Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Maytag refrigerator The freezer area appears to be freezing over. I have lowered the thermostat to it's lowest level (1) and it's still freezing and producing ice around the door, etc.
  • Kenmore Master
  • 4,654 Answers
Maytag refrigerator - ea5703cb-9dae-46dc-802e-aff05e1adbe2.jpgYou may have defrost component failure. What is the model number of your Maytag? Sea Breeze
Posted on Apr 23, 2013
Testimonial: "The model number is MFF2558VEM"
  • 2 more comments
  • Greg Turner Apr 23, 2013
    Sea Breeze, thank you so much for your assistance!!!
  • John Tripp
    John Tripp Apr 24, 2013
    You said there is ice near the door? Is this ice there like it was poured on the floor of the freezer? What is the temperature in the fresh food compartment? How cold is the freezer? On the back wall of the freezer compartment is a panel and I want you to unplug the refrigerator and remove that panel. I need to know two things after the panel is taken out. What does the evaporator frost pattern look like and is there ice in the tray below the evaporator that also appears to flow out and onto the floor of the freezer? Thanks John Tripp
  • John Tripp
    Can you take some photos and post them here?
  • John Tripp
    John Tripp Apr 25, 2013
    Thanks for providing a model number. I would like to hear from you about this ice and freezing over of the freezer compartment. Do you have anyone that can test the defrost heater? Thanks JT
aborcass
  • 2651 Answers
SOURCE: Kenmore side by side 596.57582790
you would have to remove the back lower panel of the freezer section to get a feel as to whats going on in there. behind the panel you will find an evaporator panel that should have consist ant frost pattern from top to bottom with no excessive clumps of ice.I'm assuming you don't otherwise your refrig would be working ok..
either theres only the top 1 or 2 coils actually have ice on them, and the rest of the coil is bright shiny aluminum. or there is an excessive amount of ice built up so far that you dont even see an evap coil.
if the first is true and threre little frost then that points to a sealed system/ low freon issue. and call a servicer. you should have a full 5 yr warr. for sucha problem
if its the second issue hen theres a defrost problem and youll need to replace either the defrost heater, defrost thermstat( most likely),or the defrost board/timer
Posted on Mar 25, 2008
  • 1073 Answers
SOURCE: Crisper produce freezing
are they long times between door openings of the doors, this can cause cold air to migrate to the bottom of the fresh foor area and freeze produce
if this is not the issue, then turn down the fresh food control to a lower number monitor for 24 hrs
if this does not help replace the fresh food thermastat
Posted on May 20, 2008
SOURCE: refrigerator not that cold and freezer not freezing well
dirty coils underneath the fridge, or the fan in the bottom (to cool the compressor) is not working.
Posted on Aug 07, 2008
gaeb7
  • 25 Answers
SOURCE: Frost build up in the freezer section of my side by side Kenmore
Replace the defrost clock.
Posted on Feb 25, 2009
  • 30 Answers
SOURCE: Crisper draws are freezing produce. Kenmore Trio 795.77562.600
If you can find the duct work behind the draws you might find an air control, if you have a contract with Sears - you can call them back, the part that was replaced has a Garn.T and or 30 days on service, when you ajust the temps it may sometime act up but has a default and will return to that. Cold air drops down. read the manual that came with the Refrig. Buying a service contract might be the best thing for piece of mind - Sears covers everything, even plactic and paint ( scratches). most everything is plastic in the refrigerators today and are very expensive, 3 doors allow more air into the unit then a 2 door because of the seal between the doors, just 2 pieces of rubber overlapping .
Act on this as fast as you can, 30 days on service goes fast and a service call runs about 75 dollars . Oh ! don't put wet veggies in draw and rap everything with Plastic wrap, veggies only least about 4 /5 days then become soft and lose taste and color.
Posted on Jul 15, 2009
Frigidaire side by side freezes in the Refrigerator side
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced
May 16, 2012 | Frigidaire Refrigerators
Freezer door does'nt shut all the way
If you notice one side of your Maytag side-by-side refrigerator is significantly higher than the other, you might want to raise or lower one of the doors. The refrigerator door is configured at the factory to be slightly higher than the freezer door. The weight of items on the door shelves sometimes cause the doors to sag slightly inward. Making a small adjustment to the freezer door leveling screws will correct minor amounts of sagging.
Things You'll Need3/8-inch hex head screwdriver 1
Position the refrigerator in the place you plan to keep it, and make sure the refrigerator is level front to back and side to side with a spirit level.
  • 2 Remove the base grille, located below the doors, by pulling from the sides. The leveling screws will be visible when the grille is removed.
  • Read more: How to Adjust the Maytag Freezer Door ' eHow.com http://www.ehow.com/how_12111048_adjust-maytag-freezer-door.html#ixzz1txsYiGQa
    Read more: How to Adjust the Maytag Freezer Door ' eHow.com http://www.ehow.com/how_12111048_adjust-maytag-freezer-door.html#ixzz1txrg7UOa
    May 04, 2012 | Maytag MFI2568AE Side by Side French Door...
    My refrigerator freezes my food and drinks even at lower setting. The freezer is at the lowest setting and freezes my food like rocks.
    There is a thermostat inside the casing telling the fridge to keep cooling - forever.
    Replace it
    Oct 28, 2010 | Refrigerators
    I have the same problem.
    test thermostat. when fridge is running, turn dial to lowest setting , fridge should turn off. then when fridge is not running,turn to highest setting, fridge should turn on. if it fails this test thermostat is faulty and needs to be replaced
    Sep 10, 2009 | Maytag MBB2256G Bottom Freezer...
    Food in my refrigerator freezes I have a top freezer maytag
    There are 2 things to check - Your cold control dial - to rule out a thermostat problem lower it to 1 gradually and slowly until you hear a click and it shuts off - If it does not shut off, and only shuts off if you set it to the OFF position, then you have a thermostat problem and your compressor is continually running, freezing things in your refrigerator. If lowering your dial you hear a click and compressor shuts off, then the solution is to lower your dial, you have it set too cold - There is a thermostat in your refrigerator that should shut things off when it is cool enough it's either not working properly or your dial is set too cold.
    Sep 05, 2009 | Refrigerators
    Freezing in frig.
    Check the air dampers at the bottom of the fresh food section.They may have been moved to a open position. If so close them up some.
    Otherwise the cold control thermostat may need to be replaced.
    Mar 21, 2009 | GE GSS25SGMBS Side by Side Refrigerator
    My Kenmore side by side Model #10654393300
    repl thermostat and set freezer air control to the middle
    Oct 24, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    Maytag Wide by Side (5 years old) Freezing Refrigerator & Freezer
    There is 2 things you can replaced to rectify this problem .
    1 is the defrost timer and the next is the thermostat.
    On the thermostat is a metal rod that is connected to a vent so when you adjust it it open or closes the vent .Just make sure that is not loose because if it's loose even though you turn thermostat down the vent would be wide open allowing freezing air to get into refrigerator.
    Jun 03, 2017 | Maytag MZD2752G Side by Side Refrigerator
    Kenmore 50522 / 50524 Side by Side Refrigerator Logo
    75 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal DeAngelo
    Jim Goldsmith
    Jim Goldsmith
    jackdo2
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
