Question about Frigidaire Washing Machines
Frigidaire top load washer will not drain Model # FWX833AS2
The pump is okay elecrically and mechanically. It is not plugged. Machine will not drain in spin cycle ????
  • Frigidaire Master
  • 3,361 Answers
Check your lid switch for continuity.
No continuity, replace the lid switch.
Posted on Mar 12, 2009
My Frigidaire model FTF2140ES will not spin or drain no matter what settings I put it on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Frigidaire Washing Machines
My frigidaire front load washer Model #GLTF2940E will not spin out
heatman101
Apr 30, 2011 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
My frigidaire washer model # fws545rfs0 wont drain or spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Feb 21, 2011 | Frigidaire Washing Machines
Frigidaire washer spins but won't agitate
when you try to spin the Agitator dose it spin freely both ways if so the DOG EARs are stripped and need replacing Take cap off top off agitator to access the bolt holding the n in place and the Agitator off
Oct 22, 2017 | Frigidaire Washing Machines
Frigidaire front load washer model LTF2940FEO. As
remove lower kick panel and check for leak at door boot and drain pump.
Apr 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire wont fill,just keeps draining
Your drain hose must be 36 inches from the ground. Any lower and the water siphons out.
Apr 20, 2009 | Frigidaire Washing Machines
Frigidaire fwx833as2 getting water on floor in wash cycle
Actually there are three fairly common causes for this:
The machine may not be properly leveled, and will go out of balance when spinning, no matter how carefully you load it. The drum tilts to one side and sloshes over the gasket at the top.
The pump might be blocked up badly, causing the water to not drain adequately, which can cause the water to be forced upward and out due to the building centrifugal force. These machines are designed to drain as they spin at a fairly steady rate. If something interferes with the draining, but doesn't slow the spin down, this can result.
Finally, the maximum water level switch (sometimes also called an overflow prevention switch, among other names depending on manufacturer) may be faulty. Normally your water level is controlled by the load size selector. However, on some machines the maximum load size setting is actually limited only by the overflow prevention switch. If yours is one of those, this could explain your problem.
Feb 07, 2009 | Frigidaire Washing Machines
Washing Machines Logo
224 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
