Question about Garden
Kodiak 4000 electric pressure washer
Will not run constant, pulsating
  • 242 Answers
SOURCE: pressure washer is pulsating when powered on
it just the presure building back up ,it will last years doing this,i would not worrie as replacing the presure pump will only be a temp fix and it will do it again ,most washes do this after a year or lots of use.
Posted on Dec 31, 2009
  • 112 Answers
SOURCE: 1750 psi Electric Pressure Washer: My pressure washer is losing pressure and is pulsa...
I have d'same problem before. replace the head component with the 3 little cylinders,springs etc.. its a 1 piece part.
Posted on May 06, 2010
  • 68 Answers
SOURCE: Pressure washer pulsates
Could well be the main jet slightly blocked in the carburettor.
Posted on Jun 10, 2010
SOURCE: I have a karcher K3.97m electric pressure washer. The unit constantly runs and never shutoffs. I after flipping the power switch. What could be worng?
Someone has hard wired the switch to always run because the switch was apparently bad at one time and in order for it to work they just wired it up straight. Remember to rate my solution Thanks in advance
Posted on Apr 27, 2012
  • 1388 Answers
SOURCE: landa pressure washer LT 4035-4000 psi. Why is it losing pressure and continually pulsating?
If the pump is pulsating rapidly most likely valves are leaking or debris under valve keeping one or more from closing. If the pump pulsates slowly, comes up to pressure then low pressure then repeats, problem is pressure regulator /bypass. Or you could have a combination of both. Try lowering the pressure to lowest setting to see if slow pulsation stops. As parts age within pump and debris hinder operation you can no longer operate at full pressure. To make the pump last, use highest pressure as needed and everyday work using only 60 to 75 percent of capacity.
Posted on Mar 19, 2013
My K5.55 has pressure loss and judders while running. Vibrations are transmitted to the discharge hose. I need to adjust the wand constantly to get enough pressure.
Change oil, spark plug and clean/replace air filter. Do u have a choke adjustment, most have automatic govenors nowadays. Clean water hose intake screen.
May 03, 2016 | Garden
Pulsating noise in electric baseboard heater
It is the coils they can't take the heat so the hoter it is the more vibration from heater
Mar 30, 2016 | Marley Heating & Cooling
My lights on my Neptune dryer pulsate and the timer doesnt work properly.
This is a heavy one but I've stated before that all appliances and electronics need a functioning ground----you can't use a 3prong adapter to 2prong----there's no ground for the machine to function by and also an ungrounded machine is dangerous----this may not be your problem but it's the easiest to fix, the cheapest and the safest
Oct 09, 2014 | Maytag Neptune MDE5500AY Electric Dryer
I have fuel but there is no power to the injectors to make them pulsate
It's a fused circuit, so check the fuse, probably under hood, labeled injector. A shorted injector can shut down the injector drive circuit, so pull off all injector connectors, make sure fuse is good, then check for power to the injectors. Injector circuit should nave hot wire anytime key is on. Has constant voltage to injectors. When the computer internally grounds the injector ground wire, the injector will pulse.
Dec 30, 2013 | 2001 Chevrolet Cavalier
Squeaking sound coming from engine area. Not sure if pulley or belt or something else.
Very possible it is a belt or pulley.
You could use a section of heater hose and a funnel to listen for the source, or take the belt off and run the engine without it to see if it continues.
Feb 27, 2013 | 1999 Chevrolet Silverado 1500
Briggs & Stratton 11 horse snowblower engine pulsating
this i what my pressure washer does... I would say its just getting aged and you shouldnt have to worry about it, but if you want to try to get it to stop then give it a good tune up. spark plug air filter and clean the carb out with a small wire or tourch tip cleaner to make sure all the passages are clean and clear... or just let it keep doing it like I do.
Feb 10, 2013 | Garden
My Hayward pump is pulsating rather than keeping a
make sure all intake unions are tight you have a air leak or top pump seal is bad
Jun 09, 2010 | Jandy PHP High Head Pump 2 HP Up rated
Some tune up questions and trouble shooting a running issue.
Actually.....the 5.0 in the 92 Olds Custom Cruiser is a 307 CI 5.0 L engine believe it or not....The Caprice had a 305 CI 5.0 L engine. There is very little difference, but I have one as well and I found that out through the local dealer. The pulsation you feel when driving sounds like a transmission problem to me, but I think it could be from the timing chain issue. I do not know the timing setting for the car, but maybe this will help you to find it. I would try to make sure which motor you actually have first, the 305 or the 307, and then ask the mechanic at the local dealer what the setting should be.
Feb 10, 2009 | 1992 Oldsmobile Custom Cruiser
Abs system malfunction
I WOULD RECOMMEND THE ABS BE SELF TESTED BY A FORD DEALER, A FAULT CODE WILL BE PRESENT THAT WILL LEAD IN THE DIRECTION TO REPAIR THE PROBLEM.
THE 2nd PROBLEM SOUNDS LIKE WARPED FRONT BRAKE ROTORS.
Nov 09, 2008 | 1999 Lincoln Town Car
Garden Logo
90 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
