Question about Water Heaters
What is purpose of water pump switch in rv - Water Heaters
  • Water Heaters Master
  • 6,674 Answers
You have an onboard water tank, Potable water. WHen not hooked up to a hose outside the rv, you can pump water from tank on board.
Posted on Apr 25, 2013
Switch left on now Atwood RV electric water heater will not heat. What needs replaced?
If no water in it when switch left on for hydro use, you probably burned out the element. They burn out pretty quick when no water. You have to shut off breaker to it for safety, and remove back cover where you see hydro cable going in to access it.
Dec 27, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
What does DSI mean when referring to RV water heaters?
D.S.I. = Direct Spark Ignition. You would have a 12 volt switch inside RV, that when turned to ON, will ignite water heater automatically, provided ignition module and rest of components are there, or come with new water heater. Otherwise you would have to go outside with a lighter/matches or whatever and manually start the water heater.
Oct 22, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
WHAT IS THE PURPOSE OF THE AQUA STAT?
The purpose of an aquastat is to measure the temperature of the water flowing in the piping and regulate the control valve.
Mar 12, 2010 | Grundfos RCP-96 Recirculation Pump for...
I have a keystone camper and apparently the hot water line under the belly is frozen because I get no water flow to the sink...funny thing is at the shower and bathroom sink the faucets are switched the...
YEP. I'M IN THE RV BIZ AND IT'S MORE COMMON THAN U THINK. SOME DEALERS DON'T DO A THOROUGH JOB OF DELIVERY INSPECTIONS. ANYWAY, TAKE A HAIR DRYER AND THAW OUT UR FROZEN WATER LINE. SWITCH AROUND THE OFFENDING WATER LINES, THERE SHOULD BE ENOUGH PIPE TO ACCOMPLISH THIS. ASSUMING THE LOW FLOW IS WHEN UR USING UR PUMP, YOU CAN TURN THE PHILLIPS SCREW ON THE HEAD OF THE PUMP CLOCKWISE TO GIVE IT A LONGER STROKE. CHECK THE SCREEN FILTER FOR ANY DEBRIS, KINKS IN THE LINE BETWEEN THE PUMP AND WATER TANK, MAKE SURE THE AERATOR SCREENS AT THE SINKS AREN'T PLUGGED.
Dec 04, 2009 | RTO Atwood Water Heater - 6 Gal LP
1993 gm 28ft allegro bay rv water heating system just got it and dont know how to turn on hot water can u help
chk for shut off valve to heater , open if closed. Open hot water faucet and listen for water pump. if pumping givre it time to fill heater tank and start runnuing out offaucet. Air will be purged as pump fills the lines and heater. Shoer and bath need hot faucets open also to purgr air.
Apr 24, 2009 | Water Heaters
Hot Water Heater in 1991 Pace Arrow RV is not working
If you look on the outside of the RV, you will find the vent for the water heater behind and access door. There usually is a drain plug and valve located as well. Generally they will be tucked away under the kitchen sink area with internal access as well. You will need to find where the valve that shuts the water off to the unit is and turn it on. Most times the water heater is either electric or propane. But sometimes they are only propane. Once your find the access door, you will know where the water heater is. You can also contact Fleetwood who makes the Pace Arrow to see if they have any information on your unit. Usually your unit info or trim number will be located on a little plaque right by the entrance to the RV. You will need this when you contact them. Hope this helps.
Mar 31, 2009 | Water Heaters
Water Heaters Logo
131 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
