Rear wiper not working
SOURCE: Rear Windshield Wiper Problems
Check the wiper motor connection if its touching anything and loose it will automatically ground out and check at connection make sure you put some gel and then snap it in/ Please rate my response thank you very much
SOURCE: Rear Windscreen wiper not working Seat Ibiza 2003
smonahan, The rear wiper fuse is actually a circuit breaker. It will reset itself.
Your wiper arm has probably stripped were it attaches to the motor shaft. You can check by trying to move the wiper arm with your hand, if it moves back and forth, its stripped. A new wiper arm will be needed.
Try it and let me know.
Regards,
SOURCE: LOCATION OF BRAKE SWITCH
It will be on the brake pedal assembly ussually at the top where the arm pivots.
SOURCE: Citroen Relay HDI Van. Have no dip headlights.
Probably not, the fog lamp relay works off the dip beam power, is there a relay for the dip beams?
