Question about Dell 2150cn Printer
I have a replacement laser unit (ROS) for my 2150cn, but I need the instructions on how to replace it. This is typically done by the Dell Techs, but I want to try it myself. Anyone have a service manual?
3 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Dell 5100cn Black Developer Unit
Hi and welcome to FixYa,
You are right. The procedure was initially posted by Corysf62 on this problem. Excerpt from that post:
  • "The photo developers are located behind the imaging drum. you can see the 4 seperate developers, in the developer frame, when you remove the drum unit...You need to remove the top cover, the left side cover, the high voltage power supply, the supply tubes ( where the toner travels from the actual toner cartridges down to the developers ). Then once the tubes are removed, you have to remove the developer frame from the printer. Then you can get to the actual photo developer."
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 11, 2008
WonderTech
  • 268 Answers
SOURCE: 3100cn Laser Printer: dell 3100cn service manual...
This link will take you to a site where you can download the manual for your machine. You will the link on the right side of the page.
http://safemanuals.com/user-guide-instructions-owner-manual/DELL/3100CN-_E
Hope this helps.
Posted on Aug 04, 2010
Dell 2150cn is not connecting to the network
Cindy Massey,
Click the link below to download the online user manual for help resolving printer issues.
http://dell.to/297xh91
Thank You,
Dell-Jesse L.
Jun 20, 2016 | Dell 2150CN Laser Printer
Oki B6250 displaying error: ROS failure call service.
ROS failure is the Laser Unit has gone bad and needs replaced.
Mar 10, 2014 | Xerox Phaser 6100/BD Laser Printer
Dell 2155cdn toner rubs off
It sounds like the fuser is not heating up to the correct temperature. If you are printing on specific papers, for example: envelopes, bond, linen, make sure to set your printer settings accordingly. Otherwise you will need a new fuser unit for the printer.
Feb 19, 2014 | Dell 2150cn / 2150cdn / 2155cn / 2155cdn...
Xerox phaser 6360 laser failure code 10
You may have to replace the laser unit. Code 10 is a warmup failure. You need to reseat the connector to the ROS Harness first. If the issue persists, replace the laser unit. Issue persists, check continuity between pins J15 and J151. If there is continuity, replace the Engine Control Board, if not, replace the ROS Harness
Feb 03, 2014 | Office Equipment & Supplies
Fault codes 006-380
First check the Laser Unit for a lose connector.
6-380 ROS SOS Y Length
The interval of the ROS SOS (Y) signals exceeds the specified value.
Procedure
+5VDC is measured between the MCU PWB P/J401-B20 (+) and ground (-)
Y N
Replace the MCU PWB (PL 13.1).
Check the wire between the SOS PWB (Y) P/J516-1 and the MCU PWB P/J401 for an open
circuit.
Check the wire between the LD Drive (Y) J529 and the MCU PWB P/J401 for an open circuit.
If no problems are found, replace the ROS Assembly (PL 3.1).
If the problem continues, replace the MCU PWB (PL 13.1).
May 16, 2013 | Xerox DocuColor 3535 Copier
Where can I get a PHD for a Dell 2135cn?
Incorrect, the part number is 330-0711. It is the same one for Dell 1320cn / 2130cn / 2135cn/ 2150cn / 2150cdn / 2155cn / 2155cdn. $99 directly from Dell.
Nov 29, 2010 | Dell 2135cn All-In-One Laser Printer
Color Faded
This sounds like a typical Developer Drive failure. The Developer Drive for color is different that the black developer drive. This is why black can print fine, but colors are faint or non existant. see below,a recent bullitin about this exact issue from Dell. ( the ROS, is the printhead, and is located behind the 4 developers.
5100cn Printer
Print Quality Issue
1. Problem: - Color images are extremely faint or not produced, but black images are produced without any problem.
Resolution: - Replace Developer drive assembly (H6702) and clean ROS Window/Glass.
If you chose to persue this repair, you can probably find a replacement developer drive by doing either a google search for the part number listed ( H6702 ) or an ebay search for the same. We can also provide you with removal and replacement instructions.
Good Luck
Oct 19, 2008 | Dell 5100cn Laser Printer
Error code 11 phaser 7700 polygon motor failure
The polygon motor is part of the laser assembly, other wise know as the ROS, Raster Output Scanner.
It normally is not as simple as replacing the ros and moving on.
There are color registration adjustments to be done once the ROS is replaced. You can try contacting
https://www.partsdrop.com/store/
and seeing if they have one. That motor has the mirrors on it that rotate to focus the laser to the belt assembly.
Apr 24, 2008 | Office Equipment & Supplies
Error 10 laser unit failure on phaser 7700GX
That requires the replacement of either the ROS ( laser) assembly or the MCU board. I have seen both cause that code and indicate the laser has failed.
ROS is the laser assembly.
MCU board may not be detecting the ROS.
It is possible the connector that runs from the ROS to the board is loose, you may want to disconnect and reconnect that.
If the ROS is bad, you also have to have a laptop to connect to the machine to align the colors. That is called the regicon adjustment.
Dell 2150cn Printer Logo
57 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
