Question about JVC Televison & Video
Laptop will not connect to tv
My plastation 3 will connect via the hdmi perfectly but the laptop will not. The problem isn't the laptop because my friends laptop does not work on the tv either. My laptop also connects to other tv's via the hdmi perfectly. I am under the impression that it can't be the cable because hdmi cables should work with whatever device they are connected to. The tv model is JVC LT-46ds9bj What is the problem?
    Problem Solver:
  • 18 Answers
The tv might not be able or new enough to handle the picture of a laptop or computer check to see if it is able to
Posted on Sep 19, 2013
TVtechmaniac
  • 140 Answers
SOURCE: hdmi Issue
Most new HDMI DVD players use High-bandwidth Digital Content Protection (HDCP)on the HDMI output.If you try to play this on an older TV that is not compliant with these new standards it will not work.This standard came out late in 2004 that is why your older player still works. There is also a service bulletin from JVC about upgrading the software on your TV for HDMI compatiblity issues.If you want a pdf file of the bulletin I can send it to you.
Posted on Sep 11, 2007
  • 1153 Answers
SOURCE: No High-Def via monolink(HDMI) connection
Troubleshoot first by self diagnosis
Posted on Dec 16, 2007
  • 34 Answers
SOURCE: I am trying to connect
Hello
by befault your dvd recorder is transmiting signals via component video, so what you need to do is this connect both cable HDMI and Component or just a video cable then go into setup and then select video out via HDMI your video will go off on the screen and then with TV remote slect input source HDMI on TV and it should work fine.
Thankyou
Posted on May 10, 2008
SOURCE: My JVC HD-56G786 will not work with HDMI cable.
I had the same problem with my JVC projection tv. It would flash green, then go to regular picture then back to green flashes. Not sure if this is the solution you were looking for, but I was able to get a good crisp picture using composite cables instead of the HDMI cable.
Posted on Aug 30, 2009
  • 5 Answers
SOURCE: I have a 4 year old Mitsubishi WD-57831. Lately,
I have run into this issue alot. I believe its because of a older version of HDMI 1.1. Quick solution is to hookup the cable box with component cables(yprpb) to utilize the HD picture still and then do some research to see if Mitsubishi has a firmware update on your particular model.
Posted on Aug 18, 2010
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
Protron tv says input signal out of range when connecting laptop via hdmi
The TV can't process the digital signal. It might be out of range.
Nov 26, 2012 | Protron PLTV3250 32 in. LCD Television
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
HDMI input says "mode not compatible"
If your Playstation is putting out the signal in 1080p then try changing it to 1080i and see if that works. Not all TVs are compatible with 1080p.
Aug 02, 2012 | Samsung Lnt4042hx/xaa
I have a LG LCD TV 26LX2R and I recently bought a Sony Blu-Ray BCP-S580. If i connect them via Composite or Component cables i get ok video and audio. But when i connect them via HDMI i get excellent image...
I can't speak on whether or not the apple tv has such a setting but the Bluray players does. You go into the bluray player's settings and change the audio output.Your choices should be 2 ch possibly hdmi, bitstream, pcm, and auto. Try hdmi, 2 ch, and pcm because if you have it on auto you might not get sound via an hdmi cable and it's probably not bitstream but try bitstream if none of the others work.
Sep 20, 2011 | LG 26LX2R 26 in. HD-Ready LCD TV
What channel does the tv have to be on to play a dvd?
That will depend of how you're connecting the DVD player to your TV. If your connecting via Coax cable (threaded screw type), then it'll be channel 3 or 4. If you're connecting via AV (3 round connectors), then the channel will be "input... AV". If you'e connecting via Component (5 round connectors), then the channel will be "input... Component". If you're connecting via HDMI (small flat D-shaped connector), then the channel will be "input... HDMI". See a pattern?
Jul 19, 2011 | iLO IWT3206 TV
Cannot connect my PS3 to Panasonic TV via HDMI, my PS3 will connect to other HD TVs using HDMI but not Panasonic
Does your TV work on VGA, it maybe worthwhile getting a HDMI---VGA lead and try that as it sounds like your TV isn't working, and you've tried the obvious. Do any other HDMI devices work on your TV, like DVD HD/SAT?
Apr 22, 2011 | Televison & Video
Issues with LG 26LE5300 26 in HDTV LCD TV Both audio & video flicker off & on when connected to PC via an HDMI cable. No problem when in TV or AV (DVD) modes. PS. worked fine on Day 1, did not...
Reduce the resolution of the PC to 1024 x 768. This can be done by right clicking on the desktop ( not any icon ) click properties / click settings / slide the screen resolution pointer to 1024 by 768 / slick apply / Computer will ask if you want to save this setting /Click yes and then try connecting the TV to the HDMI port. Should work
Mar 11, 2011 | LG 26LE5300 26 in. LCD HDTV
Got a PS3 hooked upto a Samsung 40" LCD TV via
I would suggest trying a different TV, and maybe see if you still have any Component or Standard Definition Composite cables to connect the PS3 to the TV and see if it works that way. I would assume you did this when you said you reset the resolution on your PS3, but turn it off, then hold in the power button until it beeps twice in a row. (Just in case) Make sure everything is plugged in twice and your TV is on the right input. If none of that works, there may be something wrong with the graphics adapters on your PS3 in which case you will need to contact Sony about fixing it.
Mar 04, 2011 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
152 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
