Question about Toshiba Televison & Video
Toshiba 100hz dynamic frame scan
Has a hole in the screen,where can i get it fixed or replaced?
    Top Expert:
  • Toshiba Master
  • 75,424 Answers
No there is not such.
Posted on Apr 24, 2013
Hi, where can I find toshiba service.center here in iloilo?i need someone Who knows how to fix blue screens and audio problems of toshiba laptop..thanks
Your closest Toshiba centre in Visayas province would be in Cebu. The company is Tricom Dynamics
VISAYAS
Company Address(City) Area code Telephone Website/Email Tricom Dynamics, Inc. Level 2, Machay Building, 30 Gorordo Avenue, Cebu 032 231-0681 www.tricom.com.phicon-opwn.gif
Sep 02, 2014 | Computers & Internet
When i power my toshiba laptop how do i test my power inverter or back lite
The plastic frame in front of the LCD screen is the Display Bezel.
The screen Inverter is mounted at the bottom of the Screen Frame.
[The LCD screen is an assembly of layers. There is a metal frame resembling a picture frame; which keeps these layers in the factory set alignment; the Screen Frame ]
Therefore easy access. Just remove Display Bezel.
To test a screen Inverter requires a sensitive multimeter; read fairly expensive,
http://www.fonerbooks.com/test.htm
Due to the above, ease of access to replace, and generally low cost; the screen Inverter is just replaced.
Then on to the Backlight if this doesn't repair the problem.
Which brings me to this;
Safety
https://www.laptopscreen.com/English/model/Toshiba/SATELLITE~A100/
The Toshiba Satellite A100-S8111TD Notebook PC, uses a single CCFL for a Backlight.
A CCFL is a Cold Cathode Fluorescent Lamp. (Bulb)
Similar to it's larger 'cousins' used in homes, and businesses; but on a MUCH smaller scale.
Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height.
View the last 8 photos,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
This means it is Highly breakable. Costs more in money to just replace the entire LCD screen, (Which has the Backlight built-in),
but cheaper when you compare to life, and limb.
Jus sayin'.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 22, 2013 | Toshiba Satellite A100-S8111TD Notebook
My toshiba satellite a215-s7472 screen is very dim can hardly see anything what do I do too fix it I tried ajusting the light .
Primer:
An LCD screen does not produce light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, or a series of LED lights.
(Two present technologies being used)
The Toshiba Satellite A215-S7472 Notebook PC uses a CCFL.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
(Average size is 2mm by 334mm. In inches that is;
Approximately a little thicker than 1/16th of an inch Thick, and a little over 13 inches Long)
A screen Inverter is used to convert the power (Electricity) from the laptop, for the Backlight, and LCD screen.
Point of all this?
90 PERCENT OF THE TIME the fault is a bad Inverter
http://www.irisvista.com/tech/laptops/toshiba-satellite-a215/disassemble-display-panel-1.htm
http://www.zkarlo.com/selected-zkarlo-part/inverter-board-p907.php
HOWEVER, the Backlight bulb is located inside the Screen Frame, of the LCD display assembly.
An LCD screen is composed of layers. These layers are held in a specific pattern, by the LCD screen frame.
This is a thin metal frame which surrounds the LCD screen layers, and has Philips head screws which hold the frame together.
NOTE*
The procedure is fairly intricate.
Regards,
joecoolvette
[ So far I have only seen listings for the LCD screen itself, and not a separate CCFL Backlight ]
Feb 01, 2012 | Toshiba Computers & Internet
What is the frame output ic
Hello
Frame output IC means nothing, but the VERTICAL OUTPUT IC. Every TV will have it, which will scan picture vertically at 50 or 60 Hz. [1 HZ means one frame per second. Normally TVs will have 50Hz, 60Hz and 100Hz vertical frequency]. As vertical frequency rat increases, the picture fliker wil decrease. High level high-cost TVs will have 100Hz or even more frequency will be used for vetical scanning.
In the case of computer monitors, the vertical frequency will vary from 60Hz to 120hz. You can see its picture stability, at this high frequency.
The IC [Integrated Circuit Chip], which generates the vertical frequency and outputs it called the vertical output [frame output] IC. OK
Wish you a Proseperous and Happy 2012.
Gopakumar G, Trivandrum City, Kerala State, South India.
Dec 29, 2011 | Televison & Video
Our phillips tv 100hz digital scan 29pt9418/79 won't power up
Yes,it about 90% of the times,it the power supply board.U can look around the power supply board for puff up bulge capacitors,replaced these caps will get ur power back.10% it ur Tuner signal board.If find no defective caps in ur power supply board.Tries websites Shopjimmy.com.Ebay.com to buy ethier refurbish power or tuner boards for the replacement.
Apr 04, 2010 | Philips 26PF9966 26 in. LCD Television
My Toshiba Satellite L305D-S5895 can't boot. I installed Fedora10
If you get a display or splash screen then you may just have a bad hard disk or memory dimm. If you get nothing then it is a hardware failure beyond a simple fix. Get on the phone with Toshiba and get it fixed before your warranty is up.
Dec 26, 2008 | Toshiba Satellite L305D-S5881 Notebook
Standard CRT Toshiba TV - 4inch tall picture in middle of screen...
Not familiar with your actual model.
But a comon problem with older Tosh sets is the 2.2uf electrolytic caps from memory they are usually red there is 1 next to frame Ic & the second is near Psu.
Allso check frame o/p IC for dry solder joints this is easy to test for.
Tap the tv while it is on if the the frame suddenly pop to full size picture you know its dry joints so resolder frame IC.
http://dysonmanuals.inc.io/
Oct 13, 2007 | Televison & Video
Red line fault
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Aug 07, 2007 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
