Question about Mitsubishi VS-55707 TV
50" Mitsubushi Projection TV --- 12yrs old
TV stopped working the other day. I had been having trouble with my pictures fading in color. It seemed to get a bit worse as the months went by. I would give the side a little smack and the lines would ajust back in order just fine. However, just the other day when I pushed the power button on, it clicked back off within a few seconds. Not sure why?? Cannot get anything from the TV other than click on -- click off. Is it time to retire the Mits, or can this be an inexpensive repair? Thank you, Reginald
  • Anonymous Nov 14, 2007
    Mitsubishi VS-50501, Sep 1997. Same problem...Color had begun to slowly fade, and then just recently, the power went off completely. When you turn it on, within 3 seconds it clicks itself off. Solutions?
    Genius:
  • 1,074 Answers
Your tv needs to be repair hitting on the tv signifies that your tv has an intermittent problem.this means that the circuit board has loose connections resolder your circuit board.if you cannot do it your self have a tech look at your tv to repair it.the repairs will not be expensive.i believe that some parts will have to be replace in the power supply prepare for that.good luck
Posted on Aug 04, 2007
I have what I think is a Hitachi 55 inch ultravision rear projection TV that is 12 years old. I think the model is 55UX58B. The color goes out and it becomes black and white. It comes back after a few...
When the tv is it totally black and white and the tv picture are good and clear wright?when the tv colors are fade in and out are clear up and when the tv picture it is in colors it is look good normal picture wright?Tv have no shadows of any kinds of colors when picture are good in colors wright?Yes,take ur hand make fist or take a wooden hamer bangs all around the tv bazel frame if the tv colors come back or tv stay in colors it is have good picture in colors.Tv it is still good just have components parts are cold soldering or CRT colors guns R,G,B just require resoldering works only.
Aug 22, 2011 | Hitachi 50UX57B 50" Rear Projection...
TV worksfine for one hour, colors fade in and out, flickers
Color Wheel, Go website Encmpass Parts Distr Look up the part # if they do not have it in stock then go to E-Bay look under Electronic 1-800-638-3328
Oct 07, 2009 | RCA HD50LPW175 50" HDTV
The color on my mitsubishi model # vs-5041 is faded and foggy.
Hi, did you try a color convergence? I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
Hope this helps :)
Sep 16, 2009 | Mitsubishi VS-50605 50" Rear Projection...
The color seems to be fading. NOt a clear picture.
Likely the picture tubes are getting weak from old age. Not much you can do about this.
Mar 30, 2009 | Televison & Video
Tv is now in faded black and white
Your HT Tansfer is giving low votage to the picture tube. Replace the HT Transformer(don't touch or go near it, it carries 11000 Volts!)....sodeep
Mar 22, 2009 | Samsung HLN5065W 50" Rear Projection...
Panosonic 50" LCD 1080i HDTV screen picture faded
try setting your menu;s to adjust the picture settings
Aug 23, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
Color blinkig in and out.
It seems like the color wheel might start to fail.
Do you hear any abnormal sound(s) from the TV when ramdon color appears.
Would you be able to check and make sure all the fans are working properly?
Jul 13, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Usually what I find in those sets with that symptom is that the solder joints have cracked on the convergence output IC. When this happens you may see the colors no longer lining up on the screen, and slapping the side might temporarily straighten it out again. After a while the convergence IC will short out inside, which overloads the convergence power supply, possibly shorting a diode and/or burning the resistors. The computer senses that the power supply is not working right and shuts the set back off. When I make a housecall for a set like that I charge $150, but some shops charge up to $400, so ask around.
Aug 04, 2007 | Mitsubishi VS-55707 TV
Color Fading
check your menu settings if not there then you may require board level service.or eprom sub menu adjustment.
Dec 02, 2006 | Panasonic PT-47WX42 47" Rear Projection...
Mitsubishi VS-55707 TV Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
