Question about Symbol SPT 1800 Handheld
Infinite Calibration Loop
Upon the initial setup, during the calibration screen, the device is asking me to "Use stylus to tap center of target." But is only showing me the top left, and then the top right in a cyclical order, never completing the calibration. Any assistance would be greatly appreciated.
Htc prophet touch screen issue
for window phones
1. Press the "Home" key and press "Start." Use the directional pad to highlight "Settings," then press the center or "Enter" button.
2. Use the directional pad to select the System tab. Select "Screen," then press the center or "Enter" button. Select "Align Screen."
3. Using your smartphone's stylus, tap the crosshairs as they appear on your screen. Do this for as many as appear, until the calibration tool finishes. Your screen is now properly calibrated.
for Android phone
4. Press the "Home" button or capacitive area, then press "Menu." Tap "Settings."
5. Tap "Language and keyboard." Tap "Keyboard settings." Tap "Tutorial" and go through the steps that appear on your screen.
6. Once this is finished, turn your phone off and on again. Your keyboard has been adjusted, which activates a re-calibration of the capacitive touchscreen. (Capacitive screens are technically far more accurate that resistive, and so a full calibration tool is not included with Android phones.)
Aug 20, 2012 | imate JAMin Smartphone
Its saying calibration problem on the screen
When the Reader device is started for the first time or is reset back to factory settings, the screen must be calibrated. The Reader device will display a calibration screen that requires you to touch the stylus to the center of an "X" at several points on the screen. This is to make sure the touch screen properly recognizes input.
The process requires you to touch the "X" in the following locations on the screen:
  • Top left
  • Bottom right
  • Top right
  • Center
If the screen is accidentally touched someplace other than the center of the "X" during calibration, the Reader device will display a message stating Calibration error detected. Please restart calibration process .
If this happens, please start again in the top left corner and touch the stylus to the center of each "X" as it is displayed, being careful not to touch any other part of the screen. After the sequence is completed the Reader device will display Touch Panel calibration completed . Click OK to continue to the next step in the setup process.
Dec 26, 2010 | Sony Reader Touch PRS-600
HOW CAN DO PHONE CALIBRATION?
Over the time, the touchscreen might have to recalibrate for better touch precision. If you press 1 but it activates 2 in the To calibrate Nokia 5800 touchscreen: Click the menu key > Settings > Phone > Touch Input > Touch screen calibration. There you are prompted to tap centre of target with stylus, where the 4 circles (target) at the corner animates one by one to guide user complete the touch screen calibration process.
May 05, 2010 | Nokia 5800 XpressMusic Smartphone
Reader 6oo Touch : calibration error detected.
This error indicates that an issue occurred during the calibration procedure. Follow this procedure to resolve this issue.
1. Using the stylus, tap the "X" to restart the calibration process.
2. Tap the center of each "X" that appears on the screen.
3. When "Touch Panel calibration completed" is displayed, click "OK".
After performing the above steps, the issue should be resolved.
If the issue still persists, perform a soft reset. To soft reset the Reader, press the RESET button using a sharp-pointed object.
If unfortunately the issue still didn't resolve, service of the Reader may require. Follow the below link to initiate the repair: http://eservice.sony.com
Feb 04, 2010 | Sony E-reader Portable E-book MP3 Player
600 soft touch e-reader says it needs calibrating? what does this mean
This error indicates that an issue occurred during the calibration procedure or the Touch screen doesn't function properly. Follow this procedure to resolve this issue.
1. Using the stylus, tap the "X" to restart the calibration process. 2. Tap the center of each "X" that appears on the screen. 3. When "Touch Panel calibration completed" is displayed, click "OK".
Feb 03, 2010 | Sony E-reader Portable E-book MP3 Player
Calibration error - reader won't install on windows vista 32 bit
Dec 29, 2009 | Sony E-reader Portable E-book MP3 Player
Calibration error detected, the reader will not repond to stylus tap
you get this message if you click anywhere but the target. The target is the letter X on the screen
Dec 29, 2009 | Sony Reader Touch PRS-600
Recalibrate process
Dec 25, 2009 | Sony Reader Touch PRS-600
Screen Calibration
Check for protective film/screen debris build-up around edges.
Check for loose cabling plugs into the back of the Screen
Unscrew the four little fascia screws & lift panel out.
I had same problem after unable to enter password.
Did Hard reset, encountered the stylus calibration cycling error.
One of my screen cables had come adrift slightly at one corner.
Jul 29, 2008 | Sony CLIE PEG-N760C Handheld
Calibration of my MobilePro off
We've put together some useful tips on calibrating your MobilePro * When calibrating your touch screen be sure to use the same amount of pressure that you apply during normal use. In general, the lighter the better. This allows the screen to recognize taps consistently. * When calibrating your touch screen hold the stylus over the calibration point until it moves to the next point. Holding it for this period will lead to greater accuracy than just tapping the spot quickly. * When calibrating your touch screen support the screen from the back with your other hand. Try not to grasp the screen from the side with your thumb on the front. * When calibrating your touch screen do not let anything other that the stylus accidentally touch the screen. For example, don't rest part of your hand on the screen to help steady the stylus. * Once you've completed the stylus calibration, be sure to perform the double tap calibration as well. This will ensure greater accuracy.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Symbol SPT 1800 Handheld Logo
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
