Question about Konica Minolta Bizhub 600 750 Image Control Board 57aa-9016g
Bizhub 600 reads wrong paper size in tray 1
Indicates 5.5x 8.5 paper in tray 1
  • Konica Minolta Master
  • 6,161 Answers
Is tray 2 OK?
Any paper stuck behind the draw. Check the setting off draw one in user mode is it for that size paper?
Posted on Jan 01, 2015
How to fix ? the tray 1 tray 2 appear question mark on bizhub 750
That indicates the copier does not under stand the paper size in those draws so check the guide that hold the paper. ensure they are snug up against the paper also check that there is no paper stuck behind those draw preventing the sensors from reading the correct paper size.
Apr 28, 2014 | Konica Minolta Office Equipment & Supplies
By pass tray on bizhub 250 only detects letter when i place an A4 paper, how do i make it detect A4
Clean the paper size sensor and change the by pass paper tray size setting on the display "Paper tray change" setting mode.
Mar 16, 2013 | Konica Minolta bizhub 250 All-In-One Laser...
My office has the bizhub c360, and when I put paper into the bypass tray, it prints from the main tray instead of the bypass tray. The settings on the printer are for bypass tray, the settings for my...
Hi the machine could be defaulted to print from the main trays if you have the same type paper being fed from the manual feed same size paper then it will automatically take it from the default trays
IF you take the paper out of the trays and put it only in the manual feed will it print and take it from the manual feed also you have to tell the machine when you use the manual feed what size and type of paper is in the manual feed once you tell it what paper and type of paper like card stock you then need to make sure when you go to print that it is set on your computer with manual feed and type of paper must match what is set on machine
Mar 09, 2011 | Konica Minolta Bizhub 222 Black and White...
My bizhub 600 is pulling from the wrong paper tray. It should default to tray 1, but is pulling from tray 2.
1) push Utility/counter
2) system settings
3) paper tray setting
On the right side you'll see the trays. Highlight the tray and press the up button
Mar 02, 2010 | Konica Minolta bizhub C351 All-In-One...
Machine will not work, it says 'direction for this OHP size is not supported. Please change to direction or set size larger than A4'.
Are you talking about the bypass tray? Or Tray#,1, #2, #3?
Check the trays and make sure the guides are tight to the paper.
Make sure the paper sizes are registering correctly.
push the utility button on the panel, then user setting, initial setting then factory setting, then press ok, then exit out.
Also in the user setting if you press the paper setting make sure that it's set to plain paper.
Dec 08, 2009 | Konica Minolta bizhub C250 All-In-One...
Can I print onto 5-1/2 x 14" paper
minumum size for the bypass is 3.5x5.5 and max is 11x17
minimum, for the paper trays is 5.75x8.25 and the max is11.5x16.5
so it should run 5.5x14 in the bypass tray
1 load the paper in the bypass tray
2 in the basics screen touch paper
3 select the button for the bypass tray
4 touch change setting
5 select custom size and program the size
Nov 17, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Wrong size paper jams
Take a trip into the Printer Driver for this printer and then select "Printer Properties"
Review the settings for the paper setup. Also, from your application, make sure you have "Letter" set as the desired page size.
Finally, if your printer has a "Paper Menu" go into that and set tray size to Letter.
Don
Oct 21, 2009 | Ricoh Aficio AP610N Laser Printer
Printing envelopes
1. Load the envelope paper into the bypass tray.
2. From the Copy Screen on the operation panel, select Paper.
3. Select the bypass tray.
4. Select Change Tray settings.
5. Select Normal for the paper type (do not select Envelope for paper type).
6. Select Custom size.
7. Enter the envelope size.
8. Select OK three times to return to the copy screen.
Jun 29, 2009 | Minolta bizhub 200 All-In-One Printer
BizHub 450 Universal tray won't pick up paper
Sounds like either a loose drive connection or there is some trace piece of paper still left in the device.
BNe sure not to overload or UNDERload the tray as well.
Aug 25, 2008 | Konica Minolta bizhub C450P Laser Printer
Cannot print from Tray 1 in Gestetner 6002
First make sure that the machine is reading/ seeing the paper size of the paper that is in the tray ( select tray 1 from the touch screen and see what the paper size reads). If the machine sees a different size then that in the tray, use the 'user tools' and change the paper for that tray. Also, go into your printer settings on/in your computer and make sure that the proper paper size is selected ( the size that is in the tray you want to print from). If the orientation of the paper size is different from the tray -- will not print and give you the error.
May 06, 2008 | Gestetner - 6002 Digital Imaging System...
Konica Minolta Bizhub 600 750 Image Control Board 57aa-9016g Logo
166 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
