Question about Moen & One Handle Tub & Shower Faucet
Need to change cartridge in shower, how to do it/
1. do i need to turn water off for entire house, no way to find if present behind the wall the on/off handles like under sink
2. can't seem to see how one removes old cartridge after removing plastic (single) turnign knob held by one screew
3.brand is moen
4. handle turns OK right and left and does work but is very tight! to pull on/push off
4.?does the chrome plate with two screws securing the plate from which the turn assemly exits the center, need to come off
hey, thanks!!!!!
ps; any diagrms to refer me to, thanks again
louis
  • 374 Answers
Louis, if you do not have a separate supply cutoff to the fixture-most residential units do not- then yes you would need to turn the house supply off. Remember to bleed the pressure off the system before attempting this repair.
1. you remove handle.
2. remove the chrome extension tube that goes around the stem and is in the center of the trim plate. It will pull straight out by hand.
3. there is a small brass retaining clip that holds the cartridge in place. It has a small tab on the top of it with a small hole in the center of the tab. Remove this tab by lifting it straight up. You may need a small set of pliers.
4. Now take and attach the handle back on and pull the cartridge out.
5. It sounds as if you have hard water in your house and the mineral deposits have caused this issue. This will also make extraction a bit harder but if yu give it a few good pulls it normally will come out. If not you may need to buy a cartridge extraction tool that is sold at most hardware stores relatively inexpensively.
6. Pay attention to how the stem is orientated so you can install the new one the exact same way.If you neglect this you may find that the hot and cold water are on opposite sides now. If this occurs remove the cartridge and rotate it 180 degrees and reinsert.
Thanks for using Fix Ya.
Posted on Mar 13, 2009
I need to replace the gasket in the shower knob, where is the shut off valve?
you will need to see if there is a seperate turn off near the shower. (usually behind the wall in an adjoing room. if not you will need to locate the main for your water and turn off the entire house while you fix this problem.. The Home Depot has several how to's on there web site for this issue.
Apr 19, 2012 | Delta Plumbing
I have a Danze D112000BT Single Control Pressure Balance Mixing Valve with Screwdriver Stops that was installed in 07, it been working fine then last week it all of a sudden became really stiff to turn...
Danze cartridges are known to have problems after time with hard water. If you call Danze at 1-888-328-2383 USA
Canada: 1-800-487-8372
They have a lifetime warranty of defects, and will replace the cartridge for that valve for free. It will actually be best to have a plumber do it because taking the cartridges out can be simple, putting them back in and tightening it up the way it should be can be tricky. It is nice that you have the valve with the screwdriver stops. That allows you to remove the cartridge without having to turn the water off to the entire house. Simple turn each stop to turn the water off, remove cartridge, put new cartridge in.
May 01, 2011 | Danze & Single Handle Tub And Shower...
I just installed a Tuscany Asti shower body. The hot and cold are reversed...the instruction booklet says, "the water supply can be modified to correct the orientation without changing the pipe...
My booklet says "remove the cap by hand, remove the eclip from the cartridge body with pliers, remove the stem ring from the cartridge body with pliers, reverse teh cartridge stem by turning 180deg. It is not necessary to remove the cartridge from the body. Make sure the flat side of the stem ring is on top and re-assemble in reverse order." or something to that effect.
Mar 23, 2011 | Ldr Industries 520 1300C ADJUSTABLE SHOWER...
Good afternoon, We have a 25yr old delta shower faucet and head. both work wonderful but the water is not all that hot- our new hotwater tank is set at 130 degrees. If i need to change the mix do i do it...
You don't change the setting on the faucet or behind the shower wall. You change the mix in the hot water heater itself. New hot water heaters are set at a relatively lower hot-water-setting for liability purposes. To achieve a hotter mix, take the cover plate off the hot water heater. You will see a dial setting that allows you to turn up the heat. Depending on what type of water heater you have, there might be two cover plates (lower and upper). If so, you'll need to adjust both of these.
Feb 26, 2011 | Delta T13420 Chrome Classic Single Handle...
Very loww water pressure when taking a shower, I've changed the shower head,but, water pressure continues to be low. I've got moderate water pressure in the face bowl in the bathroom and good to moderate...
It could be debris in the cartridge at the tap itself. Whther 2 cartidges or 1 , it wouldn't be uncommon for those to clog up as well, and it really doesn't take much to cause a decrease in flow. Turn water off to tap(s) and remove handles, then cartridges in behind with proper socket or wrench and inspect for debris inside hole cartridge came out of, as well as the cartridge.
Dec 29, 2009 | Home
I have an 11 year old, single handle shower control that when turned off has dripping. I have taken off the handle, etc and am at the wall. What is the next step or steps?
After you remove the chrome collar and plastic collar washer (behind the faucet handle), pry the beauty plate off the wall. Turn off the house main water supply. Remove the four screws and washer holding the cartridge and valve stem in place. Save the metal washer under the four screws for use with the new cartridge. Replace the stem/cartridge assembly and secure with the saved metal washer and four screws. Reinstall beauty plate, collar & collar washer, then handle.
Dec 21, 2009 | Price Pfister R89-7PC0 Chrome Portland...
I have a Delta single handled fixure that goes up and down in my shower. It is squeaking. It is getting harder to turn off. How do I fix this. It is similar to Model No.142913. It is about 8 years old.
There is a replacement cartridge for the valve. It is not expensive. ($20-$30) Lowes You need to see if there are shut-off valves on the inlet ports of the valve (behind bath wall cover-plate), they look like two flat-head screws usually on lower side of valve. If these shut offs are not present, you may have to shut-off house main. These valves are very reliable and typically an easy fix!
I hope this helps.
Nov 10, 2009 | Delta & Single Handle Shower Faucet
Faucett drips after shutoff
First shut main water off to house. Pull handle, there is a set screw on bottom side. It is a allen wrench. Now with chanel locks unscrew bonnet and pull cartridge, behind you will find 2 black washers with springs in them. This is what you need to replace to get dripping to stop.
Sep 26, 2009 | Delta & Leland& Tub & Shower Faucet
Been using shower for a couple of years .when fifished showering it will not shut water off all the way felt like stem was stuck not going back to close of water supply.After forcing it back all the way it...
First determind what side is dripping(hot/cold) then turn off water to entire house unless you have separate shutoff for shower behind wall. take a screw driver remove handle then use channel lock pliers to remove stem on the bottom side of the stem there will be a screw with a rubber washer on it you must remove the screw and replace the washer them re assemble Oh go to home depot and buy a the assorted pack of washer for faucets and stems find one that fits the pack cost about 4.99 best to change both rubber seal washer on hot and cold sinc e you have the water off
Jul 02, 2009 | Moen 3175 Legend One Handle Shower Faucet...
What steps are required to remove delta single hande shower?
No only when you remove the cartridge will you have to turn off the water.
Jan 09, 2009 | Delta & Single Handle Shower Faucet
Moen & One Handle Tub & Shower Faucet  Logo
348 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
