Question about LG RZ-20LA70 20 in. LCD Television
LG 32lc7d Having problems with the power. The remote lights up but will not turn the tv on or off. Now....when the television is turned on manually... the picture will come up, blink 3 times, then the television turns off. We have had the set for approximately 6 weeks and the problem started just after the in house warranty expired. Please help!
  • 91 Answers
Did you try programing your remote if it is an univresal remote
Posted on Aug 09, 2007
  • Anonymous Aug 13, 2007
    there is a problem with the remote itself it isnt the television
SOURCE:
LG 32" TV remote function fails to work intermittently. Works by using buttons on side. LG's remote for sound and DirecTV's remote for turning on station tuning. Batteries new in both remotes.
Try looking for the remote sensor. It should look a little like a camera lens or little red tinted window. If you cannot find it just give the entire front of the TV a good cleaning. Finger prints and dust build up can interfere with the signals. Do the same for your direct TV box.
Jun 02, 2015 | LG 32LC7D Television
HI I HAVE A LG TV 32LC7D AND I HAVE A PROBLEM WITH IT WHEN I TURN ON THE TV IS ALL BLACK AND IS ONLY A 47 CHANEL SHOWING IN THE SCREEN AND NEED SAME HELP TO REPAIR THIS TV
Hi
I have met this problem with my LG.
I agree unplug from the power supply and find the correct input on the remote control. OK the antenna if that is your input. AV1 or 2 if you use ADSL.
Good luck
Kolbrun
Jun 09, 2011 | LG 32LG30 32 in. LCD HDTV
WELL MY 32 INCH LG THE REMOTE LIGHT ON THE VT IS OUT CANT TURN CHANNELS OR ANYTHING FROM THE SIDE BUTTONS OR REMOTE PLEASE HELP
Have you unplugged the LG TV, waited about 2 minutes, and plugged back in to try and reset the TV?
After you reset the TV, try using the key pad on the TV first before you use the LG remote.
May 18, 2010 | LG 32LC7D Television
I have an LG 32LC7D TV and I am looking for the code so that the LG Remote will control my Sony BDP-S360 Blu-Ray Player. Can anyone help?
you should be able to get and kind of universal remote to fix this problem I have done this with many different kinds of products and got great results hope this helps
Feb 14, 2010 | LG 32LC7D Television
LG 32lc7d lcd tv the work find for about 5min. Then the on screen menu comes on the screen then it gos off the remote will not work what board is it ?
Maybe the remote has some keys that are stuck together on the membrane pad. Take the batteries out of the remote, then turn the TV on again see if the menu problem is still happening. Also check the menu button on the TV see if it is stuck by pressing it a few times.......
If all seems ok but still have the same problem, then the the keypad board in the TV needs to be checked for intermittent shorts or opens. If the keypad board is good then the main board needs troubleshooting. This seems like an EEPROM problem, you may want to test that first on the main board.
any questions please ask....
CWR
Jan 20, 2010 | LG 32LC7D Television
LG 32LC7D side buttons on tv stopped working
Tries to change to new batteries,same thing after that ur remote IC incoder is damages.Tries this website buy an exact remote or very close to it.1-800-Remotes Factory Original.
Sep 12, 2009 | LG 32LC7D Television
My tv turned on on its own and does not respond to the remote, even after replacing the batteries. Furthermore, the volume goes up to 100 and down to zero on its own and the remote is not able to control...
check remote first,how to check remote switch on your camera phone point to camera lens,when press any key check screen light glow,you sure r/c ok.next check reciver eye of tv
Jun 27, 2009 | LG 32LC7D Television
Power light flashing all 3 colors TV will not turn back on
Sounds like the Power supply module. I would take it in to service center ASAP!
May 21, 2009 | LG 32LC7D Television
Trying to program my dvd player with my lg tv remote
Turn on dvd player by hand using your lg tv control push set up dvd plus code.pointing for 15 seconds.
Nov 19, 2008 | LG 32LC7D Television
LG RZ-20LA70 20 in. LCD Television Logo
142 people viewed this question
Ekse
