Question about Hitachi Tools & Hardware - Others
Threads gone in base plate
Need new base plate pluse screws and the piece the screws go in to can find spares on web site
  • 1 more comment
  • chaz_hurbetb Mar 13, 2009
    hitachi sv12sg palm sander 240v
  • chaz_hurbetb Mar 24, 2009
    need new base plate plus screws plus plastic legs cannot find spares on web site so could tell me where the nearess shop is for spares i come from suffolk post code ip19 8sa can you help
  • David Ford
    David Ford May 11, 2010
    What is the model number and brand and I will try to help
  • 2,176 Answers
OK here is what I found at on your sander. If I am correct it should be a quarter sheet starting with the legs (if you need them) part number 322-756 qty 2, tapping screw 311-945 qty 2, base 322-759 qty 1 and screw 949--216 they show qty in pack of 10 so I would only order 1. Hope this helps and if you have trouble finding them let me know your location and I will try to find someone for you. Good luck
Posted on Mar 13, 2009
  • David Ford
    David Ford Mar 25, 2009
    I havent been able to find anything local for you, by Suffolk I take it you mean England, I will call a Hitachi rep and see if he can help me.
  • David Ford
    David Ford Mar 27, 2009
    No luck with rep but you might try this number 1-800-546-1666 it is a dealer locator number. Also you might look in your phone book under power tools and try that way. Sorry I couldn't help more.
How do I remove casing
there are 2 more screws below the snap on base plate if you have further problems go to espares site look up karcher spares put in inlet elbow and there is a video showing how to split casing it is quite easy when youve seen this good luck
Jan 16, 2015 | Karcher Garden
Thermostat replace
YOOLS U NEED= Basic hand tools will probably do the trick. You may need a rachet and set of sockets.
Cut the furnace's power source before beginning. Check for a power switch near your furnace or turn off the electrical power supply at the circuit breaker.
2Turn off the gas supply if you have a gas furnace. Look around the furnace for a black pipe. This pipe is the gas line. Check for a valve located near the pipe. Turn off the gas supply by moving the valve so it's perpendicular to the gas line.
Take off the thermostat's old cover by unscrewing the screws that attach the cover to the wall. Some covers don't have screws and simply pull off.
Unscrew the mounting plate and notice the wires.
Place a small piece of masking tape on each wire. Use a felt-tip marker to mark the masking tape according to the wire's screw terminal location. Usually, the wires are marked with letters.
Disconnect the low-voltage wires from the base plate by loosening the screws and then pulling the wires away.
Locate the mounting screws for the base plate. Unscrew them and take off the base plate. Guide the base plate over the wires carefully.
May 31, 2012 | 1997 Toyota Avalon
I need a Base Plate Template for my toto washlet c100
Wow I need one of those. Never even seen one before. Found a site that has spares luv.
Washlet C110
Nov 03, 2011 | Home
Otmail.vwhere can I get the part that turns the turntable
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies and Driver downloads (if applicable) as required.
The information is normally free of charge.
Replacement of the turntable motor should be carried out by a qualified appliance repair service.
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
I am assuming the plastic coupler is not split or broken and causing the problem.
The motor assembly is fixed to the base of the oven usually with two screws and access is obtained usually by removing the inspection plate directly beneath the motor. It is usually a plug in synchronous motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate, sometimes it must be cut out with sharp cutters, and disconnect the motor. Remove the motor and go and get a new one. Fit the new motor and fit the inspection cover back on the base by turning it to fit and using an extra screw fix it then put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Feb 27, 2011 | Microwave Ovens
I need a new bowl for a Moulinex masterchef 580, is it still avasilable, where?
Try Moulinex's web site? if you are uk based stock spares for Moulinex. Or
Hope that helps
Dec 31, 2010 | Microwave Ovens
Mamas and Papas Murano cot bed problem
fully dismatle the cot, keep all the bits.. Take the two slatted sides to bits and put the base pieces of wood from these to one side.
pull the headboard and footboard (is that whats its called) apart take the feet from the footboard and add to the headboard (they are now the sole head and foot boards) screw the 4 nuts with blanking plates to the top 4 holes on the new head and footboards
take the two long slatted size bases and screw them to the lower holes on the head and footboard put the base brackets (L shapped screws) into the corners put the cot base onto the L shaped screws done
May 18, 2009 | Baby Gear
How to disassemble Braun 4505 shaver. Cutter stopped working.
You want to go to this site and get a repair manual.
Follow the instruction and remove the swivel head. Then remove the 2 screws at the bottom. I still have problem sliding the two side head support off.
Apr 08, 2009 | Braun 4501 Electric Shaver
I cannot remove the plate to pute the other plate on
Here's a copy of the manual instructions...
Detail Sanding
Your tool is equipped with a teardrop base which allows you to use it on large flat surfaces
and tight spots or corners.
The pad tips may wear unevenly, depending on use. The pads are designed to allow you to
interchange and /or rotate the diamond tip.
Fitting Sanding Sheets ( Fig. 2)
• Detach the two diamond-shaped tips from the sanding sheet.
If this doesn't provide enough information, take a look at the pictures in the manual at the following link:,MS550GBMS550GH.pdf
If you still have difficulty getting the base off, write back and let me know specifically what the trouble is and I'll try to help you with it.
• Hold the tool with the sanding base facing upwards.
• Place the sanding sheet onto the sanding base.
The diamond-shaped tip can be reversed and replaced when worn.
• When the front part of the tip is worn, detach it from the sheet, reverse it and press it onto
the sanding base again.
• When the whole tip is worn, remove it from the sanding base and fit a new tip.
Tip of the Sanding Base ( Fig. 3)
When the sanding base tip is worn, it can be reversed or replaced.
• Remove the screw.
• Reverse or replace the worn part.
• Fit and tighten the screw.
Finger Attachment ( Fig. 4)
The finger attachment is used for fine detail sanding.
• Remove the screw.
• Remove the diamond-shaped tip holder from the sanding base.
• Fit the finger attachment onto the sanding base.
Contour Holder Attachment (Fig. 5)
• The contour sanding pieces are for sanding curved surfaces and grooves.
• Remove the screw.
sanding base.
• Fit the contour holder onto the sanding base.
Fitting and Removing a Contour Piece (Fig. 6 & 7)
• Choose the contour sanding piece profile most suitable for your application.
• Place one end of the contour sanding piece into the recess at
the front end of the profile holder.
• Push the other end of the contour sanding piece until it clicks
into place.
To remove the contour sanding piece, push it forward then pull the rear end out of
the profile holder (fig. 7).
Fitting a Sanding Sheet Onto a Contour Sanding Piece (Fig. 8)
• Align the sanding sheet with the contour sanding piece.
• Press the sanding sheet onto the contour sanding piece, making
sure that the sanding sheet follows the shape of the profile.
Mar 23, 2009 | Black & Decker MS550GB Mouse 5 Amp Detail...
Missing a screw!
Hi Jonathan.
You can get the part you need (QB-4W) off the web. The part doesn't have a wheel, it's called a quick release plate. It's going to cost about 12. usd. Here is just one site you can find it.
Hope this helps.
Mar 04, 2009 | Vivitar Photography
Missing screws for pentax KX (similar to K1000) base plate
Do you have a local camera shop
that speciilize in camera
Feb 03, 2009 | Pentax K1000 35mm SLR Camera
Tools & Hardware - Others Logo
99 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
