Question about Sys Technology SYS 17-C-MT (Chrome) 17 in. Flat Panel LCD Monitor
Help with me 17-c-mt lcd
Its a 17-c-mt sys lcd monitor and when i turn it on it diplays everything good but after about 5 min the dark areas star to flicker green. like a tv without signal.
0 characters
1 Points
Samsung SynchMaster 191N Monitor stay on fine for 15-20 min after that it goes dark,, and power swtich thrun itself off, cannot turn on or off, unless I unplug power for few min and replug. Then stays...
If the OSD has display and after a min goes dark that monitor has 2 possible problem. 1. bad electrolytic capacitor from secondary power supply to inverter area or fault semiconductors around inverter area. 2. Bad CCFL or fluorescent lamp of lcd panel it may be reddish color.
Sep 29, 2010 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Connect speaker cable from the monitor to the computer tower.& restrat the computer
Aug 25, 2009 | Sys Technology SYS 17-C-MT (Chrome) 17 in....
Flat Panel LCD Monitor goes dark for 2 sec then back on
sounds like the backlite bulb is failing. best thing to do is to take it in and have it checked if is worth the cost. some can be replaced, some cant.
Jun 05, 2009 | ViewSonic VA712B 17" Flat Panel LCD...
Sony SDM-HS75 tft lcd monitor
Sounds like you need a new backlight. Check
May 26, 2009 | Sony SDM-HS75 17" LCD Monitor
Viewsonic vx715 17" lcd turns on but goes dark in like 5 seconds
You need to replace your Inverter board or replace the 2 black caps on the power supply board wich are labeled 1000uF 16v ELITE. that will cure your problem. Glad I Could Help!
Apr 08, 2009 | ViewSonic VX715 17" LCD Monitor
Logik 17 monitor
The monitor came with 1 dead pixel in the bottom right hand sector but this is within the spec for most TFT's.
Dec 17, 2008 | Star Logic 17" LCD Monitor
LCD monitor dark
some starlogics have an auto dimming feature fro low light I usally turn this feature of in the menu.
Happy Holidays hope this helps
Sep 11, 2008 | Star Logic 17" LCD Monitor
Too dark
This IS an inverter issue. You need a new inverter. Open the LCD and find the inverter model number and search Ebay.
Dec 28, 2007 | CTX S762A 17" LCD Monitor
Won't Turn On
Possibly a capacitor on the internal board for the monitor that will not stay energized to allow the backlight for the monitor to illuminate. Going to need a qualified technician with the tools and equipment to diagnose it first hand. If you are not sentimentally attached to the unit, you can pick 17" monitors up pretty cheap these days.
Aug 26, 2007 | Sys Technology SYS 17-C-MT (Chrome) 17 in....
Sys Technology SYS 17-C-MT (Chrome) 17 in. Flat Panel LCD Monitor Logo
Top Sys Technology Computer Monitors Experts
Brian Sullivan
Brian Sullivan
Are you a Sys Technology Computer Monitor Expert? Answer questions, earn points and help others
