Samsung washer wa15r3
Every time we start washer machine it stops and show sign de
johnychel
  • 796 Answers
SOURCE: SAMSUNG WASHING MACHINE WF306LAW
is that the error code??
Posted on Feb 29, 2008
kapishtech
  • 2272 Answers
SOURCE: Samsung washing machine shows error "LE"
This is usually a communication error, unplug the machine for 20 minutes and then see if it returns when power is restored.
but if this does not helps then the actual reason of LE error code is as follows:--
LE LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The hall sensor is out of order/defective.
The hall sensor seems to be part of the motor.
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 11, 2010
SOURCE: samsung washing machine cycle will
your door is not close right
Posted on Sep 22, 2010
caroldon
  • 17130 Answers
SOURCE: i have a samsung washer
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Aug 08, 2011
  • 1417 Answers
SOURCE: 'Ld" sign is showing in
Hello.
What this code means indicate that the door of your washer is not well close .
L= LOCK
D=DOOR
So what you need to do to solve the problem is to open the door of the washer then close it properly.
Good luck.
Thanks for using fixya
Posted on Sep 06, 2011
I got samsung washing machine top loader the start button it quite no sound by pressing and doesn't start the machine.
I had the same problem faulty lid switch..... So meaning when the lid is shut the washer thinks it's open.....I ended up throwing mine out too expensive to fix....
my Samsung washing machine was a recall but found out too late check their recall models you might get it fixed on warranty...
cheers hope this helps
Apr 21, 2017 | Samsung Washing Machines
My samsung top loader of 13kg shows code dE
Many Samsung top loader washers are recalled due to a severe unbalance issue that causes the top of the washer to become dislodged and fly off. Enter exploding Samsung washers in your search engine. Since your machine may be recalled, you may have a free service call coming your way anyway!
Nov 10, 2016 | Samsung Washing Machines
Code dE
As Far As I Am Aware That Is A Washing Machine Door Error Code
Apr 21, 2014 | Samsung SW62ASP Top Load Washer
Code dE showing
Does your washer have a lid lock mech. If so and the lid is not locking or is staying locked you may want to check the locking adjustments
My washer is showing dE message what is this mean?
The machine identifies and indicates some operational errors through a series of beeps.As you are using LG WM2455 Front load Washer it is showing error message The error message "DE" This error signal beep during drain.Unhook/clean drain pipe and press the 'Start/Pause' button to continue cycle.Thanks for your question.
Jun 17, 2011 | LG WM2455 Front Load Washer
My washing machine stops working, it shows 'dE' everytime i try to start a cycle, and i dont seem to be able to find out what it is... please help
DE MEAN'S DOOR ERROR,There is a little magnet that detects if the lid is open or closed & this magnet always falls off into the machine then pumped away. (If it gets past the pump with out jamming it).you can't just buy the magnet you have to buy a whole new top & most of the time this cause's the computer to fail as well,So it could end up costing a fortune even up to the amount you could have bought a new one my advice get rid of the samsung & buy a new lg the sooner you do that the sooner you start saving money in washing machine repairs.
Feb 25, 2011 | Samsung SW62ASP Top Load Washer
Samsung WA15R3 will not fill with water
Could be water valve is bad. Check screens in both hoses and valve for trash.
Oct 02, 2017 | Samsung Washing Machines
Samsung smart wash b1245s doesn t work
motor brushes are worn and nead to be replaced easy job if you turn washer on to its side remove the 2 screws at the bottom and take off the plastic panel you can see the motor and the brushes are red plastic bits remove them and replace with new ones that should sort out the problem and cost about £25.00 to do .
Oct 13, 2007 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
