Imagistics im 3511
I am not able to receive a fax confirmation
4 Suggested Answers
  • 653 Answers
SOURCE: Problem with fax on estudio 3511
When enabling the Offramp Gateway, this equipment works as an SMTP server to receive
Emails from the Internet. To enable the STMP transmission in this equipment, designate the hostname (or specific domain) that relates to this equipment in the DNS server, and designate the MX record to receive the Emails that are sent to the equipment’s domain in the SMTP server in your local area network. Then the SMTP server should be configured to transmit the received Emails to the equipment in the SMTP transmission. For example, if the hostname of this equipment is designated as “host1.ifax.com”, the SMTP server receives an Email whose forwarding address is “<account name>@host1.ifax.com”, and the SMTP server transmits the received Email to the equipment. Then this equipment will send the received Email as a facsimile document to the fax number that is specified in the <account name> part.
Setup Procedures:
1. Setting up the DNS server and SMTP server.
2. Setting up the TCP/IP and the HTTP Network Service to enable TopAccess
3. Setting up the SMTP Network Service.
4. Setting the Internet Fax Settings.
5. Setting up the Fax Settings
6. Registering the Relay Box with Email addresses.
Posted on Feb 13, 2009
  • 653 Answers
SOURCE: Toshiba 3511/4511 suddenly stopped faxing
Try use the monitor button for faxing, check whether there is tone or not.
Posted on Jul 14, 2010
richroth
  • 9472 Answers
SOURCE: i bought a used imagistics
Here is a link to the operators manual. Look at page 1 about having a valid account number for operations. You may need to contact Oce for more information listed below.
Oce contacts
Posted on Mar 30, 2011
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
Our imagistics 8130 has the replace waste toner bottle error message on but the waste bottle is empty and I turned a wheel above the waste toner bottle and nothing.
Hi how are you this is jack ... jack_pak@hotmail.com
Dear you wash the waste toner bottle clearly. But error still your copier you check the waste toner bottle dection SENCER OR IS DIRTY CLEAN IT..
PLEASE VOTE ME .
Thanks
Best Regards,
Aug 14, 2010 | Toshiba E-Studio 3511 Color Copier
Jul 08, 2010 | Toshiba E-Studio 3511 Color Copier
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Cant recieve fax on Toshiba estudio 3511
Hello sir; For the fax line only have two single lines working in the cable one is in-coming ,another one is out-going, therefore if you can send fax and can not receive, that's means your phone cable or phone jack on the wall have problem, my sugestion, replace phone cable first, if still have problem check the phone jack on the wall.
Jan 23, 2009 | Toshiba E-Studio 3511 Color Copier
01.12.2008 i fax to one number. now i want aknowledgement of that fax. its gone or not. How i can find on HP Officejet 5610 all in One System?
You can get the manual here if you do not have one - LINK.
Here is an exert form the manual on this:
1. Press Setup.
Send &
Receive
receive.
Dec 10, 2008 | HP Officejet 5610 All-In-One InkJet...
Imagistic 2500 Fax problem.
On top of the toner cartridge there may be a blue slider for cleaning the charge wire.
If not, you have a bad toner cartridge (drum cleaning blade)
Sep 16, 2008 | Brother MFC-8220 Fax
27 people viewed this question
k24674
jasbo
jasbo
