Question about Air Tools & Compressors
When my compressor tries to kick back on, it bogs down and trips an internal breaker switch.
    Problem Solver:
  • 6 Answers
When finding a home for any compressor you need to take a few things into consideration. Extention leeds can create a voltage drop. for a standard compressor you will need at least a 40 amp trip switch at fuse board the draw of first start up could be a higher rating than your current breaker
Posted on Mar 14, 2009
Air Compressor trips breaker under load. If I remove the belt the motor runs fine, spins freely as does the compressor pump. With the tank pressure empty, the compressor starts and runs fine. When it...
Most people recommend replacing the motor capacitor in this situation, since a faulty cap will reduce the starting torque. But in my case the check valve was the culprit - there was too much back pressure on the head.
Oct 22, 2013 | Campbell Hausfeld VT6290 2.0 HP 20 Gallon...
Duo therm ac trips breaker
When compressor for cool tries to kick in, or even when fan only used?
Try it on fan only, not cool, then try cool and if you hear it sort of "moan" then breaker trips, that's compressor trying to kick in. Make sure you have sufficient power coming in to trailer as well, without long extension cord. Get back to me, then I can tell you which way to go from there.
Apr 20, 2012 | Heating & Cooling
My blade to my circular saw model number 5007nb was having trouble cutting through some wood which lead to it over heating how can i fix this thing and get it to start working tonight
Well you did not really say what is wrong?
Are you trying to stop the overheating, or did it get so bogged down from blade heat warpage, that the internal circuit breaker tripped?
If so, then look at the end of the motor, near the cooling vents, and press the little black circuit breaker reset. (not all have them)
Also check that the outlet still works, by plugging something else into it, because you may have tripped the circuit breaker for the outlet, or GFP.
Mar 12, 2011 | Makita K06 Switch 5007fk 5007nb 5007s...
Was cutting with it and it just kicked off like a breaker tripped, no power at all.
check the cable going into it,then the nozle i think the unit has a breaker type switch ? push it all the way down then back up again
Jan 07, 2010 | Hobart Airforce 250ci Light Weight Plasma...
Condensing unit terns off but won't come back on kicks off breaker
If it runs, turns off, then tries to restart and kicks breaker, look for bad start components. Check start relay, start capacitor. It may be trying to restart too quickly and the compressor over amps and breaker trips. The system needs to have at least 3 minutes of off time before trying to restart. This allows the pressures in the system to balance enough so the compressor can overcome the high side pressure and start. I've seen where people turn the control up and down very quickly causing the compressor to over amp and trip breakers and over loads.
Hope this gets it for you.
Oct 22, 2009 | True 19 cu. ft. / 538 liter Commercial...
Frig keeps overloading circuit breaker, just repaced relay
I think the compressor has a problem with its internal running coil , or it's grounded.To check it you can disconect the power to the compressor and then turn on the breaker , and if doesn't tripped the breaker ,you know the compressor is bad.
Sep 06, 2009 | Refrigerators
My compressor starts up and reaches the desired pressure, but when I have used it for a short time and the pressure drops, it does not kick back on automatically. It bogs down and trips the circuit breaker...
YOUR COMPRESSOR MUST UNLOAD WHEN IT SHUTS OFF SO IT DOESNT START UNDER A LOAD THE NEXT TIME. MOST SMALL COMPRESSORS UNLOAD WITH A VALVE ON THE SIDE OF THE PRESSURE SWITCH.REPAIR VALVE OR REPLACE THE PRESSURE SWITCH (KNOW PSI OR TAKE SWITCH WITH YOU).YOUR COMPRESSOR IS STARTING WITH AIR PRESSURE ON TOP OF THE PISTON. CHECK VALVE COULD BE BAD BUT IT SHOULD BE BLOWING AIR ALL THE TIME.
Mar 11, 2009 | Northern Industrial 2 Hp Twin Tank...
Air Tools & Compressors Logo
256 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
