Question about Garden
Mtd central park
I need a belt cant find one
  • 7,482 Answers
Hi richey
Try
jackssmallengine.com
Posted on Apr 24, 2013
What is the part number for the 42inch deck belt for yard machine 17.5 hp
MTD uses many, many, many different belts. You will need the model and serial number located under the seat. Usually starts with 13A. Any MTD dealer can find the proper belt for you with those numbers. I definitely recommend the use of proper MTD belts. Automotive belts have a different V shape and will fail prematurely.
Sep 01, 2014 | Garden
My 95 yard machine stays engaged in gear while pushed in or even in park
Outdoor Power Equipment Parts Use the Part Finder Tool from MTD and it will, the variable pulleys and belts need to be uncoupled, maybe try depressing the pedal a little (ON FLAT GROUND) park brake disengaged.
Aug 05, 2013 | Yard Machines MTD Gold 185 HP Lawn Tractor...
My mtd yard machine riding mower wont stop. it also goes when the parking brake is on, What should i look for?
belts may need replacedd, make sure all belt guides are in place, may have to adjust brake linkage
Sep 04, 2011 | Mtd Garden
Can i have a mtd pro 800 series drive belt diagram please
Cant find the diagram without more info but if you go to the link I have here and enter your model and serial number it will supply you a manual and it will be there. If you need further help please contact me. thank you.http://manuals.mtdproducts.com/mtd/Public.do
Jun 07, 2011 | Mtd Drive Belt 42"
I need help fitting the blade belt to my MTD RH125/92 can you help i cant find the manual anywhere
This can be a tricky job. There is two 180 degree twists when fitting the belt. Viewing the deck from behiend, looking toward the front, run the belt coming from the engine around the left blade pully. Twist the belt 180 and run it at an angle to the front of the right blade pully, this is to drive the blades in opposite directions. Coming off the back of the right pully go around the tensioner pully and between the tensioner and the engine pully make another 180 degree twist. I have fitted a few of these and i have a diagram here in front of me but i cant find a way to show it to you. Hope this helps. Stephen.
Sep 14, 2009 | Mtd Garden
Need instructions to replace main drive & transmission belts. Mower will not go forward or backwards. MTD model # 13AN601H729
Before you go trying to replace the belts, did you shut it down the last time you used it while the transmission was in a HIGH range?
If you did, restart it, put your speed lever back in the same or higher position with the F& R shifter in neutral, let out on the clutch/brake pedal until it takes up the slack, then pull the speed lever back into lowest speed, push in the clutch/brake and put it in PARK. Shut of the engine and then restart, it should be back to normal operation now
Sep 07, 2009 | Mtd Garden
How do I know if installed the v-belt properly for an MTD 22" self-propelled mower #12b-264c062. The belt has been installed around the engine and transmission pulleys and behind the belt keeper. does...
You need to check the owners manual. And be sure you have the correct belt.
You can download a manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
Jul 31, 2009 | Arnold Corporation Arnold/MTD 22" Lawn...
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
