Question about Braun M880 MultiMix Hand Mixer
My handmixer suddenly stopped working while i was
My braun handmixer suddenly stopped working while i was mixing a cake.
the motor still goes. it sqeaks-and the beaters do not spin-please let me know if this problem is solveable!
  • pankaj Dec 04, 2011
    my braun handmixer suddenly stopped working while i was mixing a cake. the motor still goes. it sqeaks-and the beaters do not spin-please let me know if this problem is solveable!
    Sergeant:
    Champion:
  • 234 Answers
Sounds like the beater is not all the way in or it broke a gear
Posted on Mar 13, 2009
Kp2671 stops and starts
It is not going to be a problem with the motor. It is going to be a chipped/damaged gear, a bent planetary center shaft pin, or possibly the planetary itself.
The first thing you need to do is take the mixer apart. You are going to have to clean of all of the gears and inspect them very closely. I recommend using paper towels and wd-40. If there is any damage, the gear will need to be replaced, in some cases the pin that sits between the worm follower gear and bevel gear can become bent, if it is, it also needs to be replaced. If all of the gears, bearings, and the pin are in perfect shape inspect your planetary assembly. In some cases the center shaft, which is pressed into the planetary can become loose, so it will still spin under no load, but as soon as you put something in the bowl it stops spinning.
Here is a link to the KitchenAid service manual. This will walk you through how to take the mixer apart, and put it back together: http://lib.store.yahoo.net/lib/mendingshed/kitchenaid6qtservicemanual.pdf
Please let me know if you have any questions, or need help with the repair.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Feb 15, 2013 | KitchenAid KSM103 Professional 5 Series...
Braun 4642 Mixers user guide
http://www.user-manual-pdf.com/appliance/handmixer/braun/instruction/braun-multimix-4642-handmixer.html
Nov 12, 2012 | Braun M880 MultiMix Hand Mixer
Black and Decker Spatula Smart Hand Mixer
1990? Dump it and purchase a new one
Mar 17, 2017 | Food Mixers
Hi there, I was doing cake mixing and turn off
If you can hear the motor spinning and the beater does not spin, the worm gear has probably failed. These fail frequently, specially after using them beyond there designed limits. The motor heats up and the gear, which is a type of plastic or nylon, melts.
Feb 18, 2011 | KitchenAid KSM150PS Artisan Series Stand...
My braun mixer seems to be powering out when I am mixing dough with the hook. It also has a little sound that it makes when it is working harder. It never used to make this sound.
This sounds to me like the brushes in the motor need to be replaced. You may want to call an area shop which rebuilds electric motors and see if they have a replacement for you. They're not very expensive and fairly easy to replace.
I hope this helps and I hope you have a wonderful holiday season!
-Jason
Dec 14, 2010 | Braun Food Mixers
I NEED TO BUY GE HANDMIXER MODEL 106651N TYPE M27 REPLACEMENT BEATERS
So do I! Walmart GE doesn't cary them anymore and can't seem to give me a regular GE part number for them. Does abyone have a suggestion as to what to do next outside of buying a new handmixer?
Dec 01, 2010 | GE Food Mixers
Kitchenaid artisan mixer does not turn the blade at low speeds
If it is the worm gear then the planetary will stop turning when there is a load on the paddle but the motor will continue to run at the speed you set it at. I'd be checking the carbon brushes, checking that the field assembly has not loosened up a bit and then I would see if the speed control plate adjustment screws are loose. I'd then reset the speed and see if it stays as it should be.
Sep 24, 2017 | KitchenAid K45SS Classic Stand Mixer
Braun M880 MultiMix Hand Mixer Logo
652 people viewed this question
Top Braun Food Mixers Experts
Slo Mover
Tom Chichester
ray gallant
Are you a Braun Food Mixer Expert? Answer questions, earn points and help others
