Question about Toro Garden
Negative battery cable
I can't see where the negative cable was on my toro rider
    Problem Solver:
  • 8 Answers
Should go to the engine block
Posted on Jun 18, 2014
Belt diagram
HOPE THIS HELPS.. http://www.toro.com/en-us/parts/Pages/PartsDetails.aspx?mybeid=34870&serialNumber=310000001&modelNumber=74366&searchTerm=9lzIRv+p5zeMaPWIo2YCaldb2KV6U4WnyxmRpPSpeQehTowzmaCEK/baRX71tPfJ&defaultTab=parts
Apr 23, 2014 | Toro Zero Turn Rider 74366 Lawn Mower...
New rider just got a 2009 vulcan 900 custom started up 5 to 6 times, the next morning not even a sound. recharged battery nothing, had battery ck-out Auto disc its good all light gose on except headlight....
Sounds like the Negative ground has been lost. Verify by jumper-cable between battery negative (-) and any bare metal on the engine. Does turn-signals and horn work ? (Like the starter motor, they both require good grounding)
Feb 27, 2014 | Motorcycles
Replace ignition switch
1. Remove seat.
Always disconnect the negative cable first. If the positive
cable should contact ground with the negative cable
installed, the resulting sparks may cause a battery explosion
which could result in serious injury.
2. Disconnect battery cables, negative cable first.
3. Unscrew ignition/light lock ring. Push switch back through hole.
4. Cut switch wires approximately 3.0 in. (76 mm) from switch body. The new switch must be spliced into existing wiring harness using splice connectors.
5. After splicing new switch into wire harness, place switch into position. The word "TOP" is marked on the top of the switch body to allow for proper positioning of switch. 6. Install lock ring to secure switch in place.
Feb 12, 2014 | 2002 Harley Davidson FXDL Dyna Low Rider
How to replace ignition switch 2002 dyna low rider ?
1. Remove seat.
1WARNING
To avoid accidental start-up of vehicle and possible personal
injury, disconnect the battery cables before proceeding.
Inadequate safety precautions could result in
death or serious injury.
WARNING
Always disconnect the negative cable first. If the positive cable should contact ground with the negative cable installed, the resulting sparks may cause a battery explosion which could result in death or serious injury.
Apr 18, 2012 | 2002 Harley Davidson FXDL Dyna Low Rider
Toro 38" Locked up?
on the bottom of the engine there is a bolt but if there was little to no oil they will not warr it most shops don't rebuild anymore the just replace the whole engine where is it you live?
Apr 07, 2012 | Toro Zero Turn Rider 74366 Lawn Mower...
How to change the starter on a 1997 dyna low rider
Disconnect the negative battery cable. Drain the primary case. Remove the primary cover and take the bolt out of the jackshaft and remove it. There is a coupling between the starter motor and the jackshaft. It should not come out with the jackshaft but when you take the starter out, it will come out with it. Remember, the counterbored end goes towards the jackshaft. Put the coupling on the starter before installing it on the bike. On the right side of the bike, you'll probably have to remove some or all of the exhaust system. Take anything else off that may be in your way. Take the battery cable and the single wire that goes to the solenoid off of the starter and remove the two large socket head bolts that holds the starter on.
Good Luck
Steve
Jun 29, 2011 | 2001 Harley Davidson FXDL Dyna Low Rider
Less than a year old, just clicks, battery fully charged
Check your starter solinoid, it probably needs replacment.
When they are defective they will make the noise you described
Free Answer...Please Rate Me
Apr 16, 2011 | Toro Zero Turn Rider 74366 Lawn Mower...
Remove battery from 2002 dyna
The Dyna battery can be removed by:
1. Remove the seat.
2. Remove negative connection at frame, and positive connection at battery.
3. Remove the lower rear bolt. (left side of battery box at frame upright)
4. Remove the upper rear bolt, and swing down the battery box.
5. Remove the top cover, nad side cover.
6. Lift battery out, and remove negative cable from battery.
Feb 05, 2011 | 2002 Harley Davidson FXDL Dyna Low Rider
How do i take off the battery cover
1. Remove the seat.
4. Remove hte upper rear bolt, and swing down the battery box.
5. Remove the top cover, and side cover.
Jan 17, 2011 | 2001 Harley Davidson FXDL Dyna Low Rider
Garden Logo
14 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
