Question about Car Audio & Video
Polk Audio PA880 800 WATT amplifier
My amp keeps blowing fuses, and I know its not the wiring because I hooked up another amp which worked, what could be some problems with it?
  • 12 Answers
SOURCE: my subwoofers cut out
You are most likey running too much power from the amp to the speakers.. you might want to try just notching the bass down a notch or 2.. just enough that the bass will hit
Posted on Nov 22, 2007
jerryg50
  • 1667 Answers
SOURCE: AMp keeps blowing fuses
When any amp blows fuses, this indicates that something is drawing too much current. The most common cause are components in the output stage and driver stages that have become defective.
On the amp that is blowing the fuse with the volume being turned up, this means that the output stage is partially working. The short or over-draw of current must be in the output stage, or what is loading it. It is possible in this case that a crossover in a speaker unit is defective, and is drawing too much current. I have seen this with especially sub-woofer crossovers, and the driver itself. Subs pull a lot of current because of the amount of drive power required to have very strong bass sounds. Other than that, this still does not rule out the possibility of the problem being defective components in the amplifier.
Jerry G.
Posted on Apr 25, 2008
SOURCE: car amp blows 12 volt wire fuse
the wire from your battery is blowing fuses? and you are using 20-30 A fuses? mine has a 100A fuse..look into getting new wire plus my wire is 4 gauge.., 1600 watts is too powerful for a 12 g wire and a 30 A fuse
Posted on Nov 18, 2008
  • 55 Answers
SOURCE: i need to know what kind of fuse my amp takes...
IT MAY MEAN THAT IT TAKES (2) 25 AMP FUSES
IF YOU HAVE THEM OUT SEE IF IT SAYS WHAT THEY ARE OR OPEN IT UP IT MAY SAY IT ON THE BOARD OR THE FUSE HOLDER OR LOOK @ THE SPECS ON THE AMP SEE WHAT THE TOTAL CURRENT IS YOU CAN ALWAYS START WITH A SMALLER AMPAGE LIKE 10 -20 AMP FUSE ALWAYS GO SMALLER
Posted on Feb 21, 2009
marketex
  • 371 Answers
SOURCE: Ground zero amplifier overheating and going into protect.
Since you changed the amperage of the fuses and the cable, you allowed the internal problems of the
amplifier to get worse than they were before the original fuses started blowing.
A fuse is a safety instrument that blows instead of your amplifier.
The problem is NOT the fuses frequently blowing, as such events warn you of internal problems with
the amplifier which you should have had serviced at the time to prevent them getting worse.
It is very much like the persons who replace the fuses in their household wiring with pennies, to prevent
frequent fuse replacement only to have their house burn down from overloaded circuitry.
Service your amplifier immediately.
Revert to the original amperage on all fuses in your vehicle to prevent a car fire.
Posted on Apr 08, 2009
Keep breaking fuses on T/L Ctsy after my son hooked a power wire there for his amp. now it keeps breaking fuses.whut can i do to fix this.
it sounds like the power wire you Son hooked up is not grounded and keeps blowing fuses. Try grounding that wire and make sure its not touching any others to spark and burn out fuses.
Oct 14, 2011 | 1991 Chevrolet Suburban
Just bought 2 12 in d3 dual 2 ohm subs with d5 600.4 amp. Need to know how to wire subs. They were in a box already I assumed they were wire at 2 o When i hooked One up to my amp it hit really for Jus...
what wattage are the subs and amp? if your subs are more wattage than your amp, your amp will blow fuses as cant handle the output to your subs. for example. you have 2 500 watt subs and a 300 watt amp, that is no good as amp isnt powerful enough. if you have 2 500 watt subs you need at least a 1200 watt amp to power them both. 200 watt more than the combined wattage of subs as amps should never be turned up to max as they tend to blow and overheat more quickly. 80% volume on amps is reccomended by installers and manufactures.
Feb 27, 2011 | Diamond Audio D5-600.4 Car Audio Amplifier
So i hooked up the amp useing the pre-existing 8 gauge wire with a 30 amp fuse it worked for about and hour and started blowing the 30 amp line fuse. i replaced the line from 8 to 4 gauge and installed an...
this sound like a case of arcing power wire it happens very very easy if u use cheap wire especially from walmart. whatever u do keep using fuses and get a batt test asap. if u take out the fuses ull burn the amp like no other and plobably burn out the power rails which will be cheaper to buy a new amp after that
Oct 05, 2010 | Lanzar VIBE266 Car Audio Amplifier
I have everything hooked up and i keep blowing the fuses in the amp?
did you use connectors on the amp or did you just strip the wire back then screwed the wire down? is the amp brand new?
Sep 12, 2010 | Alpine MRD-M1005 1000 Watt Mono Amplifier...
I have a 1200 w sony xplod amp, with 2 caps, hooked to my sony xplod 1200 w 15s, I just need to know what size inline fuse I need to have connected to my power wire to my battery? I have a 40A that keeps...
with no signal input the fuse should not blow ,if it blows then the amp has a short on it ,if it blows when the volume is turned up really high the try 60 amps .
Jun 18, 2010 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
3 amp fuse blows
Mark all your wires using tape or by writing it down to ensure you will be able to hook them back up exactly the way you found them. Remove all the wires from your board again. Tape off the ends so you don't "short" anything together. Identify the wires going to your outdoor unit and the wires going to your thermostat. Hook the wires up one at a time starting the with C wires and the R wires. Then hook up G. Then W. Then O. Then Y.....and any other wires you might have. Check the fuse everytime you hook up one of the wires. Remember to do the tstat and outdoor unit wires one-at-a-time also..........meaning........you will have 2 "Y" wires. Hook up only one, then check the fuse, then hook up the other, check the fuse...........Eventually, that fuse will blow again when you hook up the right wire. Then you will be able to determine the color wire and whether it is the one for the tstat or the outdoor unit. Once that is determined, disconnect that wire at the other end and re-install the fuse and restore power. If the fuse blows, the problem is in your wire. If it does not blow, it is most likely a bad control coil. More often than not, it's the wire. Look for damaged insulation and "crimps". Usually the repair can be made with simple electrical tape and/or cutting the bad spot out, using a wire nut and electrical tape, and testing it again. Let us know how you made out. If you run into another stumbling block, we'll dig deeper and walk you through it. :-)
Apr 10, 2010 | Heating & Cooling
I Hooked up a Performance Teknique 1200 watt 2 channel amp to my 2 12" comp kickers. and before doing all this i took out the fuse. from my car battery. after everything was hooked up i put the fuse back...
disconnect the amp and then put the fuse in.if it blows,there is a pinched wire causing a short.
Also,big amplifiers like that have to be wired battery direct.
the surge current at boot up can pull 100 amps for 10 millisec.
Jan 13, 2010 | Performance Teknique ICBM-892 Car Audio...
When I hook up my kenwood kac-7201 the power light
leave power connections hooked up disconnect rca and speaker wires if they still blow more than likely problem with amp
Dec 31, 2009 | Kenwood KAC-7201 Car Audio Amplifier
Amp keeps blowing the fuses
Serious short circuit on your output transistors, need replacing.
Sep 28, 2009 | JVC KSAX4504 MOSFET 600-Watt Amplifiers...
Car Audio & Video Logo
55 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
