Question about Motorola Radio Communications
Acoustic tube adaptor kit
Original acousting tube adaptor kits are so fragile. Can You recomend something serious for CP040
  • Motorola Master
  • 1,654 Answers
There are a variety of earpieces available for this style radio. The clear acousitc tube style is common when used for surveillance or in covert operations. If you are not needing it for this purpose you can get a more durable earpiece with a black or tan wire leading to the ear.
Best regards.
Posted on May 22, 2013
My Acoustic Research HTB-80 Speaker Bar stopped working after a storm. No lights/power. Is there any fuses in the unit that I should check?
if your unit come with external Adaptor power up type. then mostly is the adaptor already blown, replace the adaptor will do.
Jun 24, 2011 | Acoustic Research HTB-80 Speaker
I have to replace the blower motor in a 99 astro van. Can it come out from the hood side or through the dash side?
1.Remove the air cleaner . CAUTION: Refer to Battery Disconnect Caution in Service Precautions.
2.Disconnect the negative battery cable.
3Remove the electrical connector.
4.Remove the coolant recovery and windshield washer fluid reservoir assembly.
5.Remove the screws that retain the acoustic cover. The acoustic cover is located in the blower motor area.
6.Cut the acoustic cover between the ribs. IMPORTANT: Retain this portion of the acoustic cover for reassembly.
7.Remove the cut piece of the acoustic cover from the blower motor.
8.Remove the cooling tube from the motor.
9.Remove the screws that retain the blower motor to the case.
10.Remove the blower motor from the vehicle.
Ensure that the following components have not been damaged or distorted:
The flange of the blower motor
The blower fan
Repair or replace any damaged or distorted components, as necessary.
INSTALLATION PROCEDURE
Install the blower motor to the case. NOTE: Refer to Fastener Notice in Service Precautions.
1.Install the screws that retain the blower motor to the case. Tighten Tighten the screws that retain the blower motor to 2 N.m (18 lb in) .
2.Install the cooling tube to the motor.
3.Install the screws that retain the acoustic cover to the case. Tighten Tighten the screws that retain the acoustic cover to the case to 2 N.m (18 lb in) .
4.Install the clips to the clip lands. The clips secure the acoustic covers together.
5.Install the coolant recovery and washer fluid reservoir assembly.
6.Install the electrical connectors. CAUTION: Refer to Battery Disconnect Caution in Service Precautions.
7.Connect the negative battery cable. Ensure that the circuit operates properly.
8.Install the air cleaner.
Thank you for using Fixya and be safe
Oct 21, 2010 | 1999 Chevrolet Astro
Acoustic Solutions DD304 Digital Drum Kit USERS MANUAL
http://bestfilesfordownload.net/acoustic-solutions-dd304-digital-drum-kit-manual.html
Sep 17, 2010 | Audio Players & Recorders
Cuoul i replace the tweeter with any 1 inch tweeter other than acoustic research?
Providing you match the power and ohm rating of the acoustic tweeter yes. You could of course have an higher rms/watts rating than the original, but not lower. The ohm though must be the same. The only thing that might happen is that it might sound different to the other speaker, as the tweeter sound quality could be better or worse than the acoustic. Of course you could buy two and replace the other speaker one too!
Feb 14, 2010 | Acoustic Research AR PS2262 Main / Stereo...
Background hum
I fixed the same issue by replacing the original AC power supply with a 13.8 volt DC power supply (Radio Shack) It seems to be more consistent at high SPL and no hum , as the Boston acoustic unit accepts either AC or DC power.
Jan 29, 2009 | Boston Acoustics MediaTheater Computer...
Bose acoustic wave music system
I have the same problem: ready to throw it out and get a new one
Aug 18, 2008 | Bose Acoustic Wave music system II -...
Samson
try using the instrument input lets see if its going to change something.
Jun 04, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Radio Communications Logo
158 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
OBHighflyer
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
