Question about Alba Televison & Video
Alba lcd22advd with freeview,was working fine then pressed a button and went to blue screen with countdown timer saying no signal on screen,HELP
  • 192 Answers
SOURCE: blue screen and shut off by self
You will need to reset the Netcommand and tuner settings in the set. The little indented button in the front of the set needs to be pushed in (when the set is off). The front light will blink for about a minute or minute and a half. Then, reprogram the Netcommand settings. This should solve your problem. If you need more information, then, reply to this post and I will respond.
Posted on Sep 23, 2007
SOURCE: Self Timer Activation
The instruction manual is quite poor. Once you have decided which option you would like (2 or 10 seconds) you must go back to the main menu to select which drive mode you would like. Single is default. From single, you can select self-timer, which will activate it for your next shot. The drive mode will always reset back to single after every shot so you'll need to set this up for every self-timed shot.
Happy shooting!
Posted on Feb 01, 2008
SOURCE: dvd burner
Can you try just running a/v cable from your tv output to the inputs on the ilo, then whatever you watch on your tv you can record on your dvd burner. My new SDTV doesnt have audio out except Coax so this won't work for me on that tv. Why doesnt the newer tv's have audio AND video outputs???
Posted on May 30, 2008
  • 70 Answers
SOURCE: blue screen?!
im not sure what that button is for i think pan and scan but anyway try holding the power button down for several seconds to rebut the player hopfully this works let me know if not and well try something else
Posted on Sep 21, 2008
SOURCE: my monitor says no signal
a friend gave me this computer because he got another and was tired of messing with this one ... he says he turned it off one night and it would never boot back up , sso i had a new 160 gig hd which is the same that was in it and i installed it thinking this would be a quick fix......... i reformatted with xp pro which is what i had put on this machine a couple years earlier and it was fine....it reformatted just fine and now the monitor says no signal....so i hooked the monitor up to another machine and the monitor is fine ....im stumped , any help would be appreciated.....i even removed the hd and put it in another machine and it worked great even with the monitor... got any clues?????
Posted on Oct 01, 2008
How do you set the clock for a 1061978 oxo timer
This is the only timer model OXO doesn't provide for download on their site. But I also own this timer, and this is what I've learned:
To set clock:
  1. Press and hold clock/timer button for 3 seconds (clock icon will appear on left side of screen).
  2. Input time using keypad then quickly press clock/timer button to save.
To set timer:
  1. Press and release clock/timer button.
  2. If necessary, press clear/memory so timer reads all zeroes.
  3. Enter desired time using keypad (to a maximum of 99hrs:99mins:99secs).
  4. Press stop/start to begin countdown.
  5. Pause countdown by pressing stop/start; resume by pressing button again.
  6. When countdown is complete, timer will beep continuously for 30 seconds and display will flash. Timer will then beep every 10 seconds for 10 minutes until the stop/start button is pressed.
  7. Press clock/timer button to return to clock function.
To time activities:
  3. Press stop/start and plus (+) sign will appear on right side of screen as timer begins counting up.
  4. Pause count-up by pressing stop/start; resume by pressing button again.
  5. When you're finished timing, press stop/start to end timing function.
  6. Press clock/timer to return to clock function.
Sep 15, 2013 | Oxo Hardware & Accessories
Need manual for oxo #1061978 timer
I own this model also and OXO doesn't offer the manual online. So here's what I've learned to do:
To set clock:
To set timer:
To time activities:
Mar 07, 2013 | Oxo Hardware & Accessories
Instructions for oxo model 1061978
To set clock:
To set timer:
To time activities:
Feb 17, 2013 | Oxo Hardware & Accessories
My alba lcd22advd keeps flickering while on fav channel
check for a dry joints at the inverter board for the screen back light, which may have loose contact.
Aug 10, 2012 | Alba LDVD1538WDCH LCD TV
Alba model LCD22ADVD not recognising DVD's. Message
Either a dirty or a bad optical pickup unit in the player---if bad it will have to be replaced and usually cheaper to buy a new set.
May 21, 2012 | LG Televison & Video
Hi, I have an alba lcd32880hdf tv and moved tv to different part of room, when I turned the tv back on and did auto tune channels came back up except itv ones so went to retune again but tv then came up as...
The Tv is working fine, from the description it is that one channel not coming in, the blue screen indicates no signal. It could be that the signal in that room is a little weaker and just going below the thresh hold to allow it to come through. It is possible the station might have been off the air, try another auto tune.
Apr 08, 2012 | Televison & Video
Acoustic Solutions TV/DVD P1480 has stopped working
Doh me, daughter had accidently hit the standby button without realising, had a brainwave after posting above and tried that, everything working fine.
Oct 01, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
TV Tuning on ALBA TV with DVD player
you start with tv,dvd mode to your remote control when you have alread make sure your in tuner you hit menu mode and show you the instruction select arrow shows _ + try it.
Nov 16, 2007 | Televison & Video
Viewpia lcd
click menu, on station prog go to EDIT. Press blue button twice, then go to rescan prog. (it seems to clear all previous scanned programs and starts again.
Oct 26, 2007 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Alba Televison & Video Experts
Michael Galve
Michael Galve
Robert Crombie
Robert Crombie
Level 1 Expert
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
