Question about Sportcraft Replacement Treadmill Round Safety Key
What is code E3 on a sportcraft threadmill TX335
Error message E02 on Reebok ZR8 Threadmill - please help if possible
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 01, 2016 | Exercise & Fitness
Sportcraft tx 2.5 shows code 3 and stops after a few seconds of running time.
If you wish to get some details treadmill repair and error code ; check the site linked here. Pull up older posts.
Sep 07, 2016 | Sportcraft Exercise & Fitness
Fix E3 error message
see your troubleshooting section in your instr. manual and enter the keys for clear the error.
However you must test:
a) test the input voltage motor, if there are the motor need repair.
b) test the output voltage board, for input voltage motor, if there are NOT the board is faulty., see the block diagram+ w.diagram
Nov 26, 2012 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
The threadmill stops when i step on the decke. Why?
1) this hapeen has a protection to the electronic system, the machine keep safe the electronic soft and hardware.producing a shut down.
Lube the DECK BELT, inmediately.
2) LUBE the rollers bearing too very well
3) TEST the input voltage motor, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Sep 03, 2012 | Sportcraft Tx 4.9 Model 4041 B Walking...
`convert threadmill from kilometer to miles on a freespirit threadmill
Dear Sir:
Inspect the bottom of your treadmill console.
Use the pencil point. touch the hole(nano swithc) and ready. Of course you must disconnect the power before. After you reconnect it. And ready.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 13, 2012 | Bowflex Exercise & Fitness
I have a sportcraft treadmill tx335 it shows error 7 why and how do i fix it
Error code seven is due to the console getting locked. I called Sportcraft and they said to do this: Unplug the treadmill for five min and then re-plug the treadmill. Now push the ON/OFF switch to ON and insert the safety key. Now press the MODE and STOP button simultaneously. Without releasing the buttons take out the safety key and insert it again. Now you should hear a beep and the display will come on. Release MODE & STOP and now press the Speed increment (+) button
Oct 31, 2010 | Health & Beauty
Treadmill stops after 7 seconds
you have a broken spinner. Take hte motor cover off and look on the opposite side of the motor. there will be a partof the spinner wheel there. I have yet to find a way to short cirut the connectors nor a replacement wheel.
Feb 16, 2010 | RTO Image 15.0R Treadmill Walking Belt
Sportcraft TX 2.5 treadmill - error code 3 - stops after a few seconds of operation. ??? Thanks for any advice
Sorry I dont have the solution but I have the same problem.
Read somewhere that Sportcraft control boards had
a design flaw.
Jun 28, 2009 | Exercise & Fitness
Sportcraft Replacement Treadmill Round Safety Key Logo
21 people viewed this question
Top Sportcraft Exercise & Fitness Experts
John
Are you a Sportcraft Exercise and Fitnes Expert? Answer questions, earn points and help others
