Question about Hitachi Touro Desk 1 TB USB 20 External 0S03288 Black [Amazon FrustrationFree Packagi Hard Drive
Hitachi 1 TB external hard drive won't power up
I plugged in my external hard drive this morning to do some editing on a paper I am writing and it won't even turn on. No clicking, no buzzing, no flashing blue light. Can it be fixed?
    Problem Solver:
  • 8 Answers
Yes you can fixed it replase cover and and cut hdd and buy new rak out side and conected the new rak with hdd that is very esy
Posted on Apr 26, 2013
DickCanFixIt
  • 948 Answers
SOURCE: Hitachi External Hard Drive (500GB) Beeping sound
Probably not. You can try putting it in the freezer overnight (in a bag please, don't get moisture in it) but most likely if you must have the files back it will take professional help.
Posted on Jan 30, 2009
lock123
  • 6831 Answers
SOURCE: Computer doesn't detect drive
Hello
I had this problem a few months ago and i fixed it by following this steps.
Go to control panel.
Administrative tools.
Computer managment.
Storage.
Disc management.
Right click on you drive in the chart
Click on change drive letter
Change
Restart your computer and it should work.
Please rate this.
Best regards
Posted on Sep 25, 2009
steve_e_uk
  • 1675 Answers
SOURCE: hi, my external hard drive recently cannot be
Hi there
I dont know if this will work for you but looking on the web I came accross someone who had a similar problem they fixed it as follows.
They installed Tweak UI and then
She was able to get the drive recognized using "Tweak UI", clicking on My Computer, Drives,and check marking Drive F. It did the trick.
Hope this helps software link for you
http://www.annoyances.org/exec/show/tweakui
Posted on Mar 17, 2010
  • 14 Answers
SOURCE: Hitachi 250GB external hard drive on Mac OSX problem
try to format it in other way like ntfs or fat32....
Posted on Apr 09, 2010
  • 101 Answers
SOURCE: have new drive Hitachi SimpleDrive Mini 250GB USB
Most USB hard drives require an external (or secondary) power cable to power the devices when connected to laptop or netbook computers. In some cases, even older desktop computer models will require a similar cable.
This is due to the specifications for the USB standard as it dictates the amount of voltage that a USB port can deliver. Some USB ports are considered "powered" and are sometimes identified by the USB logo and a small "+" sign to indicate the added voltage.
Note: Not all manufacturers use this logo, so if your computer doesn't have this variation of the logo, it doesn't necessarily mean the USB port is not powered.
This added voltage supplies additional current to power smaller devices, such as portable (or 2.5") USB hard drives. However, in the even that the USB port is not powered, then only the minimum amount of current is supplied. This should be enough to slightly power the drive, but not sustain it, thus causing the clicking noise and there isn't enough current running through to move the arm that reads the data on the hard drive.
Chances are that the USB ports on your Asus Eee are not powered and won't allow your hard drive to run until either a secondary cable is purchased or if you use a powered USB hub instead.
The secondary cable looks a lot like a Y-USB cable with one end that connects to your hard drive and the other end consisting of 2 USB plugs that both connect to existing USB ports on your netbook. Between the 2 USB ports, they can draw enough current to power the hard drive - the downside being that if you only have 1 USB port you cannot utilize the cable or if you have 2, they will both be occupying the ports while the hard drive is in use. These cables can cost about $1-7 depending on brand and can be found online in retailers such as eBay & CompUSA.
The USB powered Hub is a more expensive solution, ranging at about $10-25, but is the higher recommended of the 2 solutions since it will provide its own power supply to the tiny device, will use on 1 of your USB ports and since it's a hub, they usually have anywhere from 3-5 additional USB ports (all powered) for you to use, if needed. Some even include built-in memory card readers and they do not require any additional drivers or software to install and can work on any desktop/laptop/netbook.
Posted on Aug 14, 2010
Im trying to recovery my music in my hitachi tb, but usb doesnt recognize the device, help
If you PC does not see the drive (assuming the PC has all the required USB drivers), then, 1 check and or subsitute the USB cable. 2. check the power supply/wall wart for correct power. 3. check the USB plug on the PC, try a different one if equiped. 4. the USB interface card in the external case may be toast. You will need to check or sub the interface to ensure that's not the issue. 5. place the drive in a different case with a different USB interface.
Jan 19, 2014 | Hitachi LifeStudio HLSDBUB10001BBB 1 TB...
Power supply specs Hitachi Lifestudio Desk Plus
Hitachi Lifestudio Desk Plus Hlsdpub10001bbb 1TB Drive and original AC adapter have been separated. Need to know Adapter output Voltage/amperage identify original or acceptable replacement.
Sep 17, 2013 | Hitachi Lifestudio Desk Plus...
Buffalo external 1tb won't power up
Return the hard drive to the place of purchase, this is a manufacture defect.
May 12, 2012 | Buffalo Technology Buffalo DriveStation...
Have a 1 tb buffalo external hd. worked great had it for back up. I unplugged it to move my computer. when I plugged it back in, there was no green light no power to the drive. check voltage and the power...
try to test it on other computer or laptop... if the unit are still exist maybe your problem would be the external drive..there are no switch button on it, because most of the switches are located on the adapter, the only testing you could do is to test it to other unit..If the external drive are ok once after you test from other PC's, then might as well check your USB port by plugging-in to other port...or try to use other power supply on your computer, co'z sometimes the supply can no longer supplied any voltage coming from your external drive once it plug-in..
Aug 20, 2011 | Buffalo Technology DriveStation Axis 1 TB...
My usb touro external hard disk won't turn on/ be detected. its so new. its really frustrating
You need to be sure that it is plugged into a USB 2.0 slot. Sometimes USB 2.0 devices will not be detected in USB 1.0 or 1.1, or on low powered USB slots. The back of your computer is the most likely location for a USB 2.0 and is likely indicated.
Jul 05, 2011 | Hitachi Touro Desk 2 TB USB 20 External...
How do I disconnect (uninstall) a WD External Hard Drive from my computer? I am using a WD 3200AAK WD External Hard Drive and want to install a 1 TB WD External Hard Drive. I would like to use the old one...
External hard drives don't need any program installed on your computer to run. Your operating system Windows, Linux should handle it as soon as you plug the usb in your computer. The programs included in your WD external hard drive are tools to backup your data.
If you try to hook up your hard drive to a Windows prior to XP, maybe your computer will not handle it.
It is always safer to safely remove your drive using the green arrow icon in the lower right corner of your screen. This way, the drive is shut down properly and you minimize chances of fails when you plug it again on another computer.
Hope this helps!
Feb 08, 2011 | Western Digital My Book Essential Edition...
My XP will not boot when my Hitachi 1TB External USB 2.0 drive is connected. It gets as far as showing the Pentium screen and stalls.
Its probably trying to boot from your external drive.
Go into your bios and reset your boot setting to HDD0 as your first boot device, Disk drive 0 second and floppy third, unless you want to boot from an external drive. That being the case select an appropriate order.
If the bios shows your external HDD as HDD0, then you have to work out which is the drive carrying the operating system and set that to your first boot device.
To get into the bios, watch the boot screen for a key to hit to enter setup, normally its the "DEL" key.
May 03, 2010 | Hitachi 1TB External USB 2.0 Hard Drive
1 TB drive not turning on.
u mite need a replacement caddy if you are outa your warrenty period i would open it up an test the hard disc drive on another pc if it powers on u need to get ur self a another caddy type in google external caddy
Mar 11, 2010 | Western Digital My Book Essential Edition...
Western Digital 1 TB External Hard Drive and BSOD
perhaps the new hard drive is bad western digital software is junk take it back and get seagate external w/freeagent on it
Dec 31, 2009 | Western Digital My Book Essential Edition...
Hitachi Touro Desk 1 TB USB 20 External 0S03288 Black [Amazon FrustrationFree Packagi Hard Drive Logo
290 people viewed this question
Top Hitachi Computers & Internet Experts
steve morris
steve morris
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
