Question about Omega Seamaster Planet Ocean 2900.50.91 Wrist Watch
How do I manually wind my Omega Seamaster Automtic Plz
Can't figure out whether is clockwise if you look side on or anticlockwise
  • 2,334 Answers
I'll make it easy and with a little fun for you!
First -lets assume that the winding crown of your watch is the one of the weels fitted on the car.
Imagine the car which is driving across your watch dial from point 6 (six o'clock) to point12 (twelve o'clock).
Which way the weel of the car is turning?
So, the winding of the watch is executed exactly in the same direction as the weel turn of that car when it goes from point 6 to point 12.
When you wind the watch in that direction, the winding pinion and the clutch wheel (both are parts of setting gear) gets engaged and through the gears turns the barrel which is housing the mainspring.
When you turn the winding crown in opposite direction, the winding pinion and the clutch weel gets disengaged due to the specially angled weel teeth and no action in the setting gear is taken. All you hear is just a rapid clicking sound when the wheel teeth are jumping over each other.
I hope this is Fixya.
Do not forget to rate, please.
Posted on Mar 12, 2009
  • Arturs Kalnins
    Arturs Kalnins Mar 12, 2009
    P.S. All mechanical watches are wound this way.
May i have information about omega watches?
Top omega watches internet wide free delivery. For Omega watches, quality, creativity and innovation work together. It can make use of the better of materials to style its watches. visit it http://sbwatches.com/
Apr 06, 2014 | Watches
Omega Seamaster 300M won't resart after replacing the battery ,which is an Eveready Energizer #395.I have replaced the battery once before,and there was no problem.What I can tell you is when I at
The loss of the stem is probably what caused the watch to stop.
The only remedy is to remove the back cover and identify whether a press-stud or screw held it in place.
A press-stud should allow the stem to be simplt pushed back in - although it may need some help by pushing if it's stiff.
A screw would likely have loosened, unscrew slightly, reinsert the stem and then screw down firmly.
It is unlikely that any parts were lost and if you are not comfortable opening the case, refer to a watch maker (rather than a jeweller) who will do it for you and also assess whether any damage had occurred to start the problem off.
Jul 05, 2012 | Omega Seamaster 300M wristwatch
My omega seamaster professional planet ocean co-axial chronometer has just stopped ticking, what is the problem do i need a new battery or do i need to wind it and if i havent wound it 48 hours can...
As I can see,this is an Automatic Omega watch.The most possible cause is that the watch is out of power.
Ensure the watch in your palm by passing four fingers throught closed strap and moving it up and down,making a trajectory of about 60 degrees, many times not too fast,not too slow.Try many times.If problem persists,my advice is to take it to an Authorised Omega Service Centre (as it is an expensive watch) for secure service and repair if needed.
Oct 11, 2010 | Omega Seamaster Planet Ocean 2900.50.91...
I have an omega watch thats winding knob came off, now the spring is exposed and i cannot put it back on, how do i fix it?
Unfortunately you can not fix it yourself. If the spring came out, that means your winding knob (real name is CROWN) has been worned out and the friction fitting no longer can keep it in working order. AS THE CROWNS FOR ALL WATCHES ARE MADE BY MACHINES, NO WATCH REPAIRS CAN BE SUCCESSFULL. All you can do is to go to local OMEGA dealer shop and ask for replacement. Be prepaired to pay more than you think. OMEGA parts for replacemebt cost dearly.
Rate me, please.
May 19, 2010 | Omega Seamaster 2561.80 Wrist Watch
Omega Seamaster battery
Well maybe if you use a coupon then the price will be lower.
Feb 06, 2008 | Omega Seamaster 2541.80 Wrist Watch
Omega seamaster gmt
what you have to do is that pull the crown to halfway do not pull completely out, if you pull halfway out and then move the crown to clockwise or anti clockwise it will change the date. if you pull completely out then it will change the time.
Nov 07, 2007 | Omega Seamaster 2561.80 Wrist Watch
Omega seamaster
sounds like an auto wind watch,you must wear this watch most of the day to keep it wound up.to wind the crown must be pushed all the way in.
Jan 10, 2007 | Omega Seamaster 2232.80 Wrist Watch
Time delay
try manually winding it if you can, and see if it still happens. If it does it probably needs to be sent in for service
Jan 05, 2007 | Omega Seamaster 2561.80 Wrist Watch
Omega Seamaster Planet Ocean 2900.50.91 Wrist Watch Logo
4,679 people viewed this question
Top Omega Watches Experts
Geoff
NavigatorX
Level 1 Expert
Are you an Omega Watch Expert? Answer questions, earn points and help others
