Question about E-Machines eMachines Desktop PC
I cannot get my CD drawer to open. When I push the button, the drawer beins to open, but after a quarter inch opening it pulls back.
  • E-Machines Master
  • 19,396 Answers
That is a mechanical problem, the unit is prevented from ejecting completely the try because something is in the middle.
If you do not find a simple solution, the best thing to do is replacing the CD/DVD RW unit , a new one start from $30.
Posted on Mar 12, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
Is there any cd stuck inside the cd drawer? Turn off your PC and then try and open the CD drawer.
    Brigadier General:
  • 3,614 Answers
You can see a tiny hole on the front of the cd tray. use a paper clip and insert it, and try to push it unitl the tray open
The display flashes "closed" and I can't open the cd drawer when pressing the open/close button. Is there a reset please ?
Try removing power from the unit, let it set two minutes without power and power it up again. See if the problem continues.
Make sure the cd drawer is complete closed and flush with the front panel. If not, something could be stuck inside.
Turn off power and remove cord from wall for next step:
There is a small hole generally on the flat face of the cd drawer through which a bent straight paper clip can be pushed gently until you hit a mechanical stop. Pushing slightly harder at this point should cause the cd drawer to move open mechanically. Gently pull the cd drawer open until you can remove any CD still inside.
Gently push the drawer closed again and restore power to the unit and see if the problem returns.
Would be nice to have manufacturer and model number of the CD player.
Apr 08, 2015 | Audio Players & Recorders
If pressing the button on the CD/DVD drive does not open the drawer you can look for a small hole on the face of the drive, usually just below the drawer and about 1/3 of the way in from one side. Straighten out a paperclip and insert it into the hole. It should go in about a half inch then stop. Push a little harder and it will travel farther in and release the drawer.
Nov 02, 2013 | Computers & Internet
Cd tray tries to open butacts like its stuck
Take a Norwegian paper-clip.
Straighten one end.
Insert that end into the small hole in the faceplate of the CD-drive, until you feel resistance.
Push it another 1 centimeter (1/4 inch) against the resistance.
This will "unlock" the drawer.
Push the open/close button, to fully open the drawer.
Remove any CD disk.
May 09, 2011 | Computers & Internet
I have an Everex PC Tower. My cd/dvd/drawer is jammed shut. How can I get it open? Thanks, Craig Knapp Monroeville, Ala
Turn the computer off.
Straighten one end.
Push that end into the small hole in the face-plate of the CD, until you feel resistance.
Push another 0.25 inch (6 mm), and the drawer should "unlock".
Gently pull the drawer open, and remove any disk(s).
Oct 22, 2010 | Everex DESKTOP PC EVEREX | GPC TC2502 RTL
The cd player want open
Turn the computer on.
Take a invented-in-Norway paper-clip, and straighten one end.
Put the end into the small hole in the front of the CD-drive.
Push it gently in until you feel resistance.
Then, push much harder, for about 1/4 of one inch,
and the drawer should open, slightly.
Remove the paper-clip.
Gently pull the drawer open.
Remove any CD from the tray.
Then, remove the CD-ROM device from the desktop, and discard it.
Oct 09, 2009 | HP Computers & Internet
Can't open the second cd rom drawer
Does the light flash when you press the button? If so, was there a disk in the drive previously? There is a small hole on the front of the unit. With power off, get a paper clip and open it up halfway. Push the open end into this hole and the drawer should pop open by about half an inch. This will be enough for you to gently pull the drive open and remove anything stuck inside. Ian.
Sep 27, 2009 | E-Machines T3256 PC Desktop
DVD tray won't open.
Opening a CD or DVD drive to retrieve a disc
  • Use Windows to open the drive door:
    1. Double-click the My Computer icon on the desktop (or click Start and My Computer in Microsoft Windows XP).
    2. Right-click the CD, CD-RW, or DVD drive , and then click Eject .
  • Restart the computer and press the EJECT button on the front of the drive when the first screen appears (before Windows launches). If the drive door opens this way but does not open in Windows, another software program is taking control of the CD drive. Try shutting down or configuring any programs that write discs or monitor the CD drive.
  • If the door still will not open, do the following:
    1. Close all programs and shut down the computer.
    2. Unplug the PC from the power outlet and remove the battery.
    3. Locate the manual release hole in the front faceplate of the optical drive tray. This is a small hole under the door that is a little bigger than the diameter of a paper clip. The location of the manual eject hole will vary.
    4. Insert a straightened paperclip into the manual release hole until resistance is felt.
    5. Once the resistance is felt, keep pushing the paper clip until the drawer comes out about a quarter of an inch.
    6. Remove the paper clip and gently pull out the drawer until the disc is accessible.
    7. Remove the CD and turn on the computer.
May 21, 2009 | Daewoo DVG-3000N DVD Player
Five discs keep spinning; will not stop. Cannot open drawer
they button maybe stuck or the switch that open the cd player sticking try to push button to open then pull on drawer not to hard u brack then see if u can clean swith
Mar 22, 2009 | Sony CDP-C445 5-Disc CD Changer
Cdr20 drawer is jammed ERROR message
Try taking the unit apart it mostlikly jamed or jumped track try re ajusting it that would prob work, another thing is to try messing with the gears that could aslo work
Oct 18, 2008 | Harman Kardon CDR20 CD Player
CD problems
hi you push the button and it dosent work? maybe the button went bad push harder pull the button out ( if possible) and push with something small and hard you hear anything after you push? if soo then the drawer is stuck or the engine is about to die (not enough power to open the drwer) take a flat screwdriver and shove it (gently) between the carack of the drwer and try helping the drawer out maybe a plastic wheel will brake from this soo be careful in the end these system are ment to start dying after 5 years soo if this is the case sorry wont do any good have a good one
Mar 26, 2006 | Sony CMT-HPX9 CD Shelf System
E-Machines eMachines Desktop PC Logo
61 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
