Question about Refrigerators
Amana SXD22S2W Side by Side not cooling - no frost on coils
Amana SXD22S2W Side by Side not cooling - no frost on evaporator coils behind panel in freezer section. I just paid a repair man to come tell me I have a leak, freon leak and for wat is would cost me to fix it, I could buy a dinged or dented one for $399 - $499. This fridge is 11 years old. Is he telling me the truth, in ref. to there being no frost on the coils and is that what I should do? the fan is blowig and he said he can hear the compressor running as well.
  • 478 Answers
He's right,sorry.
Posted on Mar 12, 2009
We've got the temp set at the highest setting (7) and the frig is only keeping things coolish. We just vacuumed and cleaned the coils in both the front and the back of the frig. What's our next...
if the inside rear freezer wall has frost on it then the evaporator coil is frozen up behind it,(remove the panel) and cool air cant blow over the coil,defrost it with a hair dryer then troubleshoot the defrost heater and thermostat both located on the coil as one of these is most likely bad
May 19, 2011 | Amana Side-By-Side Refrigerator 26 cu. ft....
How do I get access to the coils on an Amana model SXD22S2W,
on most refrigerators the plastic grill is a snap on most service tecks carry a long
brush that looks like a cats tail to clean the condenser coils a long bottle brush will also work but be gentle the tubing is metal the fan is normally located looking from the front back left corner if you have a plastic putty knife you can insert on top behind plastic close to the side and easily pop forward very few units are secured with screws ron
Dec 05, 2009 | Refrigerators
Runs but doesn't cool
An Amana SxS has 3 motors. The evaporator fan motor in the freezer (common failure in Amana's), condenser fan motor behind the cover on the bottom back of the machine, and lastly, the compressor itself.
If just one of these works, it could be claimed the machine is running.
If there is no frost built up on the rear panel of the freezer compartment (defrost system failure), and if both fans are running, and no frost exists on the back panel of the freezer compartment, then it would a problem with the compresser, and would need either a new start kit, or possibly a new compressor. This last part should be handled by a pro.
Oct 24, 2009 | Amana Refrigerators
Does not get cold
I'm not sure if you mean it's not getting cold enough or dot at all.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. If there is a lot of build up then the defrost timer may need to be replaced.
Most of the time the evaporator coils and fan are located behind panels in the freezer section. These are usually easy to remove. The defrost timer is a different story and may require the help of a service person.
Hope this helps.
Sep 14, 2009 | Frigidaire FRS26R4A Side by Side...
Fridge-side not cold enough
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Jul 29, 2009 | Hotpoint HSS25GDMWW Side by Side...
I have an Amana Side by Side. The freezer section
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the adaptive defrost control.Part 13 on this diagram of your fridge controls. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ASD2625KES&productCategoryId=0165000&brandId=1268&modelName=AMANA-REFRIGERATOR&diagramPageId=00005&componentDescription=CONTROLS&documentId=M0612301&backToLink=Return%20to%20Sub%20Components%20list
Is the evaporator fan in the freezer running.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2009 | Amana ASD2625KE Side by Side Refrigerator
Door open all day Amana SXD22S2w
the evaporator is clogged with frost, just as if the defrost heater went out. Two options, remove all food and leave ref unplugged and doors open for half a day, or remove the back wall(evaporator cover) and defrost it with a hair dryer.
Jun 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana fridge SRD27S4W 27CU.IN. 1995 S/S PARTIALLY COOLING
normal to have frost accumlulation, on the evaporator coil, not normal to see it coming thoughthe back panel, which is indictitive of defrost prblem, you can remove the back panel inside freezer compartment and look forthe thermostat( 2 wires leading to a round thermostat clipped onto the top coil of evap, simple to replace simply cut out old and wire in new one heres the part number R0161087
Nov 27, 2008 | Amana SXD524VW Side by Side Refrigerator
Refrigerator
It sounds like you found it. Change the defrost timer.
Jan 16, 2008 | Amana DLE330RAW Electric Dryer
Amana not cooling
Take the back cover off and look at the frost. If the frost is only at the bottom of the coils then you are low on R-12 or R-134 and the defrost t-stat is cutting out to quick. If the coils are well frosted then you have a bad t-stat.
Dec 09, 2007 | Refrigerators
Refrigerators Logo
401 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
