Question about Belkin Components Belkin F9K1103 N750 DB Wireless Dual-Band N Router - 2x USB Ports, 4x
Belkin usb peripheral switch
Do I have to Download disc to both computers using the port. What if one of the the computer doesnt read discs. Help
    Problem Solver:
  • 10 Answers
You've two options. One is to just copy the files off your disk to an USB drive and another one is to connect to your USB devices via the media server feature on your router. The latter can possibly be difficult to do.
Posted on Apr 23, 2013
I cannot install the above mentioned scanner since the driver is unspecified
IF IT IS USB BARCODE SCANNER, DO THESE:
1.
Locate the USB connector on the bar code scanner. Bar code scanners, like other computer peripherals, connect to the computer by way of a data cable. At the end of the data cable, most likely opposite the scanner itself, should be a small rectangle-shaped plastic and metal connector. This connector is the USB terminal that will plug in to the computer's USB port.
2.
Locate the USB port on the computer. The USB port, whether on the computer or a peripheral device, will be rectangular in shape and feature either the letters "U S B" or a small network diagram showing two circles, a square, and an arrow.
3.
Connect the USB cable to the computer or peripheral device. Once the USB connector and port have been identified, push the USB connector firmly but gently into the available USB port. USB connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the USB connector, remove the connector from the port, turn it over and plug it in.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must decipher the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
TO INSTALL A SERIAL BAR CODE SCANNER, DO THESE:
1.
Locate the serial connector on the bar code scanner. Bar code scanners, like other peripherals, connect to the computer by way of a data cable. At the end of the serial cable should be a rectangular, typically male connector. The cable may be pinned with nine, sixteen, or more pins depending on the design of the scanner.
2.
Locate the serial port on the computer. Most computers have at least one serial port, usually found on the back of the machine. The port will be female, maybe blue in color, rectangular in shape, and should be approximately the same size (or slightly smaller) as the serial connector.
3.
Connect the serial cable to the computer or connected peripheral. When both the connector and port have been identified, push the serial connector firmly but gently into the port. Like USB connectors, serial connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the connector, remove the connector from the port, turn it over and plug it in. Do not use excessive force while pushing on the serial connector, as it is possible to bend the connecting pins and damage the connector.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must interpret the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your specific scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
THANKS AND WELCOME.
Apr 12, 2011 | Computers & Internet
Belkin USB Peripheral Switch Free Download
there seems to be no software for our usb peripheral switch
Oct 27, 2009 | Belkin BLKF5U201 USB Peripheral...
I have a Panasonic VDR-D160 mini disc camcorder. Im unable to edit discs while in camera and cannot connect camera to my computer. Computer doesnt recognize hardware, manaul is no assistance. No usb or...
i have recored the sveral movie on the DVD-R disc using Panasonic VDR-D160 and then i take the DVD-R disc with me to leave for another country (the Panasonic VDR-D160 left at home) and now i can not read the moviesrecored on the DVD-R disc !!! Why this should be ? The computer view the empty disc although it contains several movies when i checked it from Panasonic VDR-D160 camera when i was at home ! How can i do now to read the movies from the disc ? Thanks a lot !
Jun 24, 2008 | Panasonic VDR-D100 DVD Camcorder
Peripheral switch
Port 2 is problem. same way test plug computer 1 in to port2. test . if print not works confirm that port 2 is only problem . replace the switch.
Mar 05, 2008 | Belkin BLKF5U201 USB Peripheral...
Computer doesn't recognize usb device...
do not use Front usb connector. put your device in backside of CPU usb port. it wil work fine.
do not use Front usb connection. try to use cpu backside USB port it wil work.
Feb 27, 2008 | Belkin BLKF5U201 USB Peripheral...
USB Peripheral Switch F1U201.401
Have you looked at the instructions? Here's a link to the Belkin manual for this product:
http://belkin.httpsvc.vitalstreamcdn.com/belkin_vitalstream_com/support/dl/f1u201-401.pdf
It looks very straight forward. You need to install the driver software on each of the computers then run a USB cable from each computer to the USB switch. Connect these cables to the end of the USB switch that has the four sockets. Next run a USB cable from the end of the USB switch with one socket to the device you wish to control.
When you want to use the USB device from a computer you can select it by right clicking on the USB status icon in the task bar and selecting "Switch" or you can use the hotkey Ctrl+F11 for Windows or Alt+F11 for Mac.
If you find this solution useful I hope you'll rate it...unfortunately most people don't seem to find the time. People like myself are not getting paid for these solutions we're just trying to help.
Dec 29, 2007 | Belkin F1DK102P 2-port KVM Switch
Not Reading Peripherals - i-rocks IR-4100 4-Port USB Hub
If your looking for a good quality USB hub, i would go with a Belkin. They do cost more than most other hubs, but from the 8 years i have been at my retail store, they have had the lowest return rate of all that I have sold.
Aug 25, 2007 | i-rocks IR-4100 4-Port USB Hub
Belkin Components Belkin F9K1103 N750 DB Wireless Dual-Band N Router - 2x USB Ports, 4x Logo
Top Belkin Components Computers & Internet Experts
William Miller
William Miller
David Payne
David Payne
Are you a Belkin Components Computer and Internet Expert? Answer questions, earn points and help others
