Question about Body Solid Series 7 Smith Home Gym Package w 300 lb Weight Set GS348QP4
Body solid smith machine replacement cable weight equipment
Cable snapped.. but i'm not certain if this is the equipment we own. can't find a model number. it's an older piece for sure.
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: got cables connected on gym but number one weight
If the top plate is just hovering and you cannot adjust it out. For a while you may have to push the top plate down and engage the selector pin and with use the cable will stretch on its own with usage. Since these are a series of cables it would be difficult to pinpoint which cable is causing this problem. If you want to remedy this call Body Solid and have them send you a new set of cables.
Posted on Jun 11, 2010
How to replace cable on nautilus nt-cc1
Did you ever figure this out? I ordered the replacement cable, but can't figure out how to get it replaced.
Mar 26, 2013 | Nautilus Smith Machine
Broken cables and counterweights
Call Techmotion 877-805-1030. We can get you fixed up.
Oct 03, 2012 | Body Solid Counter Balanced Smith Machine
What are the parts of a pulley?
It is a fiber circular component with a center V- groove and uses a 6202 sealed bearings that the cable travels when utilizing the machine. The Upgrade is a complete replacement of all pulleys in the unit with aluminum pulleys
Jul 19, 2010 | Body Solid Aluminum Pulley Upgrade Kit for...
Got cables connected on gym but number one weight is still not sitting of top of the oher weights it up a lil bit on body solid home gym 1500s
Jun 09, 2010 | Body Solid Bodysolid Exm1500s Home Gym - ...
I need to move my body solid G4I to another room,
first disassemble the chest press then tie wrap the cable to frame. pull the weight stack off then tie wrap weight stack cable then remove rear base all away to where the front seat is attached now you should be maneuver to the other room
May 13, 2010 | Body Solid G4I Iso-Flex Home Gym
Hi the weight plates get struck when i am doing workout when I put on 2 weight plate and when I do heavier weight it feel i like not smooth. I notice that the weight plate is little side way when I pull...
I would the entire sequence of pulleys that lead from the lat/chest press cable to the weight stack itself to see if any of the pulley are dragging or the cable is snared. Another thing I would look for is that top plate selector pole is straight . I would loosen the allen bolt 8mm put the selector pin in one lower plate holes then tighten the bolt. If that solve the problem I take the weight stack apart and inspect the bushing for burrs that may be causing the drag.
May 10, 2010 | Body Solid Body-Solid Fusion 500 Personal...
The weight plate get struck when i doing workout when on the 2 plates and when doing working with more plates it fell like not smooth. is the main cable problem cause it more shorter
Need assembly manual Body Solid PSM1442XS
Here is the body solid website you can access manual that you need
http://bodysolid.com/Support/Assembly_Manuals.cfm
Apr 15, 2010 | Body Solid Powerline PSM1442XS Smith...
Saftey rules
There is a risk assumed by all individuals who use this type of equipment. To minimize risk, you must follow these rules:1. Inspect equipment before each workout. Check that all nuts, bolts, screws and pop pins are in place and fully tightened. Also, before use, check cables for signs of wear. Replace all worn parts immediately. Never use machine if any parts are damaged or missing. FAILURE TO FOLLOW THESE RULES MAY RESULT IN SERIOUS INJURY. 2. Keep clear of cables and all moving parts when the machine is in use. 3.Always make sure all Snap Links are closed when doing any cable/pulley/strap exercises. 4. Exercise with care. Perform your exercises at a smooth moderate pace; never perform jerky or uncoordinated movements that may cause injury. 5. It is recommended that you should workout with a training partner. 6. Do not allow children or minors to play on or around this equipment. If unsure of proper use of equipment, call your local Body-Solid distributor or the Body-Solid customer service department at 1-800-556-3113. 8. ARNING: Consult your physician before starting your exercise program. For your own safety, do not begin any exercise program without proper instruction. Including maintaining the equipment the owner’s responsibility is also to: 1. Be sure to always provide adequate supervision to all end-users. 2. Be sure to instruct all end-users of proper usage. 3. Be sure all supervisors and personal trainers who instruct end-users on equipment use are properly trained and know the function and importance of every adjustment and setting. Also, be sure these trainers provide proper instruction to end-users on the fundamentals of strength training.
Dec 01, 2008 | Body Solid Cam Series Ab/Back Machine
Body Solid Series 7 Smith Home Gym Package w 300 lb Weight Set GS348QP4 Logo
51 people viewed this question
Top Body Solid Exercise & Fitness Experts
Howard
Howard
John
Tom Chichester
Are you a Body Solid Exercise and Fitnes Expert? Answer questions, earn points and help others
