Question about Garden
Can an Eaton Model X778 -005 Hydrostatic drive unit be rebuilt.
I have a zero turn lawn mower which seems to loose drive in one direction and will eventually regain power in that direction in about 1 minute. Suspect Eaton Drive unit. Snapper cautions against checking hydraulic fluid level. Can the fluid resevoir be opened for checking the level of fluid or even the addition of fluid. Also what type should be added?
Thanks for any help.
Ken
  • thecapitanio May 16, 2009
    I have a snapper zero turn that looses power in the left hydro after 10 minutes. Took both hydros off machine and left has much less fluid than right. Can I add more? Do I have to bleed the air? What type and how much fluid.
    Please help
5 Suggested Answers
wilsodfarm
  • 986 Answers
SOURCE: What fluid do I use for Eaton hydrostatic
Hdy 46 fluid
Posted on Sep 05, 2009
  • 109 Answers
SOURCE: MTD PRO RIDING MOWER/LAWN TRACTOR 18 HP ENGINE HYDROSTATIC DRIVE
In the back of the mower...probably under the seat, there should be a lever to release the transmission, or it is on the back plate. As far as the noise when trying to move drive the mower, the brake in the back, next to the transmission is jammed, use a 1/2 inch wrench to loosen it maybe 1/4 turn and this should unlock the brakes
Posted on Apr 22, 2009
  • 85 Answers
SOURCE: checking fluid level
most units of this size & quality have a factory sealed transmission. to check or change oil, the transmission would have to be removed.
Posted on Sep 12, 2009
  • 3074 Answers
SOURCE: hi, i have an snapper riding lawn mower model
http://www.ehow.com/how_6402951_change-snapper-mower-belt.html
Posted on Apr 03, 2011
Mower will not drive to the right I changed the o-rings and filters on both drive motors and re-filled unit with oil but now unit will only drive with left hand no right hand action.
Sou.d like the hydrostatic transmission completly failed upon right hand drive the main gear is not engaging right drive
A knew transmission unit should fix the problem but part is pricey
Jun 20, 2016 | Toro Titan ZX5450 (54") 25HP Zero Turning...
Cub cadet i1042 zero turn doesnt seem to want to go forward when turning or even going strait sit moves very slow and when i go up a little hill it stops half way and then creeps up the hill it use to
If it's a hydrostatic transmission, I would have the transmission looked at. You may need to "purge" the system and check the fluid level.
The ones I've done called for the drive disconnects (the rod or lever which allows you to roll the tractor when the engine is shut down) to be in the flow bypass position. They also wanted the wheels off the floor, then the engine to be started, & the direction control to be worked SLOWLY to the front & rear positions 10-12 times. Then put the bypass valve back in its 'drive' position, fire the engine again & repeat the slow cycle of the direction control. The unit SHOULD be quieter now & perform better, but double check the oil level because expelling the air may have dropped it too low.
Jul 22, 2014 | Cub Cadet I1042 42" 18HP Zero Turn Tractor...
Hi, i have a Ariens Zoom M 2148 xl tractor model
Probably you can get what you need at a lawn mower shop, they have exploede parts diagrams on microfilm.
Sep 28, 2010 | Ariens 34 In 344 CC Briggs Stratton...
Mower doesn't cut going downhill
Sounds like a loose belt check the tension spring if they ok check and see if belt is strectched
Dec 19, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Oct 10, 2009 | Garden
Looking for when the oil and transmission should be changed on Lt
Hey,
Many manufactures recommend a engine oil change every 50hrs more often in extreme conditions,
Most transmissions are sealed units if this is the case company's recommend not to touch these,
If you have a hydrostatic drive or a Zero turn unit with twin hydrostatic drives the transmission oil must be changed every 500 hours or every year whichever comes first as the hydraulic oil brakes down in time, also at these intervals the hydro oil filter must also be changed...
Brad:)
Sep 16, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet engine runs but, also will not go in forward or reverse
you didnt say what model this is, but i assume its hydrostatic because it has a drive shaft. is the hydrostatic unit filled with oil¿ if its ok, check the linkage from the pedal to the rearend (hydrostatic drive) make sure its not broken or loose.. if that l@@ks ok, check both ends of the drive shaft making sure the couplers are not broke and the drive shaft is ok. hope this helps.
Jul 17, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Hydrostatic Transmission Failure
There is a transmission bypass lever on the back of the mower, if the bypass is moved out of the drive position, it will not drive in either direction, and will be really easy to push.
May 02, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
1,700 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
