Question about Brother IntelliFax-2820 Laser Fax
Phantom jams & button undetection
This machine is continuosly feeding the paper in the fax mode w/o printing. unable to utilize the copy button, doesn't recognize it. is there soe type of reset? Please help!
  • 62 Answers
Sounds like a button may be stuck or something. Reset machine by powering off, press and hold start button at same time while powering machine back up. Hold the start button down for a few seconds and release. This should help. Let me know if it does not and I may be able to walk you through another bit harder reset.
Posted on Mar 13, 2009
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
Blank page when I copy or print reports
Re check all the connections. When taking off the paper feed assay, other parts and plug and jack connections were needed to be taken off first.
Make sure the drum seats in its correct position, silver grounds are not bent.
The copy cartridge and Dev housing are not connecting very good somewhere.
Make sure the machine is unplugged.
Try running copies.
Apr 21, 2010 | Xerox WorkCentre Pro 580 Plain Paper Laser...
My Sharp UX-A255 won't let me fax anything. It starts up and then comes up with the message Line error or paper jam. There is nothing jammed.
Is it receiving faxes? Make sure you have the line in the right place in the back of the machine (line) and that you get dial tone (hit the monitor button if it has one). Try calling it on your cell to see if it picks up. You may have a poor phone line conditon, and you could try to slow the modem speed down or check the ECM (Error Correction Mode) if so. If it's a jamming problem, try to run a copy and see if it feeds ok. If not try cleaning the feed/pick up rollers with mild soap and water. Reseat the paper and try it again.
Oct 27, 2009 | Sharp UX A255 Plain Paper Thermal transfer...
Double sided copying
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
Slot.
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
stack.
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
orientation.
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
middle.
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
Disabling the fax function
You can set the fax portion of the machine to manual receive like this:
"User tools"
"fax features" ok
"reception settings" ok
"switch reception mode" ok
"Manual reception" ok
"user tools" to exit
Thia will prevent the machine from picking uo any incoming faxes
....However, if the machine is jamming trying to print a 'fax' report, it will jam regardless of the feature you are using -they are unrelated. Depending on the cause of the jam, it could be a specific tray that is causing the problem, so you may want to remove the paper from that tray, and see how it works. The other reason, that is common for jams from one particular tray is that the size is set incorrectly. Check that the paper size dial on the tray is set for the appropriate size in the tray (including orientation).
If none of this helps, please describe the location of the jams, and I may be able to give further advice.
Apr 23, 2009 | Gestetner - DSm618d Digital Imaging System...
Stuck in print mode with out taking paper from tray
i think may be i can help, well rick there is no reset button on brother machines,..have you tried cleaning the paper feed roller? may be some thing did print and the paper is still crumbled up in the machine. try this. cut a file folder to 8x11 and manually force feed it through the paper path, there may some thing inside the machine that might be holding a sensor down. this is the first thingwe would do as a brother tech. good luck by the way clean the rollers with denatured alcahol
Jan 19, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Clearing an error
well, one of two things have happened, 1. you haven't removed all of the jammed paper, maybe you left a small piece of a piece of paper or you may bent or broken your paper jam sensor. go through the paper path very carefully and check both things.
mikey
Mar 14, 2008 | Sharp UX-B20 Plain Paper Inkjet Fax
Unable to copy
You need to open the cover and see the document you were trying to fax.Just pull it gently.
Samir
Feb 21, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
Copying
You should be able to open the machine up easily and see the jam. It is a very small unit and no plece for the paper to hide. Does the unit use a film ribbon to print from. If so, remove the ribbon to see the jam.
Aug 09, 2007 | Sharp UX P100 Plain Paper Thermal transfer...
Brother IntelliFax-2820 Laser Fax Logo
133 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
