Question about Panasonic Lands Phones
Mic volume panasonic phone
Mic level is too low and I need to increase its level
robotek
  • 1512 Answers
SOURCE: No volume from Audio-Technica ATM410
the mic you mention is a dynamic mic, and needs a mic preamp to get decent levels for most computer sound inputs
Posted on Dec 14, 2007
SOURCE: Low record level for guitar
first of all you want to have your guitar amp at a decent volume but too loud, just enough to be able to get a good signal. when you have done this turn up the gain on your mic channel so that your VU meter (level meter) on the recording software shows a reading of about half way up the meter. If you can not achieve this with the soundcard alone increase the gain on your channel in the software.
This sound guarantee a good signal but as with most recordings you will still have to boost the signal without it peaking. to do this use a compressor or a limiter and turn the gain up. if you use these dynamic effects correctly you will achieve the guitar level you want.
Posted on Jul 10, 2008
  • 46 Answers
SOURCE: how increase my mic volume
a) to hell with calling india, they are as dumb as bush is.
b) click start > accessories > entertainment > volume controls. when the volume controls open, click on file (drop down menu) then select recording, then click ok. when the recording volume controls come up. select microphone as the default recording device, and make sure the mute box is not checked. slide the volume control slider most of the way up.
c) if you are using yahoo's call-out, run the audio wizard in yahoo messenger before making call.
d) plug your microphone into other 3.5 mm jacks on computer, and use window's sound recorder to see if the computer is picking up audio through the mic.
e) make sure your microphone's mute switch is not turned on (if applicable).
Posted on Sep 26, 2008
SOURCE: I have behringer xenyx802 Iam
Here is a link to what your looking for,
http://pro-audio.musiciansfriend.com/product/Yamaha-CM500-Headset-with-BuiltIn-Microphone?sku=245012
I can't tell from the add but hopefully it comes with adapters for both plugs that will work on your mixer. It does have the one for the headphones but the one for the mic is not clear, they are not interchangeable.
You would obviously plug the headphones into the headphone jack. The knob labeled "Phones/Control Room" will control the volume without changing what's being broadcast. What you hear in you phones is exactly what you are broadcasting.
The microphone needs to go into either mono channel 1 or 2. The adapter for it needs to be a mono Tip/Sleeve adapter as the more common stereo Tip/Ring/Sleeve adapter may cause some problems. You can tell the difference by looking at how many sections are on the plug divided by a little black line. Two sections is mono, three is stereo.
Adjust you microphone level by setting the volume knob, the one on the very bottom, to the 12 o'clock position. Then turn the gain knob, the smaller plastic one on the very top, until the desired volume is reached. If you experience any clipping or distortion turn the gain knob down until it goes away. These are general settings, you may want to experiment until you get the best level without noise.
Posted on Nov 30, 2008
  • 12 Answers
SOURCE: Haveing a difficult time trying to increase the volume of mic.
Has this always been an issue or just during class? If it has always been an issue, you need a preamplifier to bring up the signal. You can get one for pretty cheap and you can use it for other things as well (like a turntable or something).
Posted on Jul 29, 2009
Need mic for use on youcam--no sound...help?
Open your device manager and find mic inlet. It may be muted, uncheck mute or increase the slider level.
Sep 26, 2015 | Audio Players & Recorders
HOW TO INCREASE VOLUME IN XOLO A500S
here are some steps to increase incall volume
open your dial pad thwn input *#*#3646633#*#*
go to hardware option nd select audio then select sph.....select level 6 then select volume lwvel at 160 then press on set key
now reboot your dewice
The first step is to get in the "Engineer Mode" by pressing the following set of keys in the dialpad "*#*#3646633#*#*"
Xolo A500s low microphone volume fixby Sbplus 20/09/2013 ' 3:39 6 Posted in Tutorials
If you are a Xolo A500S owner, then you might have noticed the low microphone volume on this handset. So think no more, just follow these simple steps and this problem will be fixed.
You can watch the video or follow the steps below.
The next step is to go to the " Hardware Testing " and select " Audio "
Now select " Normal Mode "
From the dropdown, select " Mic "
Now we will increase the value to the highest possible number, which over here is "255" You can also select the level as " level 6 " , which will set the maximum value.
Now press "set" to apply, and then restart/reboot the handset.
Repeat the procedure if the settings are not saved the first time.
Sep 09, 2013 | Cell Phones
Hi, I have HT-1001 mic, the volume from the mic is low, any possibility increase the volume? do i need to use the external Amp?
The mike can be a mismatch with your CB A booster mike amplifier with a volume control will suffice.
Oct 25, 2012 | Hisonic Audio Players & Recorders
Can you please tell me how to increase the volume on my husbands phone as it not very loud thank you
most of the times there are side keys in mobile placed on either side of the mobile by pressing them up and down we can increase the volume. but if a pair of keys is not present on one you are talking about then certainly in setting-----sound settings you can increase the volume of the mobile. but keep in mind some time if a mobile previously working fine suddenly started to transmit low sound there may be a problem in mic as well. try the above mentioned steps and if the problem remains focus on the mic. it may be replaced by some mobile repairer.
Also it may be possible that the output sound of your mobile is low as you listen from your own mobile its volume if increased could also give you good results. thankx
Feb 10, 2011 | Cell Phones
I get the signal but listening very low Listening low noise and the voice is very low
This radio has a mic check. Turn on radio with out mic plugged in when you plug it in the volume should increase.
Possible causes.
  1. Solder or wire in mic cord broken.
  2. Bad switch in mic .....Astatic mics are bad for this
Jan 13, 2011 | Uniden Radio Communications
When im recording,the voice is to low
DEAR SIR,
R U USING LINE IN OR MIC , IF MIC , INCREASE MIC VOLUME FROM VOLUME CONTROL PANEL, & IF U R USING LINE IN INCREASE VOLUME OF LINE IN FROM CONTROL PANEL ..
Jan 05, 2011 | Computers & Internet
HP pavilion dv9005us. When using built in mic receivers say volume is very low. When I move the lid I get a crackling sound in the speakers like the mic wires a lose ..
To fix the low volume problem in mic receiver follow the steps below:
  1. Click Start , Control Panel .
  2. In the left panel, select Classic View .
  3. Select Sound , and then select the Recording tab.
  4. Right-click on Microphone and select Properties .
  5. On the Custom tab, select Microphone Boost .
  6. On the Levels tab, increase the microphone recording volume to the maximum level.
Then please check if it works fine otherwise you need to install the latest sound driver.
Windows VISTA 64bit and 32 bitsound driver:
ftp://ftp.hp.com/pub/softpaq/sp35501-36000/sp35684.exe
Windows XP sound driver:
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
Install the sound driver as per your operating system.
Apr 04, 2010 | HP Computers & Internet
Need more mic volume
Plug webcam into USB
Right click on speaker icon in the system tray by the clock.
Select 'Recording devices'
Click on your mic to highlight in blue
Click properties
Click 'Levels' and adjust slider
Click OK
Click 'Playback' tab
Click on Speaker to highlight
Click 'Properties'
Click 'Levels'
Increase speaker level if low
Click OK
Aug 22, 2009 | Microsoft LifeCam VX-1000 Webcam
I have a LG Shine KE970, and the mic is very low
when u make a call ensure the volume is @ max press the increase volume key when u r in a calll or press the right arrow key or move the joystick towards the right to increase the volume
Jul 12, 2009 | Cell Phones
Microphone volume goes down automatically
Go to control panel and select the sound option
There you will find microphone settings that are enabled, one of them is set to on and adjusts volume automatically as the noise increases, jsut disable that option
Cheers
Jul 08, 2009 | HP Pavilion dv6000z Notebook
Lands Phones Logo
16 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
