Question about Dell VOSTRO 1015 T6570 21G 2GB 160GB DVDRW W7Hewlett Packard 1YR NBD (4685946) PC Desktop
Problem i tried to install the bios update which i downloade. when i tried to install it it warn me that this is not supportive but i tried to install it. after sometime there was green dialog box and my system died off. i tried to on it but only while pressing on bottom twice the blue light glow but does not give any respond. plz plz plz help me.
    Brigadier General:
  • Dell Master
  • 3,400 Answers
DON'T INSTALL A BIOS-UPDATE.WITH OUT A 100% CERTAINTY.
Posted on Apr 23, 2013
whitebirch
  • 433 Answers
SOURCE: [Ithr]checkpoint failure dell 8400 dimension
What can cause this error?
Well, this is the problem since quite a variety of problems can trigger the error.
1: the bios can be malfunctioning (a bios reset or flash can give a solution)
2: the cpu can be malfunctioning (this requires a new cpu)
3: the cpu socket can be failing (this requires a new mb)
4: the problem can be with bad usb sockets
5: even a bad uplink to a usb hub can cause this error to appear.
Did you change your monitor lately? I would chase down the USB things first...that and the monitor seem to trip the trigger...
Hope this get you started- I think you were right on target with the flash of the BIOS-try it again using the BIOS flash downloaded from the dell site...and to run the chipset again...it just might
Good luck my friend, hope this helps, please leave rating, thank you kindly
Posted on Apr 27, 2009
  • 8 Answers
SOURCE: giving green light and there is no display
disconnect the video cable that coonnects the motherboard and monitor...now switch on the monitor ..now a screen saver like video will come on monitor that says to connect the cable this means your motherboard has a prblem call the service center.. if not and still the monitor is on green light it means your display driver in your monitor would have got fried and your motherboard has no problem...
Posted on Apr 28, 2009
  • 118 Answers
SOURCE: I think I updated BIOS from Dell incorectly.
Sounds like the BIOS upgrade didn't take. Those beep codes are audible indicators that the motherboard has failed POST (Power On Self Test).
Here's is a list of the codes for your specific BIOS/PC:
http://support.dell.com/support/edocs/systems/dim4700/sm/adtshoot.htm#wp1052968
Posted on Sep 04, 2009
Cruxor
  • 94 Answers
SOURCE: Dell 8300 not loading xp home with the blue screen of death
To resolve this behavior, contact the manufacturer of your computer to obtain a BIOS that is fully ACPI compliant.
To work around this behavior, manually install the Standard PC hardware abstraction layer (HAL):
  1. Restart the computer to restart Setup.
  2. When Setup starts again, press F7 (not F6) when you see the "Press F6 if you need to install a third-party SCSI or RAID driver" screen.
Windows automatically disables the installation of the ACPI HAL and installs the Standard PC HAL.
Posted on Dec 30, 2009
tecnomage201
  • 221 Answers
SOURCE: dell 4700 bios a06 2.8 ghz 64 bit bus=800mhz
You have a rootkit virus, the only answer is reformat the drive and start fresh, sorry.
After a fresh install is done immediately install service(can be downloaded free from microsoft.com) pack 3, because sp2 is vulnerable to a host of trouble.
Posted on Apr 17, 2010
Bios update
How to Update Your BIOS
By Patrick Miller, PCWorld
  • Jan 21, 2010 6:00 PM
  • Check your BIOS version, without restarting your PC, by using msinfo32.exe (as described in the text).187437-versioncheck_original.jpgThe easiest way to find your BIOS version is to open up the System Information app in Windows--just type msinfo32 into the search bar (for Windows 7/Vista) or the Run box (XP), and clickSystem Summary; your BIOS version should now show up on the right under your processor speed. Record your version number (and the date that appears afterwards, if applicable).
    Step 2: Check your PC/motherboard manufacturer\'s Website for BIOS updates.
    Most PC manufacturers handle BIOS updates based on your specific line and model, so head over to your manufacturer\'s support page and check its listings for your PC, because if you download and install a BIOS intended for a different model, your PC probably won\'t work (although most BIOS updaters are smart enough to notice if you try to install them on the wrong hardware). If there is a BIOS update file available, grab it--along with any documentation it comes with, because often warnings and specific instructions are contained in the Read Me docs.
    Those of you who assembled your PC yourself will need to look for BIOS updates from your motherboard manufacturer\'s Website. If you don\'t remember your motherboard\'s model number, you can look it up without opening up the case by downloading and running CPU-Z and clicking on the Mainboard tab.
    Step 3: Read the included documentation.
    Your PC\'s BIOS handles a lot of the nuts and bolts ISO Recorder for Windows XP or the version for Windows 7/Vista) to create a BIOS update CD.Other systems will have you copy a few files to your bootable disk, restart, and open up the BIOS during startup (typically by pressing a specified key for setup options), and change the boot order so your system looks for a bootable USB drive or CD before loading the OS from your hard drive.
Dec 13, 2013 | Acer Q45t-am Motherboard Intel Q45 Ddr3...
To make a long story short: My Lattitude D800 has gone completely dead. Is there a way to restore the bios to the factory settings, or something like that? The longer version. Dell Lattitude D800,...
There was a BIOS download from Microsoft for the D800? Weird. Yes as you now know, only install BIOS versions released from the manufacturer themselves.
Well you can try removing the reserve battery, trying to power on to see if that resets it with the reserve battery out.
http://support.dell.com/support/edocs/systems/latd800/sm_en/reserve.htm#1123661
Is it allowing you to go into the existing BIOS at all? You could download the latest bios from Dell's site and try this. http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R103840&SystemID=LAT_PNT_PNT_D800&servicetag=&os=WW1&osl=en&deviceid=3582&devlib=0&typecnt=0&vercnt=3&catid=1&impid=-1&formatcnt=0&libid=1&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=133892
You will need a bootable DOS disk to boot to, and flash it.
Flashing the BIOS Dell™ Latitude™ D800 Service Manual 1. Ensure that the AC adapter is plugged in and that the main battery is installed properly. 2. Insert the flash BIOS update program floppy disk or CD and turn on the computer. Follow the instructions that appear on the screen. The computer continues to boot and updates the new BIOS. When the update is complete, the computer will automatically reboot. 3. Press during POST to enter the system setup program. 4. Press and to reset the computer defaults. 5. Press , select Save changes and reboot, and press to save configuration changes. 6. Remove the flash BIOS update program floppy disk or CD from the drive and restart the computer.
Jul 01, 2011 | Dell Latitude D800 Notebook
I'm trying to fix a friend's dell dimension 2350. On board sound is turned on in system bios. downloaded and downloaded and re-installed and re-installed windows xp pro. Updated and Updated and Updated...
Normal 0
You can download the drivers from Dell WEB site, the support download page. Make sure you select your model desktop or laptop, better still, type in the Service Tag number, it is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go into the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). This will open the page where the specific drivers for your model computer are located. Also make sure you select the Windows XP or Vista version of the drivers for your Windows operating system. Click on this link to download the drivers: -
http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Oct 07, 2010 | Dell Dimension 2350 PC Desktop
Why, when i try to install driver for vga card in a acer aspire L100 computer, the sistem is shuting down?
Hi
thank you for your query
Please can you try the following
1) go to www.devicedoctor.com
2) Download and install the device doctor software
3) Once installed open it up and click scan, it will then scan your PC for the best driver
4) Download the driver (entitled VGA driver) and install
5) Restart and see if this cured the issue
Regards
Shauqat
Jun 02, 2010 | Acer Aspire L100 PC Desktop
I have a dell 1525 laptop. It works fine except feor one problem. While I type, the cursor jumps all over the place and puts letters all over my document. It did this with both Vista & now XP. It does...
This is not a virus issue since you had already tried two version of windows.
First you can try to update the BIOS on your laptop by downloading the BIOS update from http://support.dell.com
Select the support for home users.
Drivers and downloads.
Enter the service tag of your laptop. ( even laptops w/o warranties can download updates)
Just download the BIOS update via browser only ( do not select download via download manager)
Just run or install the downloaded update (make sure ac adapter is plug-in and battery is at least 10% charge)
After the update check if still getting same problem. If yes then have you keyboard and palmrest replace.
Mar 31, 2010 | Dell Inspiron 1525 Laptop
ACPI Compliant
Don't worry check out on the net about this motherboard, put that serial number of the mother board on the site and download the BIOS drivers. update that BIOS by DOS prompt , problem will be solved
Jun 15, 2009 | Computers & Internet
I can't install XP on Thinkpad A20P #2629
im sorry to say this laptop is just not fast enuf to run windows XP you best bet for this would be to run windows 98 or a distro of linux that fits your needs  there are no bios updates at this time that will allow you to install XP on this system. sorry
Mar 27, 2009 | IBM ThinkPad A20 2629 Notebook
Abit NF8-V drivers (non-bios)
  • Bios Downloads
  • Bios Motherboard Update
  • Bios Updates
  • Bios Drivers
  • Vista Driver Update
  • DriverZone.com Driver Scan; Registry Scan; BIOS Update; CD/DVD-ROM Drives; Hard Drives; Infrared; Input; Modem; Monitor; Network; Other; PCMCIA ... All Drivers. Scan Computer For All Drivers Driver Updates
    Best of Luck ! Please dont for get to Vote.Thank You
    Dec 11, 2007 | Computers & Internet
    Update
    download the update software from the garmin website; http://www8.garmin.com/support/download.jsp then plug your GPS system(using the cable provided) into the computer with the software update on it and click the WebUpdater and it will walk you thru the procedures.
    Nov 14, 2007 | Tomtom GO 930T Car GPS Receiver
    Bios problem
    Please try replace a computer CMOS battery and boot computer in to your CD Utilites enclosed in the system. Or download and install the bios updates in the http://support.asus.com/download/download.aspx?SLanguage=en-us
    and try to repair manual on updating bios. the guideline on updating bios is here: http://www.cyberwalker.net/columns/oct00/121000.html
    If not solve the problems maybe u can replace your bios.
    Oct 24, 2007 | ASUS K8V-MX Motherboard
    Dell VOSTRO 1015 T6570 21G 2GB 160GB DVDRW W7Hewlett Packard 1YR NBD (4685946) PC Desktop Logo
    19 people viewed this question
    Alun Cox
