Question about Lands Phones
Gatehouse deadbolt
The dead bolt will not open when the user password is entered. I need technical support number the 1-877-4GATEHS is not working (rings busy. Need a alternate number.
4 Suggested Answers
spencerfield
  • 31 Answers
SOURCE: B362 605 KA4 DBL CYL DEADBOLT 4 EA 20536728: Gatehouse deadbolt 2 tears old.moves about 1/2 inc...
Remove, lubricate with a dry silicone or graphite lubricant and reinstall. The mounting bolts may have loosened up, and now it is not perfectly lined up. More likely is some corrossion or wear in the throw mechanism.
Posted on Oct 13, 2010
  • 3 Answers
SOURCE: brought new keyless dead bolt. Put it in a door
My lock adjusted itself automatically... You have to hold the lock button in (on the exterior side) while you insert the battery pack - the deadbolt will cycle in and out, then beep a couple times. You'll be holding button for maybe 10 seconds.
I have to say while this step is included in the instructions in a big red box, it says nothing about why or what its doing, so I imagine many people miss this...
Posted on Jul 07, 2013
  • 51535 Answers
SOURCE: cannot remove the gatehouse dead bolt to remove plunger
SORRY but we have no idea what you have or want nothing to do with a car or truck .
Posted on Oct 23, 2015
We have a gatehouse model # pl110s10 and are unable to program a code because we got rid of the box. Can you help us program a code?
the programming instructions are inside the battery cover. instead of Enter click the Gatehouse button in some cases. also, to actually USE the thing, you just enter your code and hit Gatehouse/enter to unlock, and just hit Gatehouse/enter to lock.
Mar 22, 2015 | Televison & Video
Have deadbolt lost template for install
Control of uncertainties is not possible because it's the natural truth. You can borrow deadbolt from the locksmith in san francisco or can hire them to fix it as well.
Nov 03, 2013 | Gatehouse Locks & Locksmithing
How to remove gatehouse door knob?
Look for a small set screw on the side of the deadbolt on the inside of the door loosen the set scrww and remove the cover to expose the screws that hold the door knob on
Oct 31, 2013 | Gatehouse Springfield Satin Nickel...
Shlage keypad dead bolt unlocks when you press the
Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial?
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.
To enable/disable this feature, enter your Programming Code--press the Schlage button--Press 7.
Each time you do this, you toggle between enabled and disabled.
Videos for installing and programming can be found on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Scroll down and find them under the heading Electronic Security--Keypad deadbolt 365
Aug 31, 2012 | Schlage Camelot Deadbolt Keypad, Satin...
When i try to lock or open with key pad it will make the sound like its closing but the bolt does not move. can only lock and open with key.
The deadbolt may very free inside the deadbolt hole... This system is low torque and a over torque clutch may slip if the dead bolt it's not completely free inside the deadbolt hole... Also, if you try to open the door before to unlock it, you may block the deadbolt... take care to unlock the door before open it. to be sure that the dead lock is ok, you can turn the manual knob and be sure is turning very very easily.
Also are you no that POWERBOLT is a 3 codes memory? go to that link to see more info about that : http://www.fixya.com/support/t8006865-not_overwrite_old_codes_just_keeps
Have a good lock
Have a good unlock
Jan 30, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
I have a weiser lock powerbolt 1000 and i just installed it and progammed it except the bolt wont lock unless the keys are in the door, if i type in the code with the keys in it works fine but when i...
Have a good lock
Have a good unlock
Sep 11, 2010 | Weiser Lock Powerbolt 1000 Lock
Brought new keyless dead bolt. Put it in a door that opens in with hinges on right side. The problem is that the motor wants to turn the dead bolt the opposite direction, unlock extends deadbolt,...
Aug 25, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
May 16, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
I have several ''gatehouse'' deadbolts and i can't get the core out in order to rekey them. how can i get it out or find instructions?
Here is a link to the manual for rekeying all Schlade/Gatehouse locks.(It's in PDF format)You can download,save,print,or view online.
Please take time to rate this fixya
May 14, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
