Question about Konaki MP4-NS MP3 Player
Sansui mp208 switch on, but then stays on the home screen. Don't want to go in the menu
I don't want to use the antenna on my Sanyo Ds20930
You have to enter its service mode to rectify this problem. Just contact any expereinced tech, as this is a very risky and skilled work. The tech know, what to do.
May 22, 2012 | Sanyo DS20930 20" TV
Screen menu don't deasappear
Hello
The problem is with its main system control processor IC. You ahve to contact any experienced service tecnician to rectify this fault. It is a very skilled job.
Mar 10, 2012 | Toshiba CX32H60 TV
Menu box on screen won't come off
If the buttons are micro-switch type buttons (like you would have on a car's alarm remote) and they don't have the proper feel, then the monitor is probably ready for the recycle bin. Doing a little looking around it appears that the monitor you have is prone to failure. I think you should look into a replacement. Samsung makes a great monitor these days. I would steer clear of anything made by HP. Here is a link to someone else's woes with that particular monitor. Good luck!
http://h30499.www3.hp.com/t5/Home-PCs-Pavilion-Presario/f1703-Monitor-Menu-stays-on-screen/td-p/557824
Dec 18, 2011 | Proview PL 766s 17 in. Flat Panel LCD...
I ave a sansui home theater speaker system. the problem is that it is not functioning well,i think there is a problem on the parts inside i think its the i.c and need to be replace and i want to know where...
'not functioning well' tells us nothing. We don't know where you are to point you to a service center'; and even if we did, what keeps you from finding one online?
Sep 14, 2011 | Audio Players & Recorders
I have a Sansui SLED 2280 that I'd like to use without cable input. How do I switch to regular over the air (no cable) antenna? Thanks
To switch from cable to air or vice versa on most Sansui flat screen tv's including the SLED2280, go into the menu. Select "channel" on the screen. Press "enter" on the remote. Select "auto ch mem" on the screen. Press "enter" on remote. Select "signal type" on screen. Press right arrow button or right volume button on remote to change signal type (cable or air). To program channels into tv, select "automatic search" on screen then press "enter" on remote. Wait for search to finish.
I hope this helps you.
Bobya
Dec 19, 2010 | Sansui Televison & Video
Sansui LCT37SD switches off by itself
To anybody that has not been able to solve problems with the sansui lcd tv ,lines ,dots on screen etc after warming up ,pls contact me for the solution to the problem. i have succesfully repaired my lct 37st for next to nothing. garth@cybersmart.co.za
Apr 13, 2009 | Sansui HDLCD3210 32 in. LCD TV
Kenwood KDC-MP208 Clock Set
Make sure that the source is set to "Standby" when trying to access the menu. It took me about an hour to figure it out and afterward I felt like a ******.
Apr 09, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
Konaki MP4-NS MP3 Player Logo
Top Konaki Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Konaki Audio Player and Recorder Expert? Answer questions, earn points and help others
