Question about Charging & Starting Systems for Ford Fairmont
Cruise control stays on
When the vehicle is started the display shows that the cruise control is on but the fuse for the brake is taken out
  • 47 Answers
What is your car?
Posted on Nov 05, 2013
How to fix cruise control on a 2006 ford freestar, does not work at all, wont turn on
Note the diagram, at least check the fuse. Check trouble codes, related to cruise control. to check codes yourself, at least, you need an obd2 code reader that will read po codes as well as manufacturer specific codes. It is worth the investment, in my opinion. Make sure the brake lites work.
Mar 05, 2017 | Ford Cars & Trucks
Cruise control not working in my 2009 Silverado. It went out gradually over the past several months, pretty much worked intermittantly.
cruise control module has failed. or if your brake lights are staying on, then brake light switch has failed and not allowing cruise to engage. Have someone stand behind truck and see if brakes are working properly, if not- replace brake light switch. if fine, then swap out cruise control module under hood.... prob find one at a junk yard.
Feb 02, 2016 | 2009 Chevrolet Silverado 1500
Cruise control doesn't stay on in my 2004 Chevrolet Cavalier?
not being informed if it is auto or manual, here are some of the items that control the cruise control
brake pedal sensor ,
clutch pedal sensor,
vehicle speed sensor
engine ignition control module , tacho ,
vehicle speed --will disconnect if the road speed is below setting minimum speed
ratio changing
bad cruise control switch
wiring and connections
ecm problems
problem cruise control module
Apr 06, 2017 | Cars & Trucks
My 2004 ford explorer brake light intermittently stay on, it will not shift out of park, and the cruise control is malfunctioning. HELP
Check all fuses for the brakes this is a warning that something is wrong that's why your locked in park also check all contacts and wires for corrosion and continuity I've seen this before and it's brake related but you must check all including the cruise control are you sure you weren't touching the set accelerator or resume buttons ? It could just be the brake light switch down at the pedal it's probably done it's 14years old now if never have been replaced good luck Stephen
Jan 10, 2018 | 2004 Ford Explorer
My cruise control light comes on but won't engage
The reason any cruise control will not stay engaged is cause by 2 things.
1. Brake light switch. Check to see if your brake lights are coming on when your driving.... i.e have some one follow you while driving without the brake on.
or
2. Loss of speed sensor data to the control module. The speed sensor on an automatic transission car is located on somewhere the drive train / shaft. On a vehicle with a standard transmission the engine tach signal is used. (also unsed on automatic w/Over drive) If you do not see a tach reading on the instrument cluster I would suspect a tach sensor problem.
Troubleshooting needs to be in these 2 areas. As far as a source for schematics. Clymer and Haynes are 2 of many after market repair manuals.
May 18, 2010 | 2007 Honda Odyssey
I own a 2005 GMC Canyon Five CYL and the cruise control stopped working last niight. You push the button and no cruise. I checked the fuse and it is ok I exchanged with another 10AMP and no change still...
Start with the simple and check the fuses and the Stop lamp switch. Check your brake lights, if they're not working, the cruise won't work either. If they're not working, check the fuse for them, if the fuse is fine, then take it into the dealer, there's been a recall issued on the brake switch, so it should get fixed for free.
Cruise Control Disengaged
The powertrain control module (PCM) disengages the cruise control operation based on the signals from the following switches:
* The stop lamp switch
* The TCC brake/cruise release switch
* The clutch release switch, if equipped
* The cruise control On/Off switch
The TCC brake/cruise release switch and the stop lamp switch are mounted on the brake pedal bracket. When the brake pedal is applied, the normally closed TCC brake/cruise release switch opens and the normally open stop lamp switch closes. The PCM detects a low signal voltage on the TCC brake/cruise release switch signal circuit and a high signal voltage on the stop lamp switch signal circuit. When the clutch pedal is applied, the normally closed clutch release switch opens and the PCM detects zero voltage on the CCP switch signal circuit. The vehicle speed stored in the memory of the PCM will be erased when the cruise control On/Off button is turned OFF, or the ignition switch is turned OFF.
The Cruise Control System will disengage when the PCM detects that a driver override function has been active for approximately 60 seconds .
When the Cruise Control System is disengaged, the PCM sends a class 2 message to the instrument panel cluster (IPC) in order to deactivate the cruise control indicator.
Cruise Control Inhibited
The powertrain control module (PCM) inhibits the cruise control operation when any of the following conditions exist:
* A cruise control related DTC has been set.
* The vehicle speed is less than 40.2 km/h (25 mph) .
* The vehicle is in PARK, REVERSE, NEUTRAL, or 1st gear.
* The engine RPM is too low.
* The engine RPM is too high, with fuel cut off.
* The vehicle speed is too high, with fuel cut off.
* The system voltage is not between 9 volts and 16 volts .
* The Traction Control System (TCS) is active for more than 2 seconds .
Thank you for using Fixya and start with replacing the stop lamp switch. Even though the brake light work, it;s been known for that switch to cause your issue. that's way there was a recall for it.
Apr 01, 2010 | 2005 GMC Canyon
1999 Lincoln Continental Cruise Control Set Button
check and see if theres a blowen fuse before you start taken the steering wheel apart
Sep 20, 2009 | 1999 Lincoln Town Car
Cruise Control on 2001 Dodge Stratus SE stopped working. The green light comes on but it won't work. The fuse isn't labeled in either of the fuse boxes to see if that is the problem and I didn't get the...
Have you recently had any brake work done? I had a 05' freestyle that did the same thing.. when you tap the brake the cruise kicks off right? so if your brake pedal is sticking or not returning fully to the up position, the cruise will immediately kick off like you applied the brake. Check to see if your brake lights are staying on when you release the brake. Let me know what happens, please and good luck.
May 31, 2009 | 2000 Dodge Stratus
Cruise control doesn't work
does cruise show up in led when you start engine
Aug 14, 2008 | 2007 Dodge Ram Truck
Vehicle Parts & Accessories Logo
69 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
