Question about Samsung Weather Resistant Security Camera SSC-12C
Ssc21web samsung monitor
IC201S is defective/We have svc manual/It isn't listed .Other IC's are. It has a paper label on it. We assume it was adapted for this particular use. Can we get one?
    Top Expert:
  • Samsung Master
  • 37,945 Answers
You would have to refer this matter to Samsung directly
Posted on Apr 23, 2013
2 Suggested Answers
SOURCE: SAMSUNG SSC21WEB
If it is the same year as mine you can change the settings through the ssc21web system instead of the recorder-have you tried that yet? The ssc21web system has the ability to be set to view the input from the cameras. There are many options- motion detect, quad, single, it will switch from single to quad intermittently, etc. Maybe your settings were changed on the ssc21web and not your recording devise-check that first, then go back to the ssc1280.
Posted on Jul 23, 2010
Acer flat screen monitor
acer monitor v193hqv power supply regulater ic burn so iwant circuit or ic no part no ic 802 problem plse solution
May 03, 2013 | Acer S202HL LCD Monitor
Paper jam in Toshiba Tec
Check length of label and type of sensor used and check the sensors
Apr 02, 2013 | Toshiba TEC B-472 Thermal Label Printer
I need the remote code for the Samsung Syncmaster monitir, please
If you have a "universal" remote, it will scan for the number, or it could be listed in the manual that came with the remote. If it doesn't list Samsung monitors, try Samsung TV's. If you have the nanual for your monitor, it will be in there, too. Also, check Samsung's own site to download the proper manual and/or the codes. In the meantime, try these 2-digit codes from the manual for my Samsung Blueray system, assuming of course, your monitor uses 2-digits -- which does seem to be a standard convention. I also suspect manufactures only have a certain block of codes they use for all their remotes. 00, 15, 16, 17, 40, 43, 46, 47, 48, 49, 59, 60, or 98
Jan 23, 2013 | Samsung SyncMaster 710m 17" LCD Monitor
Hi, I have a Mackie MR8 that isn't putting out sound anymore.
I assume that you switched L and R monitors to verify the problem and so I would say that you have a amplifier failure issue. Knowing Mackie, they're probably using an output IC for amplication which although it took some time, has now completely died.
Me being an old-timer I can honestly say....Oh how I miss the discrete transistor and "thru-hole" component mounting days.
Oct 24, 2012 | Mackie Mr8 Active 8" Powered Studio...
What's your problem?
First, make sure this isn't coming from your signal source; these items are not listed in any of the functions described in the manual for your monitor.
If disconnecting, changing or turning off your signal source doesn't get rid of the control item display, try resetting the monitor (maybe the display has some extra firmware features not in the documentation):
  1. Press the Menu button on the side of the monitor.
  2. From the On-Screen Display, navigate to the Setup&Reset menu using the arrow buttons, then press the Source/Select button.
  3. Navigate to "Reset" and select it.
This should restore everything to the factory default setting and get the TV/monitor out of whatever mode it's in.
Dec 03, 2011 | Samsung 23IN Led 1920X1080 5M1 PX2370 Dvi...
Somebody has changed my password & now I can't reset
You can manually reset the router, there should be a small switch on the router labeled "reset". the routers password will be reset to the default. if there isn't a reset button the manual that came with your router should list another way to reset the router.
Jun 16, 2011 | Computers & Internet
When trying to print getting error Paper Jam in Manual Feeder. There is no Jam...we tap the side of the machine and it prints....any Ideas on what causes this to happen?
There is likely a loose connection going to the manual feed paper sensor.
The printer thinks there's paper in the manual feed, but of course since there isn't any paper there, when it tries to feed the paper in from the manual feed, the next paper sensor is not tripped, so it assumes there is a jam in the manual feed.
Start testing at the manual feed sensor, and work your way back to the board it connects to.
It may be the sensor itself just needs to be cleaned - these sensors are usually optical, and spraying canned air at it will often fix it up.
Also, make sure the lever that trips the sensor isn't sticking after using the manual feed.
Apr 11, 2011 | Samsung SCX4623F Laser All-in-One Printer
Need Synmaster 216bw driver
Here is the driver download from SAMSUNG website
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_cd=&prd_mdl_name=216BW&prd_ia_sub_class_cd=P
Just click on the driver, it is the same one as you listed '20070515103345609_SM223BW'
No need to uninstall the old driver, all the driver doese si to allow you to set the resolution that is not listed in the microsoft video resolution lists.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 29, 2010 | Samsung SyncMaster 216BW Monitor
Can't load paper in a TI-5032 SVC
I found the manual that explained how to load the paper. I do not need any future assistance. Delete my request for help! Thanks -
Nov 30, 2009 | Texas Instruments TI-5032 SVC Calculator
SAMSUNG SSC21WEB
It's a quad. It records all 4 cameras at the same time. You can display 1 cam at a time. If you play it back, you have to hit the buttong that displays the corresponding camera you want to review.
Nov 06, 2008 | Samsung Weather Resistant Security Camera...
Samsung Weather Resistant Security Camera SSC-12C Logo
51 people viewed this question
Top Samsung Home Security Experts
Heilcode
Level 1 Expert
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
