Question about Tamiya America 1/14 Scania R470 Highline Semi
Head bolt torque setting - Tamiya America 1/14 Scania R470 Highline Semi
Head bolt torque for ir. ss5 air compressor?
It's not that critical, use a torque wrench and make sure they are all evenly tightened like you would do with the head of a car engine. Use basic torque specs for the size bolt. That can be googled. Start with a lower setting on the torque wrench. Tighten the bolts in a pattern, then increase the torque setting and torque the bolts again.
May 20, 2016 | Ingersoll Rand Air Tools & Compressors
What is torque settings for head bolts on Kia pregio 2001
What are the cylinder head torque settings for a KIA K2700
www.answers.com > ... > Categories > Cars & Vehicles > Asian Cars > Kia
What is the torque specification for the cylinder head on a 2002 Kia Sportage? ... the correct torque for cylinder head bolt of kia pregio 2.7 diesel is 130-135ft-lbs. ... Thehead bolt torque settings, on your Kia 2.7 diesel engine, is 70 pounds per ...
Aug 17, 2015 | Kia Cars & Trucks
Toyota 80 series GLX auto landcruiser 1996 need head bolt torque a nd cam shaft torque settings
Torque setting Toyota Land-cruiser 80 Series 4.5 1995-98
Engine code: 1FZ-FE, 1HD.
Stage 1: 20 Nm (Start tightening bolts from center to outwards)
Stage 2: 39 Nm
Stage 3: Rotate each bolt by 90 Degrees.
Stage 4: Further rotate each bolt by 90 Degrees
Nov 22, 2014 | 1996 Toyota Land Cruiser
What is the torque setting on the head bolt for a harley davidson sportster
Cylinder Head Bolt Installation
Factory Method
For each cylinder head, start with head bolt numbered one. In increasing number sequence (1-2-3-4), tighten the head bolt in three stages.
1. Tighten each bolt to 7-9 foot pounds of torque.
2, Tighten each bolt to 12-14 foot pounds of torque.
3. Mark each head bolt and head with aligning marks. Tighten each bolt 1/4 turn (90 degrees).
Torque Wrench Method
For each cylinder head, start with head bolt numbered one. In increasing number sequence (1-2-3-4), tighten the head bolt in four stages.
2. Tighten each bolt to 12-15 foot pounds of torque.
3, Tighten each bolt to 22-25 foot pounds of torque.
4, Tighten each bolt to 38-42 foot pounds of torque
Good luck, i hope this helps.
Aug 06, 2011 | Harley Davidson XL 1200 C Sportster Custom...
Need torque settings for cylinder head bolts on a 52 reg skoda fabia 1.4 16v any help much appreciated thanks
Torque settings for cylinder head bolts for Skoda Fabia 1.4 16v
Cylinder head bolts tightening order:
IMPORTANT NOTE: RENEW BOLTS!
Stage 1: Tightening torque = 30 Nm
Stage 1: Tightening torque = 90 Degrees
Please do rate my response. Thanks!
Dec 17, 2010 | Volkswagen Polo Cars & Trucks
I need torque settings for the engine ie head bolts v6 engine 1
i am replacing the heads on a GMC 350 cu in engine. what is the final torque of the head bolts?
Jul 15, 2010 | 1985 Chevrolet Camaro
Torque setting cylinder head bolt 4 cylinder KIA sportage
I need the torque settings and pattern for a Kia Sportage 2.2
Nov 24, 2009 | 2001 Kia Sportage
Head bolt toqure
Hope this helps, from autozone site. Curt
Application:
Cylinder head bolt torque sequence
Note :
Torque sequence:
front | 3 1 6 |
of | |
vehicle | 5 2 4 |
Step 1: Lightly oil cylinder bolt threads & washers
Step 2: Torque to 22 Ft/Lbs
Step 3: Torque to 51 Ft/Lbs
Step 4: Loosen all bolts 180 degrees
Step 5: Loosen all bolts 180 degrees
Step 6: Torque bolts 1 & 2 to 25 Ft/Lbs
Step 7: Torque bolts 3, 4, 5, 6 to 11 Ft/Lbs
Step 8: Turn all bolts an additional 80 to 90 degrees
Step 9: Turn all bolts an additional 80 to 90 degrees
*** CAUTION ***
engine uses Torque To Yield head bolts (TTY) that
permanently stretch during the initial installation.
New head bolts must be used when cylinder head is
replaced or re-installed to obtain proper Torque.
Apr 24, 2009 | 1995 Subaru Legacy
Angle Torque settings head bolts
Use new bolts, tighten in the following stages 1. 20Nm 2. 100Nm 3. wait 3 mins 4. slacken bolts 1&2 retighten to 20Nm +110 degrees 5. carry out stage 4 for bolts 3,4,5 & 6 then bolts 7,8,9 &10 Sequence, 8 4 1 5 9 7 3 2 6 10 Bolts 9 & 10 are flywheel side of the engine.
Jan 28, 2009 | 2000 Renault Sportwagon
Head bolts torque settings
According to my haynes manual for G-S reg, 1989-1998 it goes as follows,
Stage 1:- Tighten all bolts by hand until bolt heads just contact cyl. head.
Stage 2:-Tighten all bolts to 40Nm or 30lb ft.
Stage 3:-Angle tighten all bolts a further 60 degrees.
Stage 4:-Angle tighten all bolts again a further 60 degrees.
Stage 5:- M12 x 140mm bolts ONLY angle tighten a further 20 degrees.
Hope this helps everyone, sorry it seems longwinded but that is how it's written in the manual.
Oct 26, 2008 | 1995 Land Rover Discovery
Tamiya America 1/14 Scania R470 Highline Semi Logo
Top Tamiya America Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Tamiya America Toy Expert? Answer questions, earn points and help others
