Question about Garden
Over heating bobcat
After running for about 20 min begins to over heat
  • Garden Master
  • 2,478 Answers
CHECK YOUR THEROSAT FIRST.
Posted on Apr 29, 2013
On a 1995 chevy lunima have heating problem i replaced thermastat heater core and heat controller still no heat controller
when idling does the temp gauge move on the dash and if you give it gas does it move open the rad cap start the engine let it run for 15-20 mins is the prestone pouring out or is it just setting if it boils out 1-airlock,2-headgasket,after it runs and all the air out try to replace the rad cap possible cap leaking causing no pressure and no heat
Jan 27, 2014 | Cars & Trucks
I have a 99 nissan quest after it warms up 20 min or so, it dies and wont start for 20-30 minutes, then runs 15-20 min and does the same thing.
not sure about your vehicle but it sounds like a coil when they go bad they heat up and open so the engine will get no spark , it's a cheap try.
Aug 30, 2011 | 1999 Nissan Quest
I have a LGR5636EQ3 Maytag dryer that will not heat up and the timer is not keeping correct time. Dryer will run but longer than preset time and no heat. No click noise when started. I had dryer set at 60...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 13, 2010 | Kenmore 73952 Gas Dryer
Laptop lock up
More than likely it is a heat issue. Does the problem occurred when the laptop is on a hard surface? If the problem disappears when on a hard surface (desktop), then it is a heat/ventilation issue. You might invest $20 - 30$ for a laptop cooler.
Oct 13, 2009 | Computers & Internet
Supra over heats
Change your water pump.
Oct 13, 2009 | 1988 Toyota Supra
After purchasing a new Motherboard, my computer jsut seems to power down after about 20 mins playing games on it. Other than that it is ok.
It definately sounds like a heat issue.
Did you use the thermal paste to heat sink? Make sure your fans are all running. Make sure the heat sink is snapped tight to the processor.
I would suggest a system monitor to detect heat and speed of fans.
May 23, 2009 | Gigabyte MB GIGABYTE GA-MA74GM-S2H AMD740G...
Heat Pump Reset Button
If running in heat check indoor air filter if in cool wash out outside coil with garden hose make sure fan is not overheating and shutting down.
Jan 06, 2008 | LG LSC121PMA Split System Air Conditioner
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
