Question about Kitchen Ranges
970-6874 element light is on all the time even with all burners and oven are off. Because of this, the self cleaning function does not work
SOURCE: self clean light blinks when you turn oven on (oven does not work)
I had this same problem with mine (still posted under unsolved) This is the simpler model with the old turn style knob and the lever you slide over to lock the door for cleaning What I think (keep in mind I know little about ovens, more about cars) is that the switch that tells the oven the door is latched is staying engaged, and this is part of the lever mechanism. I cleaned and lubed this mechanism (obviously I would guess you want to use a food safe lubricant) and then moved the lever several times with the oven on so I could see if it turned on. After a few tries the cleaning light went off and the oven light came on. No, its not really a technical answer, all indications to me where that the problem was in the switch which is part of the latch mechanism. Good luck
Posted on Dec 25, 2006
fridgetech
  • 473 Answers
SOURCE: Oven takes a long time to preheat
Before we go into diagnosis mode, call the customer service # in the owners manual and complain about the problem.  They usually will make a concession when it is this close to the warranty period.  Let me know what you find out.
Posted on Oct 25, 2007
SOURCE: Oven wont turn on.
I tried several times to get my oven to work and nothing seemed to help. After downloading the manual from this site, my husband locked and unlocked the oven door several times very hard and it knocked something in place and now my oven works. I hope it works for you.
Posted on Dec 08, 2007
SOURCE: Estate Range #TE5400PXHQ0
MY SELFCLEANING WHIRLPOOL OVEN CLEANED ABOUT 30 MINUTES AND THEN STOPPED AND WENT INTO E2 AND F1. THE DOOR IS LOCKED AND WON'T OPEN. WE HAVE TRIED EVERY THING THE BOOK SAID AND NOTHING HELPS. DO YOU HAVE AN ANSWER?
Posted on Dec 20, 2007
SOURCE: Kenmore gas range--oven won't come on
My oven will not work. After pressing the desired temp on the oven, the preheat light and oven light comes on. After about 15 minutes, the oven is slightly warm and maybe an hour later the oven may or may not heat to desired temp. Kenmore gas range model #790.72851301.
Posted on Jun 16, 2009
How do I replace the receptacle for the heating elements on the stove top.
Typically the light is a function of the selector so as long the position of the knob is to the on position it will be on. in order for the burners to work you'll have to replace the connectors, so full current can go through them. also the self cleaning feature refers to the oven meaning you can lock it, turn it to clean and it will get so hot that the build up on the inside will get flaky and then you can clean it once it cools off. I've never seen one that work that well, but it has nothing to do with the glass there is cleaners that you can "rub" kind of like waxing a car and if you have build up on the glass or burned food you can scrape it with a razor laying flat on the glass and scrape the cleaner around will eventually it will peel off.
Jan 14, 2015 | Kenmore Ovens
VDSC4876GSSLP - Oven element wont heat . . Main oven started going in and out of "clean" mode, locking and unlocking the oven door while in use, then eventually stopped working all together. Fan and light...
If there is power to the unit (lights turn on) I would check the fuses and switches especially the one for door lock mechanism if you noticed a glitch. But a lot of times if you experiences problems after running a self-cleaning function, including locked door issue, the solution could be as simple as resetting a switch and no actual replacement parts needed. It all depends. If you are in Los Angeles, we could send a Viking repairman the same day you call us. : Viking Appliance Repair
Dec 08, 2014 | Viking 48" 6 Burner, 12" Grill Gas...
I have an electric stovetop and did a self cleaning it would not unlock so i turned off breaker and was able to unlock when i did the baking element was so brittle that it snapped and now all the burn
Ok,... First, and foremost, stop using the self clean. It takes the temperature up to 900 deg F, and creates all sorts of other problems with the lock motor and the walls and the bake/broil elements. Use a Low odor Easy-off spray cleaner to clean your oven from now-on, please.
Now, the bake element needs to be replaced. If you have the model number (found on the body of the Range behind the lower drawer, if you pull it out) I can look-up the manufacturer's suggested part to be replaced. You may also need to replace the broil element, but that usually is the last element to burn-out as most people don't use the broil function of an oven.
You will have to pull the range away from the wall, and unplug it before you attempt to replace any parts. No need to have 240 VAC/30 Amps running through your body. There are several black 1/4" screws that secure the back panel on the oven section to the body (about 6 to 8) and they will have to be removed to pull and replace the wires on the oven bake and/or broil elements. You will also have to go to the oven door (on the front of the range) open it, and remove the two 1/4" screws that secure each element to the body before you can change-out the element(s). The most popular bake elements for GE Ovens are part #WB44K10005 and/or WB44T10010, but there are other Bake elements. Will need the model of your Range to ID the correct element and the cost.
Now as for the rest of the burners on the stovetop not working, they are usually independent from the oven functions, which are wired into the controller in the center of the range control console, but there are a couple of GE models that wired the stove burners into the oven timer/controller. If this is the case, then you may also need to replace the oven timer/controller.
If the stove elements are independent and are only wired to the Infinite switches that control the front left, rear left, front right, rear right burners, than the problem is either with the actual radiant heat burner elements or the infinite switches that independently control each burner. I would still need a model number for the Range to help you more with this.
Hope this is of some help.
Dave
Dec 01, 2014 | GE Stove / Oven / RanMain Top Assembly...
I have a Frigidai #RG35HW*1 , the oven won't come on, not on bake, broil, preheat, nothing. But everything else works, the burners, the light, the clock/timmer. Just not the oven. Is it something simple...
evene thought he clock timer is functioning it may still be bad and not operate the oven or broiler.this should be replaced they can cost up to 140.00 dollars.also check to make sure that the elements are good if they are good then they clocktimer does need to be replaced
Feb 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven lights, but temp does not get above 100
The gas burner is broken. There is an upper burner and a lower burner. In-order for both burners to turn on, both must be working to let the gas turn on. If one burner element is out the oven wont get hot just warm.
Apr 29, 2009 | Maytag 30" Self-Cleaning Slide-In Gas...
Self-clean not cleaning
I was wrong (I think).  the baking element probably was burnt out as the repairman said.  He replaced it and I thought selfclean still wasn't working.  In fact, I think I just had to give the self-clean function more time.  Also, I was judging by smell.  We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair.  Bottom line, the oven was clean after the baking element was replaced, sans smell.
Apr 19, 2008 | GE Profile JTP18 Electric Single Oven
Frigidaire electric stove keeps beeping
IF IT HAS A MECHANICAL CLOCK, THE START AND STOP TIMES NEED TO BE SET, THE OVEN CONTROL SET TO CLEAN, AND THE SELECTOR SWITCH SET TO CLEAN.
TO CLEAN NOW SET START TIME TO THE TIME ON THE CLOCK AND THE STOP TIME TO 3 HOURS LATER.
LOCK THE DOOR. IT SHOULD START AND THE CLEAN LIGHT SHOULD ILLUMINATE, OR OVEN ON LAMP SHOULD LIGHT.
IF IT STILL DOESN'T WORK, THERE IS A PROBLEM WITH THE CLOCK OR THE CONTROLS OR THE LOCK ASSEMBLY.
A WIRING DIAGRAM WOULD BE BEST FOR DIAGNOSING THE PROBLEM.
Feb 20, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Problem w/burners & lights after self clean
You may want to re-seat the right two cooking elements, in case there is poor electrical contact. When you have them removed, clean the contacts with denatured 91% alcohol and a Q-tip. The removal procedure follows.
First, unplug the range.
LIFT–UP PORCELAIN COOKTOP
To lift:  When cool, grasp the cooktop front
edge.  Gently lift up until the two support rods
snap into place.
To lower:  Hold the cooktop front edge and
carefully push back on each support rod to
release.  Then lower the top into place.
COIL ELEMENTS
➢When an element is on, it will cycle on
and off to maintain the heat setting.
➢Coil elements are self-cleaning. Do not
immerse in water.
To remove:  When cool, raise element.  Carefully pull out and away from receptacle.
Check them for damage. They do wear out.
To replace:  Insert element terminals into receptacle.  Guide the element into place. Press down on the outer edge of element until it sits level on drip bowl.
COIL ELEMENT SURFACE
➢ On Canadian models, the two front elements will not operate during self-clean.To prevent the risk of electric shock or fire, never line drip bowls with aluminum foil.
If that does work, you may have a faulty control panel. In that case, call Maytag at the number below.
Maytag Customer Service
533 Benson Road
Benton Harbor,MI 49022
(800)688-9900 U.S.
(800)688-2002 Canada
Dec 03, 2007 | Maytag MER6772 Gemini Electric Kitchen...
After self cleaning, Range trips circuit breaker when using convection
self cleaning ovens use super hot seting to bake the oven clean and it sounds like it melted a wire and it is shorting out the oven on that setting. look at the wires you can see or easy to remove panels
Dec 22, 2006 | GE Profile JGS968 Gas Kitchen Range
Kitchen Ranges Logo
37 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
