Question about Maxon Radio Communications
Does not transmit. it has receive and weather station. has less than 5 hours on it. HCB-30A MAXON/CB/WEATHER HANDHELD RADIO
The PLL chip is burned out
Posted on Mar 14, 2009
Dose it work good like i live in a prtty good nabor hood dose it get good distance will it conect withe other bigger cb radios
Typically, this type of handheld has a useful range of approximately 1-2 miles. This distance will be increased with other radios being mobiles and base stations. Distances of 5 miles is possible if the other person has a good base station antenna. I would not expect much from the stock rubber ducky antenna.
JTRadiojunkie
Aug 30, 2010 | Maxon HCB-10C CB Radio
What is the range of the maxon hcb-10 model. miles or kilometers will do
It is between 4 - 7 miles.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 26, 2010 | Maxon HCB-10 40-Channels Handheld CB Radio
The antenna base on my Maxon HCB-10C CB Radio got pulled out. Can I fix this?
Not sure what you mean here...
If the antenna is broke, then you should just get a new antenna. If the antenna connector was pulled out of the radio, it is usually fixable.
If the connector is broke off the antenna, it may may be fixable, I would have to see it. If its done wrong, you could hurt the transmit section of the radio.
You should just get a new antenna.
Sep 25, 2009 | Maxon HCB-10C CB Radio
HOW TO INSTALL BATTERIES IN MAXON 27KC AND WHAT ARE THE TWO BLACK THINGS IN WITH THE BATTERIES
KC27 Maxon CB need 10 batterys rechargables 1.2 v for 12v total, use the most amperes or miliamperes possible, if you have a charger case or 27-CRDL Cradle for 27-KC you can use 13.8v regulated 5 amps. máx. but need external antenna. When you put a radio in charger case it switch to use external mic, voltage, antenna & speaker. Actually 2500 mAh "AA" battery is very common and cheap. You can charge batterys on to radio case, only need a 200 mAh eliminator at 15v for 6 hours.
May 31, 2009 | Maxon HCB-10 40-Channels Handheld CB Radio
BATTERY CHARGER HCB-30A CB MAXON
you can get that charger aftermarket at radio shack take the walkie with you to get the right power supply the voltage should be close to where the external power plug goes into the radio.
Mar 13, 2009 | Maxon HCB-30A CB Radio
I have a Maxon handheld cb - it squeals when keyed can not talk.
sounds like you are getting a feedback squeal.. try taking a wire and attaching to you handheld and grounding it to something.. that might work.. i know i have to have my mic on my cb grounded to my radio or i get a feedback squeal...
Jan 02, 2009 | Maxon HCB-10C CB Radio
Maxon model 27SP Handheld 40 channel CB
well it appears to have a BNC connector, so that shouldn't be hard at all.
Jun 05, 2008 | Maxon HCB-10 40-Channels Handheld CB Radio
Radio Communications Logo
126 people viewed this question
Top Maxon Radio Communications Experts
Steve
AnyMHz.com
AnyMHz.com
Mike Charette
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
