Van ac not blowing cold air - Heating & Cooling
    Master:
  • 435 Answers
Maybe it is the.coolant ? Have you checked your coolant level recently? Van ac not blowing cold air - 4_24_2013_6_07_36_pm.png
Posted on Apr 24, 2013
  • calanders465 Apr 27, 2013
    Yes coolant level good
Ice maker
  • 8 Answers
SOURCE: ac blowing hot air instead of cold
Check for the following problems
(1) Check if compressor is geting power
(2) Check if system have Refrigerant in it
(3) Check if pressure switches are operational
(4) Check Thermostrat setting.
(5) Check for dirty or block condenser or evaporator
Send feed back if you solve problem
Posted on Mar 27, 2008
22yooper
  • 828 Answers
SOURCE: Refrigeration AC not blowing cold air
If you can hear the A/C compressor start and run then your system has lost it's charge of refrigerant. If the compressor does not start and run it could be a control problem.
Posted on May 17, 2008
  • 77 Answers
SOURCE: ac BLOWING HOT AIR INSTEAD OF COLD
Check to see if your outside unit is running. If not, check the breaker. If it is running you may have an issue with the reversing valve. It looks like three lines coming out of the top and one on the bottom. Trace the wires back to see that they are tight and secure. Of course, TURN OFF THE POWER first. good luck.
Posted on Apr 18, 2009
  • 4 Answers
SOURCE: carrier air-v AC is not blowing cold air
There could be a freon leak, or just low freon levels. If this is the case, you have to call a certified a/c technician to recharge your system.
Posted on May 19, 2009
  • 587 Answers
SOURCE: carrier RV AC is not blowing cold air, compressor
If the compressor is running and the air is cool but not cold it's probably low on refrigerant.
Posted on May 20, 2009
Won t blow cold air
Do you know if the system is full ? What are the gauge readings ?
Jul 02, 2013 | Toyota Cars & Trucks
1998 Ford Econoline Van E-150 Front A/C blows cold rear A/C blows warm?
Generally you would need to check the level of freon in the system, and probably the expansion valve in the rear unit. You should have one hot and one cold ac line going to each evaporator.
Aug 22, 2012 | Ford Cars & Trucks
Chevy venture van passenger side AC blows cold, driver's side blows warm to hot
Usually a blend door problem, either the control or the blend door itself.
Jul 03, 2012 | 2000 Chevrolet Venture
The air is cold, but even when the fan is on high, the air conditioner of my 2004 mpv blows very weak and won't cool van very well.
hello l..... Begin by replacing the air conditioner relay. That should solve the weak fan volume. If the AC still is not as cold as it should be get the AC system charged [add more refrigerant]. The charging requires special tools so most folks leave that to the pros at the garage. Joe
Jul 17, 2011 | 2004 Mazda MPV
I HAVE A CONVERSION VAN FRONT AC BLOWS COLD AIR BUT MY REAR AC IS BLOWING JUST HOT AIR.
Once again, it could be the temperature doors not operating correctly on the rear hvac module.
Mar 08, 2011 | GMC Safari Cars & Trucks
AC repair on a 2005 Dodge Sprinter Van
system needs serviced possible low on ac fluid.
Aug 25, 2009 | 2005 Dodge Sprinter 3500 Standard Roof
Air conditioning not working properly
Would have him check out side air temp sensor ,thermister and rerove control head and inspect for burned terminal.1st.
Jun 20, 2009 | 2002 Oldsmobile Silhouette
A/C not cycling and blowing hot and cold air.
Hello msbrig,
This is a REAL SWAG
(stab in the dark... (a bit reasoned))...
Confession... I'm no GM expert... but
General Motors & FRIDGIDAIRE
are the "GREATS" in automotive A/C.
and
This is the BEST DOCUMENTED QUESTION I have
ever seen (congratulations)...
I hope I am not doing a disservice by attempting an answer...
If your vents blow al any time... you ought disregard their behavior.. Likewise temperature controls...
and DUAL EVAPORATRS... front & rear...
The fact that your troubles are intermittent in the FRONT & REAR is a really great SYMPTOM...
You are MOST LIKELY looking at only two POSSIBLE PROBLEMS....
1. - Either your CHARGE is insufficient to keep
the compressor running.(pressure switch monitored)
OR
2. - You have a SATUATED DRYER which is allowing moisture to block your EXPANSION VALVES (internal ice) ...
External frosting is expected...
a lot of external FROST is an indication of #1. (above: low charge)...
A descent refrigeration person should be
able to tell you the HIGH and LOW pressure loads... and watch your system cycle for a few minutes... Which should be long enough to DETERMINE if you are experiencing
INTERNAL MOISTURE ISSUES...
Some folks ROUTINELY replace the ""DRYERS' (desiccant)
I do not... I use brains, gauges, experience... and your vehicles HISTORY
I am here most every day... Push comes to shove... I have the
Lincoln Navigator... dual EVAPORATOR system...
(I'll pull the book & take a look).
You can comment me back...
I bought ALL THE TOOLS years ago... NOTWITHSTANDING my amateur standing... I only let the JAGUAR DEALER jam me for an $800 Schrader Valve since 1965 (Mustang(all the rest... I did myself)).
Happy to chat... comment me back.
(again: here daily)
- Hope this inspires...
Carnac the Magnificent
http://www.rockauto.com/en/catalog/oldsmobile,2002,silhouette,3.4l+v6,1382295,heat+&+air+conditioning,a/c+receiver+drier+/+accumulator,6972
More Information for ACDELCO 1510088
Feb 27, 2017 | 2000 Oldsmobile Silhouette
AC works when ever.
vacuum line reserved vauum bottle crack not enought vacuum reserved when you give gas vacuum goes down that normal that why they put a reserved tank follow the vacuum line to the reverved tank check it out hope it help fixye our post thanks pierre
Jul 12, 2008 | 1995 Chevrolet Lumina Apv
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
