Question about Power Acoustik Poweracoustik Pcnc2.0f Capacitor
How do i hook up my power acoustik capacitor the right way.
  • 8,197 Answers
HEY GUY..FIRST THING....GOOD JOB IN GETTING A BIG CAP :) ...SECOND I HAVE WIRED THESE FOR YEARS..ITS REALLY VERY EASY.......THE OBJECTIVE IS TO PUT THIS IN LINE WITH YOUR AMP....SO WITHIN ABOUT A FOOT AND A HALF OF YOUR AMP..YOU WANT TO 1.. CUT YOUR POSITIVE AND NEGATIVE WIRES RUNNING THE POWER TO YOUR AMP...2. YOU WILL THEN CUT THE INSULATION OFF AROUND THE POSITIVE AND NEGATIVE WIRES ON BOTH ENDS OF THE WIRES YOU HAVE JUST CUT(YOU WILL END UP HAVING THE 2 POS AND 2 NEG. WIRES WITH THE INSULATION PEELED OFF)... 3... YOU WILL THEN JUST HAVE THE 2 WIRES (WITH THE INSULATION GONE OFF OF THEM) OUT OF THE AMP..AND THE OTHER 2 STRIPPED OFF RUNNING TO THE CAR BATTERY (POS) AND THE (NEG) TO THE CAR FRAME OR NEG BATTERY POST... 4.. YOU WILL THEN JUST MATCH UP THE POSITIVE FROM THE AMP INTO THE POSITIVE ON THE CAP...AND THE POSITIVE GOING BACK TO THE BATTERY OF YOUR CAR TO THE POSITIVE ON THE CAPACITOR...DO THE SAME THING WITH ALL OF THE NEGATIVES.......
SUMMARY.... CUT THE NEG. AND POSITIVE WIRES.WITHIN 1.5 FT FROM THE AMP.... PEEL INSULATION ON WIRES BACK ABOUT .5" ON ALL 4 WIRES.... PUT ALL THE POSITIVES TOGETHER AND ALL THE NEGATIVES TOGETHER...AND YOU CANT GO WRONG....THANK YOU
Good Luck
Posted on Mar 12, 2009
3 Suggested Answers
  • 95 Answers
SOURCE: power acoustik 5 farad neon digital capacitor
You hook it up in parallel with your amp. You'll see a and - on the clear plastic cover.
Hook a wire from your amp or positive to the capacitor
Hook another wire from your amp - or negative to the - on the capacitor.
That's it, you're done.
If the plastic cover is missing, or painted over, with the neon tubes at the top, and the connector/display end facing you, the right side is the left side is -.
Posted on Aug 29, 2010
etirbynnor
  • 655 Answers
SOURCE: Need diagram to install capacitor
Hello tommysgirl,
Here's a link to Car Audio Help's cap wiring diagram.
Hope this helps.
Posted on Aug 28, 2009
Can i hook up My 500w Power Acoustik subwoofer to my entertainment center
yes, but you will need a significant 12 volt power inverter to support 500 watts
Feb 19, 2016 | Power Acoustik Car Audio & Video
I have a PCX-5F POWER ACOUSTIK 5-Farad Digital Capacitor and after i turn the car off it stays on and sometimes when the keys not even in the ignition the cap stay on. why is it doing that?
It is a capacitor. Please read up on how capacitors work and it will explain itself.
The capacitor is holding a charge, just like it was designed to do.
Oct 01, 2012 | Power Acoustik Pcx-5F 5-Farad Digital...
Where do i hook the remote wire up to my power acoustik head unit
Me either.
Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
May 07, 2012 | Pyramid Car Audio & Video
25 farad cap slowly losing its charg if the car sits for to long
Cap is hooked up wrong, should shut off after a certain amount of time and reactivate with the ignition hot wire. If it's draining your battery continuously then you should look at the wiring.
Dec 24, 2009 | Power Acoustik Pcnc3.0f 5 Farad Digital...
Power acoustik 5 farad neon digital capacitor
Sep 08, 2009 | Power Acoustik Pcnc3.0f 5 Farad Digital...
Hello tommysgirl,
Hope this helps.
Aug 27, 2009 | Power Acoustik 1.2 Farad Capacitor Pcnc...
Capacitor shuts off
HI DUDE UR CAR BAT NEED TO B CHANGE PLUS UR ALTERNATOR IS GOING TO FAIL SOON ... THATS ALL ... IF U ARE USING NOW IT MAYBE COZ LOTS OF PROBLEM TO CAPICATOR
Apr 05, 2009 | Kicker DX700 Car Audio Amplifier
My amp goes in protect mode
Maybe the audio amplifier IC´s are damaged
Feb 06, 2009 | Power Acoustik GOTHIC OV2-1200 Car Audio...
Protection light on
i had one of these amps, if you don't have a good ground, the protection light will come on.
May 09, 2007 | Power Acoustik TS1440-2 Car Audio...
Power Acoustik Poweracoustik Pcnc2.0f Capacitor Logo
628 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
