Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
No power I unplugged my TV to do a power cycle. When I plugged the TV back on nothing happen. I don't even get the standby red light on. Sony said I need to take it to a repairt shop. At the repair shop I was told that it could be the lamp and they have a 3-week wait. To me it sounded like a load of cr**. I thought that if the lamp was burned, I should at least get some power to the TV, but I get nothing. I removed the lamp myself, inspectioned it and it looks fine. I think it is the power supply unit. Shouldn't there be a circuit breaker somewhere inside? Does anybody have any suggestion?
  • Paolo Catasti Aug 05, 2007
    That's a good suggestion. Thank you.
    I am just wondering whether I want to go through the pain of removing the back panel to chase the AP power cord all they way to the fuse... But it could be fun!
  • alfie30 Feb 26, 2008
    The Sony just went black. We found the surge bar light was out. We checked to find the bar was defective. We replaced it with a new one but still no power. The cable light does come on when we press the power button on the remote, but it does not turn on the TV.
  • 398 Answers
I agree with you, because if the lamp is bad then the set will still try turning on and the red light will come on in front. There is no circuit breaker but there is a small glass fuse. Follow the AC power cord and where it connects into the power supply board there should be a glass fuse. You can try replacing that fuse but if that does not fix it then have the set serviced by a different shop.
Posted on Aug 05, 2007
6ya staff
SOURCE:
I have a 55” RCA tv that I just replaced the t-con board on, now I can not get it to turn on. I have the red standby light then I’ll hit the power button on the side and nothing will happen I can’t even...
Make certain you got the right T-Con board for the job. And check the connections of the board. You might have pulled out a plug by mistake or not fitted one back. It's easily done!
Aug 24, 2018 | RCA Televison & Video
Hi I have a Sony fwd-50px1. It's plugged into the wall and without hitting the power on the TV the red standby light is on, as it should be. Now I press power on the TV itself and nothing happens. No...
Try unplugging and plugging the tv back in. Could also be a problem with the power button itself. Make sure the membrane contacts are clean and that the membrane is making contact with the contacts.
Dec 10, 2013 | Televison & Video
Sony KL-50W2U rear projection TV stuck in standby
Try holding down the power button until it turns off and then turn it on again.
Nov 29, 2012 | Sony KL-50W2U
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Standby light flashes but tv will not turn on
Ur high voltage is dying.The block of plastic with a red wire with a cap hook to ur CRT(tv tube).The FBT,it call the Flyback transformer,that is dying.That must be replace.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
AKAI LCT3201AD
Find and replace the following caps, Ec18, 19, 20 / 1000uf/16v,
Ec9, 10 / 1000uf/35v, Ec14, 25 / 470uf/35v should resolve the problem. You can get the caps at almost any electronics supply.
This is a common problem in this unit.
Good Luck!
Happy Thanksgiving!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
[email protected]
Nov 27, 2008 | Akai LCT2715 27 in. LCD Television
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to [email protected]
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
55 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
