Question about Farmall International Tractor 140 Radiator
Tighten steering on a Farmall 140
The play in the steering is about 1/3 of a turn. is this normal? If not, I have read on this post that you can back off a locking nut on the steering box and lose or tighten the screw to tighten up the steering. The problem is there is no such nut,screw or or adjustment. Only plugs to add or drain oil. What do I do?
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: Which cylinder is #1 on a Farmall Super
The radiator. All in line engines always have the #1 cyl closest to the harmonic balancer / belt pulley.
Posted on Apr 11, 2010
  • 51 Answers
SOURCE: NEED TO KNOW HOW TO TIGHTING STEERING ON 140 tractor
if all tie rods are tight the steering box has a philips screw with a jam nut loose nut turn screw in until it stops, back out a little tighten jam nut. that takes slack out of worm gear. hope this helps
Posted on Aug 01, 2010
A little play in steering wheel how do i adjust the steering box has a bolt and nut older ones had a bolt with a hole for a allen wrench to tighten
The same way. Loosen the nut, tighten the bolt down snug, then back it of about 1/8 turn. Drive it and adjust as necessary. If it doesn't adjust out. Check other steering linkage parts.
Apr 29, 2016 | Cars & Trucks
How do i adjust the steering box on a john deere jd1950
Pretty much every steering sector has a way to remove excessive play (backlash) in the worm gear. Look on the sector for a locknut encompassing a large threaded bolt with no head, usually a wide slot for a "flat bit" used in a 3/8 or 1/2" ratchet. Some DO have a square headed end on the adjustment screw. Back off the lock nut 3/4 turn and tighten the adjustment, turn the steering wheel back and forth, tighten the adjustment screw again, tighten the lock nut and go for a spin. Hopefully adjustment improved it a bit. If not, try it again. Do not tighten it ridiculously tight though.
Nov 11, 2014 | Garden
140 international tractor when turn motor off the motor runs backwards
It is called dieseling. Could be carbon on the plugs or in the combustion chamber. Carbon gets hot enough to cause fuel to keep igniting after ignition is turned off.
Apr 18, 2014 | Farmall International Tractor 140 Radiator
Aug 01, 2010 | Farmall International Tractor 140 Radiator
Battery polarity
yes it is correct it is just the way it is
May 11, 2010 | Farmall IH Tractor 130, 140, w/c123 Eng...
Which cylinder is #1 on a Farmall Super C....toward the radiator or toward the steering wheel.....
Apr 11, 2010 | Farmall Tractor A-i,av,super A ,super Av...
How to install a 3 point hitch on a 140 farmall did not come with a 3 point hitch
I think a 140 is a IH Cub . I don't believe they had available a 3 point hitch. Please register at www.farmallcub.com and there are people there that have had a 140 apart and back together many times. IF there was a 3 point hitch available they will know about it.
GOOD LUCK
Mike
Oct 16, 2009 | Garden
Wiring diagram for ignition switch farmall 140 tractor
FOUND YOU A WEB SITE FOR WIRING DIAGRAM
CARTER & GRUENEWALD CO. INC.
IF THAT DOSN'T WORK LOOK UNDER FARMALL 140 WIRING DIAGRAMS AND THE SITE WILL BE LISTED THIS SITE WON'T LET ME COPY AND PASTE TO YOU
Sep 16, 2009 | Computers & Internet
1998 dakota steeering play
on the steering gear box theres a flathead screw with a nut on it loosen the nut the have someone to move steering wheel back and forth while you tighten flat head screw slowly then tighten nut back
Jul 28, 2009 | 1998 Dodge Dakota
Farmall International Tractor 140 Radiator Logo
78 people viewed this question
Top Farmall Garden Experts
Dennis Key
Dennis Key
john h
john milligan
Are you a Farmall Garden Expert? Answer questions, earn points and help others
