Question about GE JE740 700 Watts Microwave Oven
My microwave model is je 740wk02.. window with metal shield is burnt.. can i replace it
    Sergeant:
    Champion:
  • 234 Answers
Yes ,but cost might be a little high.Because you have seal it every good.
Posted on Mar 14, 2009
It sparks
Check splatter shield inside cooking area for burnt carbon ie replace
Dec 11, 2013 | Panasonic NNSD688S 1.2 Cu. Ft. Capacity...
Brown spots on window of microwave
see this steps and fix it.God bless you
  • Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  • Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  • Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity paint
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#10#ixzz2aSjW5F9U
    Jul 29, 2013 | Microwave Ovens
    Homestyles 0.9 cu.ft. Microwave Oven's shielding plate
    yes you can but you should not. Take the shielding wall from another similar microwave if possible, the magnetron waves can seep thru the smallest crevasses and will repeatedly cause more damage if not fitted properly, im not so sure what type material is used but more than likely it is non conductive, careful magnetrons are dangerous thats why companies that make microwaves have such strict guidelines and safety measures, there are so many switches to prevent direct exposure to the magnetron, it is so dangerous the goverment developed a weapon from the technology--if your insist on repair please find exact replacement parts- careful and good luck more questions just ask
    Mar 30, 2013 | Microwave Ovens
    Turn Table does not turn is it suppose to
    One could unplug the power cord and take off the back metal panel.
    The turntable runs off a rubber belt.
    Be very careful as the capacitor holds one hell of a voltage. It is usually encased by a metal shield... but be very alert.
    Do not run the microwave with the cover off..
    Apr 25, 2012 | Daewoo KOR1NOA Microwave Oven
    When operating arcing appears on right wall there is a burnt hole in plate ad arc is in and behind it
    This is due to grease or food particles stuck on and behind the waveguide cover, which is the plate you are describing.
    The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
    It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
    The metal behind the cover should be cleaned with a mild, non-ammonia cleaner.
    If the paint is damaged or charred on the cavity metal, the area will first have to be sanded smooth and cleaned and dried thoroughly.
    Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
    Since your waveguide cover is damaged, it will need to be replaced.
    It provides critical protection for the magnetron.
    You didn't mention your brand or model, but you can find links to helpful exploded view diagrams and part ordering help here.
    I recommend that you bookmark that link to your favorites.
    Jul 02, 2010 | Hotpoint RVM1435 Microwave Oven
    Microwave wont heat up
    Your signs point to a failed power tube. First though, does it defrost? If it does it is an electrical control problem. If it does not defrost, do the following.... With the power unpluged you may want to remove the outer cover, ( screws at back ), and locate a shiney metal box. That box is shielding for the power tube. Get the part # from the tube and replace. You could check price and availability at www.avnet.com . Make sure you replace all of the shielding exactly the way you found it. VERY VERY IMPORTANT!!!!!
    Dec 02, 2009 | LG Microwave
    Sharp R403 microwave internal electrical short/fire
    This is a simple problem & solution.
    Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
    The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
    If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
    Since your waveguide cover is damaged, it will need to be replaced. It provides important protection for the magnetron.
    You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
    Jun 03, 2009 | Sharp R-403HW Microwave Oven
    American Home shield said that the waveguide is burnt
    The reality is that microwave ovens have gone way down in price while repairs have gone way up. Go to a Walmart or a K mart and you will find many microwaves in the 50-90 dollar range. Even if you could have your current microwave repaired it is still ten years old, well beyond it's life expectancy.
    Apr 30, 2009 | Frigidaire FMT116E1B Microwave Oven
    Burnt hole in metal plate inside microwave oven
    Ok stop useing oven and unplug! THIS CAN BE FIXED!!! Go to a home improvment store and buy a small bottle of white liquid enamal....Clean up the area that is missing and flakeing and then apply the enamel over the hole and let dry overnight! now that the exposed metal is covered back up it is safe to use and will not spark or cause any more soot!
    PLEASE rate my response to your question!
    THANK YOU!
    Jan 08, 2009 | Microwave Ovens
    GE JE740 700 Watts Microwave Oven Logo
    51 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    vince
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
