Blaupunkt tv I have a blaupunkt 21.5 inch led tv flat screen I can pick up radio on it and it is installing all the freeview channels but there is no picture what can I do?
SOURCE: TV No Picture
My 32D40U would turn on for 5-10 seconds (Please Wait would appear) and the screen would go black. Sound Normal. It would also sometimes do this after running 5-10 minutes. I read somewhere that the inverter board would come loose and lose proper ground. I took the set apart, removed the board, and cleaned up the grounding points. I reassembled using some copper paste on the ground points and LockTite on the screws. I used some contact cleaner on all the connectors going to the board. I noticed two cables that are covered with copper shield tape where too tight at their connectors and repositioned the tape to give them some slack. The problem hasn't occurred since the fix.
Posted on Mar 22, 2008
SOURCE: Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Posted on Apr 30, 2008
SOURCE: LG LCD TV 37LP1D digital freeview tuning problems
Hi - I have the same problem. Also in Cornwall LG were not interested in helping because the TV was 3 1/2 years old. There was a possible fix in the end offered via LG at a cost of £180 + vat - a hardware update that might or might not work but I was not going to pay that so I now watch my LG 42 plasma via a £25 digi box from the CO OP. LG must have sold 1000's of these Tv's so when the digital switch starts in the more populated areas of the country I exect many more web postings.
Posted on Dec 06, 2009
SOURCE: Dynex 32 Inch Installation Problem
Hi I Just Bought A Dynex 32 Inch HDTV. I Did A Auto Scan And It Didnt Pick Up Any Digital Channels? Am I Suppose To Have An Antenna Or Digital Box? How Do I Get Th Channels To Come In?
Posted on May 03, 2010
  • 8457 Answers
SOURCE: IHave a 32 inch flat screen Westinghouse TV that c...
Ur tv the LCD inverter board it dead.The LCD inverter is the board that help the LCD screen panel to get a backlight to produce a picture,the LCD inverter board is dead and it not working anymore that why u only get 8 sec.of the picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Posted on May 23, 2010
I can't receive HD channels
Roy, change your cable, must be faulty and not giving a signal to TV.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 02, 2016 | Blaupunkt BLA32/147 32" LED TV 1920x1080,...
Hi have a built in freeview alba tv tune in channels working fine but dont have any bbc or c4 c5 any one can help me or send tv back
Can't tune Alba LCDW16HDF :( - Freeview - Digital Spy Forums
forums.digitalspy.co.uk/showthread.php?t=1238173
Digital Spy
Apr 1, 2010 - 17 posts - ‎8 authors
No matter what the problem DS Forum posters will always provide an answer ... That the Alba is your only digital television receiver - you don't have another ... I suspect the set may have found Craigkelly's BBC & ITV/C4/C5 ... BBC Three questions? - Broadcasting
Dec 13, 2015
Why dont RTE do this - Page 2 - Broadcasting
Aug 21, 2015
Channel 4 Licence Renewal and Scotland - Broadcasting
Mar 12, 2014
Why Won't Freesat/BBC let Viewers Nationwide have ...
Jan 20, 2014
More results from forums.digitalspy.co.uk
Freeview Help: Missing Freeview Channels - Radio and Telly
Jan 01, 2016 | Alba Televison & Video
Blaupunkt tv intermitent pining sound when tv is on picture not effected.
The problem post of yours' is difficult to understand. Provide more details; please. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 17, 2014 | Blaupunkt BLA32/147 32" LED TV 1920x1080,...
Why when turning on blaupunkt 1080p led hd tv i only get a black screen there is start up menu
If you tap "gently" on the front screen do you see whiteish color?
If no you have a problem with the set. probable power supply issue.
If you do then press menu. If you don't see the menu on screen, probable control board issue or lvds board. Time for a tech.
Jul 29, 2014 | Blaupunkt BLA32/147 32" LED TV 1920x1080,...
I have lost Sky Channel 82 from Freeview on Samsung HD TV I have tried to reinstall but channel 82 is still missing
U have more than one tv?Yes.Tries check on the other tvs see if u have channel 82 freeview channel,freeview channels are take out or add on all the times by the tvs stantions broadcasting listing.If yes channel 82 is on the other tvs.Than u have low or weak antena signal.U have a analoge antena probally correct?Buy and install a digital antena,u will get a stronger longer ranges tvs incomming broadcasting chaanels tvs stations.Rescan for channels again,u will pick up channel 82 if it still on the air.
Aug 11, 2011 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Dont not pick up freeview channels
if u pick up NON freeview channels, i think the antenna isnt good enough to pick up the signal..freeview requires a very good signal, very important.
If you think this isnt the problem rescan the channels
If you think the TV is faulty contact Samsung directly
Jul 15, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Televison & Video Logo
247 people viewed this question
Top Televison & Video Experts
