Question about Makita 6936FD Factory Reconditioned 18-Volt Cordless Impact Driver
Makita impact drill repair
Can\'t open casing
SOURCE: Makita drill 6349D
dont think its http://www.toolbarn.com/product/makita/6349DWDE/
Posted on Oct 05, 2008
RonPark
  • 855 Answers
SOURCE: i took apart my makita 8271d 14.4v battery drill
Check and make sure you put the clutch pack in right and not backwards. That is what it sounds like happened.
Posted on Nov 12, 2009
radar001
  • 1051 Answers
SOURCE: removing chuck from Makita 64C1 drill
secure the short end of an allen wrench in the chuck, making sure it is as tight as possoble. Useing a wood or hard rubber mallet strick the long end of the allen wrench so it turns counter-clockwise. This should loosen the chuck from the spindle enough that you can unscrew it by hand.
Posted on Feb 19, 2010
Asbestos 56
  • 191 Answers
SOURCE: Ive got a makita ZIC-26 hammer drill and the drill
if this is an SDS try grabbing the bit with some vice grips and jiggling it back and forth. DO Not do this when its plugged in or has a battery hooked up. (your model # did not mach an online search so I don't know what you've got. Also a bit of WD-40 or the like may help loosen it up.
Posted on Jul 24, 2011
Testimonial: "thanks. tried wd but will try the vice thing. "
  • 885 Answers
SOURCE: wiring diagrams for makita hammer drills
Go to http://www.makitatools.com/en-us/Modules/Home/Default.aspx, put your model number in the search box and the parts breakdown and owner's manual can be viewed or downloaded.
Posted on Jan 16, 2012
Makita impact driver wobble
Many of my customers that use this tool heavily have the same problem. It's usually the Hammer Case (PN 154590-6). The nose if the case is the bushing that holds the anvil in place and sometimes wears out of round. Rarely the anvil (PN 324432-0) wears where it passes through the hammer case so check that also.
Feb 20, 2014 | Makita 18V LXT Lithium - Ion Cordless...
The screw point got stuck inside of the makita
Low quality steel drill bits get stuck in the Makita because the hammer impact squashes the metal, forming a ridge that gets snagged on the anvil's steel ball bearing. Use only impact drill bits.
Sep 15, 2011 | Makita 18V LXT Lithium - Ion Cordless...
I have a Makita 6914D impact driver. the motor works fine, but the drill has lost torque ( will not finish driving a screw ). The motor runs, but it just makes noise. What's the most likely worn...
Hi mybankston,
Welcome to fixya!
More than likely you need new brushes. Copy and paste this web address into your browser and a diagram and parts list for your drill will open up: http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/6914D
This is a good place to get parts. Fast service and delivery!
Thanks,
Handie Andie
Aug 16, 2011 | Drills
My makita impact driver has lost power. it seems to be using the hammer much more and seems to be slipping. both the hammer and the andvil don't appear worn. the bushes are fine. what could be the problem?
This is more then likely caused by the plastic gears inside the drill wearing down. Makita may replace/repair under warranty depending on when you purchased the drill.
Mar 18, 2011 | Makita 18V LXT Lithium - Ion Cordless...
My Makita BHP451 Li ion battery drill periodically the varible speed does not work, ie. the button works as a on/off switch - any idea what's wrong. Thanks Bjarne
Bjarne, odds are the variable speed function of the trigger is failing. There are Makita repair centers that perform repair, and sell parts if you want to take it on as a DIY project. Before proceeding, I would make sure the warranty has expired. If it is still in warranty a Makita repair center should repair it for no charge.
Dec 19, 2010 | Makita LXT202 BHP451 18 Volt Hammer Drill...
Makita impact driver dead spots
Depends on model you have. There are 2 brushless models - BTD132 (14.4V) and BTD144 (18V) - both have big BL letters on housing. According to your picture, you have BTD140 which has brushes. When you open user manual, you can find section dedicated to changing brushes. In case it does not help, you migh want to check trigger. Juraj
Jun 07, 2010 | Makita 18V LXT Lithium - Ion Cordless...
I have a Makita 6935 FDWDE. I need to separate the two halves for repairs but I can't figure out how. I have all current drawings but it doesn't really show anything.   Any help would be appreciated.
Beware that if all the screws are removed try to open with a sharp knife between the housing and if not worked then knock him open with hammer around rapping , because of heat (melting) problems
Dec 20, 2008 | Makita 6935fdwdex 14.4v Impact Driver...
Makita 6936FD Factory Reconditioned 18-Volt Cordless Impact Driver Logo
23 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
